Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Typical turbo lag?
      05-14-2015, 11:25 AM   #1
georgy21
Drives: 335i
Typical turbo lag?
I recently replaced the turbos with new stock turbos on my 2008 e93.. car is fbo with meth (stock exhaust)
The car is usually super responsive and boosts like a bat out of hell
This is my question/problem... sometimes what seems to occur is when Im WOT from low rpm (any gear other than 1st) my boost shoots to 7-10 psi, hangs there for a couple or few seconds, then shoots to its 18-19 target... almost like a delay in the 2nd turbo kicking in
This phenomenon does not occur if I very slowly tip in the throttle, or Im starting from a 1st gear WOT pull, and sometimes doesn't occur at all, depending on conditions.
Im curious to know if this is typical lag that others experience or something I need to dig a little deeper into..
      05-14-2015, 12:24 PM   #2
Longdoggy
Master Bates
Longdoggy's Avatar
80
Drives: 2020 BMW M340 xDrive
Do you have an aftermarket charge pipe?
CURRENT: 2020 G20 M340 xDrive — Carbahn Tune
RETIRED: 2011 E90 335i xDrive — Cobb AP3, PE Exhaust, Alpina TCU Flash, VRSF Charge Pipe
2017 Estoril Blue X1 M Sport — JB4
      05-14-2015, 12:26 PM   #3
mojobmw_e90
380
Drives: 2014 E63S
Lags usually occur from a downpipe leak, that's if there is no boost leaks
      05-14-2015, 12:52 PM   #4
georgy21
Drives: 335i
I do have an aftermarket chargepipe and I had multiple issues with it blowing off since replacing turbos due to the pressures. I recently did a pretty good job securing it in place and made certain there was no gap in the connections..
I also have AR downpipes but no issues there as far as leaks
Im at a bit of a loss..
      05-14-2015, 01:05 PM   #5
csu87
2134
Drives: 09 335xi
Check the manifolds. typically when you remove an exhaust manifold or turbo from the manifold, the heating and cooling can loosen the bolts and need to be checked regularly for a week or 2.
