Those of you running Devil's Own or progressive Water/Meth
05-14-2015, 11:09 AM | #1 |
24
Rep 217
I am about to install my Devil's Own kit and had a couple questions:
1. What size nozzle is everyone running? 2. What did you set your progressive boost controller to (Psi to come on and Psi max)? 3. Where did everyone tap in to get their 12v ignition power for the controller? I will more than likely update this thread as question arise during my install. Thanks guys! I am pretty impressed with how helpful such a small group of enthusiasts have been. |
05-14-2015, 07:36 PM | #2 |
798
Rep 1,633
CO335D, there are various levels of tune out there, so taking someone else's settings is not your best bet. Also, you did not mention whether you would be running a H20/methanol mixture, and if so what the percentage would be.
H20 acts as a coolant. Evaporation can lower the intake temps and that is a good thing. When it gets in the combistion chamber it will lower exhaust temps. That can hurt performance at lower pressures and loads. Methanol is also a coolant. But it is also a fuel. So it will counteract some of the heat it adds to the combustion chamber. Most folks run @ 50/50 mixtures to maximize the power from the methanol. Any mixture is going to clean the intake tract. Some trigger on boost, some trigger on rpm, some trigger on a combination of boost and rpm. Some do stages with multiple nozzles and soleniods, some do progression with PMW of the pump, others do PWM of solenoids. If you don't log exhaust temps, your just playing. However, as a general rule you can safely inject a 50/50 mixture at 1/2 the volume flow rate of diesel fuel, at WOT, without quenching combustion. That equates to @ 300cc/min at maximum stock Hp. For more information, please check the other threads that already exist in this forum, regarding this subject. |
05-14-2015, 07:57 PM | #3 |
411
Rep 3,049
Drives: 2009 BMW 335d
I think Diesel Racer was a fan of Devil's Own.
05-14-2015, 09:41 PM | #4 |
427
Rep 1,040
I'm running pieces of a Devilsown kit (pump and nozzles) with a piggyback controlling it.
I currently run a 3 and 7 nozzle together, controlled progressively with a map (at 50/50 mix). I believe that equates to about 660cc/min. You can tap into power in the dde compartment under the cowl, there is a wad of positive wires that are joined together at a solder crimp that is heat shrinked from the factory.... Last edited by iaknown; 05-14-2015 at 09:52 PM.. |
05-15-2015, 09:03 AM | #5 | |
24
Rep 217
05-15-2015, 09:41 AM | #6 | |
798
Rep 1,633
05-15-2015, 10:55 AM | #7 | |
614
Rep 2,410
http://www.e90post.com/forums/showpo...9&postcount=11
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods |
05-15-2015, 11:36 AM | #8 | |
798
Rep 1,633
05-15-2015, 08:52 PM | #9 | |
Rep 69
1) I'm running a 60 and 225 ml/min nozzle 2) My initial setting has the 60 nozzle come on at 5 psi, and the 225 come on at 10. It was great for full out on the dyno, but cruising on hills, it was too much and I had some quenching occur. New setting has 10psi for the first nozzle, and then 20 for the second. 3) My installer could not find a 12V source. I wish I had saw TDIwyse's post last night. I also attached a pdf file of my dyno graph. I'm not certain the validity of it, but it's at least consistent. The first and second runs (two lowest HP numbers) had no meth added. The third and fourth runs (two highest HP) had meth added at different psi triggers. Best gains had 12 horses and 30 ft-lbs. I'll take pictures of the install tomorrow, hopefully. |
