05-14-2015, 11:21 AM | #1 |
115
Rep 418
4 Year/50k Miles Covers What?
I've got an amazing 2014 M235i that has about 12k on it. No troubles so far except a flat tire (thank you wheel/tire ins) and a cracked windshield. I paid for a 3k oil change for my break-in piece of mind and already received my 10k oil change (free). My question: What isn't covered in the new car warranty? I don't want to dig through the fine print, but if any of you know a summary...
I assume tires are on me. Wiper blades? Brake pads? All fluids? TIA. |
05-14-2015, 12:44 PM | #2 |
701
Rep 2,337
You're asking about "warranty" but also mentioning things not covered under a warranty, but under BMW's maintenance plan.
From what I've experienced and seen/read, everything but drive-related incidentals are covered. Aside from tires, anything that is a consumable, that has been consumed, is covered. Brake pads - covered Rotors - covered Fluids - covered (but generally under their schedule - except gasoline... I haven't gotten them to replace the fluids in my tank once, damn it!)
05-14-2015, 01:20 PM | #3 |
91
Rep 333
Drives: 228i
You need an i3 for that!
05-14-2015, 01:22 PM | #4 |
1538
Rep 3,331
Wipers are covered, but make sure to mention it to them otherwise they generally won't replace them. I usually get them done every oil change.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
05-14-2015, 02:02 PM | #6 |
739
Rep 1,066
05-14-2015, 02:21 PM | #7 |
98
Rep 168
Curious about the brakes.
Im at 4800+ miles so far so haven't had my first oil change yet (computer shows in about 2000 miles) As far as brakes go....Im assuming they will only replace pads AFTER certain mileage? Say if you kill your brake pads BEFORE x amount of miles its on you? or will they replace them regardless within reason? Say 10000 miles as an example. Roman |
05-14-2015, 02:36 PM | #8 | |
739
Rep 1,066
05-14-2015, 02:59 PM | #9 | |
76
Rep 288
Unless there is a physical evidence of failure evident (broken clutch spring, lever, etc,) you're gonna hear that "sorry, this repair isn't covered" phrase from your SA. Don't take my word for it, just ask anyone whose had the experience. A burned out clutch is a symptom of driver incompetence/misuse at 50 K miles. That's not me saying that, but it's what BMW will say (yet, I agree with them). |
05-14-2015, 03:05 PM | #10 |
1538
Rep 3,331
Yeah if you have to replace a clutch at 50k you are slipping the clutch way more than it is designed for. I'm not sure if that is covered since it would be considered abuse and could likely be proven by a hot spotted flywheel.
For brakes, they will replace them when they need to be replaced, and not sooner. I did not have to replace the brakes on my F30 after 40k so I couldn't tell you. I had a substantial amount of pad left even with the more aggressive M sport compound pads. If you are tracking the car on BMW's dime they will notice that the pads needed to be replaced multiple times and will more than likely call you out on it.
05-14-2015, 03:08 PM | #11 |
10661
Rep 6,937
Drives: 2018 M2 AW DCT
Oh, and the battery is usually not cover either.
05-14-2015, 03:15 PM | #12 |
106
Rep 855
They pretty much made me come in for my first oil change in February even though I purchased my car in June last yeat and it had less than 4000 miles on it. They calculate the 12 months from the date of production, not the of purchase. I had a 1/14 build date.
05-14-2015, 03:24 PM | #13 |
76
Rep 288
BMW is pretty good and being able to determine normal wear-and-tear .vs. abuse.
I'm sure that somewhere in the literature there's an "abuse" clause that exempts coverage. |
05-14-2015, 06:22 PM | #14 | |
Rep 80
The oem clutch on my '11 WRX was toast after about 55k miles, which surprised me since I did not "abuse" the clutch at all. I did, however, do 80% of my driving in traffic. Would never have guessed it was as bad as it was (was not yet slipping), but decided to check it out when the motor was pulled for a rebuild and saw the damage. |
05-14-2015, 06:53 PM | #15 | ||
76
Rep 288
05-14-2015, 08:19 PM | #16 |
Rep 80
cause subaru ringlands.
oem pistons are notoriously weak. I was making stage 2 power (nothing crazy, around 300whp) and they cracked...low compression in cylinder 2. Very common issue and I was one of the unlucky winners. Had the motor rebuilt with forged pistons and sold the car shortly thereafter sadly. Looking forward to being in a stock vehicle for a while! |
05-15-2015, 02:12 PM | #18 | |
76
Rep 288
05-15-2015, 04:09 PM | #19 | |
Rep 42
Long life clutch
