05-10-2015, 11:23 PM | #1 |
119
Rep 221
track day - prep
I'm looking to do a track day. I'm not looking to turn my car into a race focused machine and lose the daily driver friendliness, but I do want to prep it the best I can. Any advice would be appreciated.
This is what I'm thinking: -Change brake lines to Champion SS -Flush fluid to Motul 600 -Change brake pads to? R4-S, RS-29? (these can be track focused pads as I'll change them back to stock after) -Tires/rims (currently have stock Pirelli 225 square)...Not looking to break the bank but I would like a summer tire set -Camber plates? Based on some posts it looks like these help with evening out tire wear. Are there any drawbacks with them? Thanks. |
05-11-2015, 12:26 AM | #2 | |
450
Rep 845
05-11-2015, 06:51 AM | #3 |
51
Rep 269
yes, I would say no reason to upgrade the pads when not using slicks. I just did a full day on stock pads and the pilot supersports at Atlanta Motor Speedway and the stock was good enough for these tires.
05-11-2015, 09:14 PM | #6 | |
1399
Rep 5,262
05-11-2015, 09:31 PM | #8 | |
1399
Rep 5,262
1) sidewall is soft so you need to run 40+ psi in the front to prevent rollover 2) they are staggered so not much you can do rotation wise... you could move the right front to the left front but that's about it 3) because of the little camber it will eat your outside shoulders... simplest fix is http://www.2addicts.com/forums/showthread.php?t=1079766 unless you want to do camber plates As great the PSS is for the street, I wouldn't buy a PSS as a dedicated track tire... get the Direzza II, Hankook RS3's... I got the Bridgestone RE-71R but haven't run them yet |
05-11-2015, 10:07 PM | #9 | |
51
Rep 269
05-11-2015, 10:17 PM | #10 | |
1399
Rep 5,262
now I can only see the arrow on the rear wheel Last edited by pikcachu; 05-11-2015 at 10:22 PM.. |
05-11-2015, 10:20 PM | #11 |
153
Rep 446
05-12-2015, 08:29 PM | #12 |
463
Rep 957
I wish mine looked that good. These were mine after euro delivery and a day at spa.
05-12-2015, 09:22 PM | #13 | |
1032
Rep 1,997
OP - the stainless lines is something that sounds good in theory but i didn't notice any benefit in my e46 m3 when i did them.... once the rubber lines start to get dry looking i'd do them, but that will probably be a while from now on these new cars that being said some people absolutely swear by them... i won't ever do them again unless the lines need to be replaced. DOT4 brake fluid is another thing it seems like people swear by and i always advocated until recently when i found a guy who has tracked his e9x and now f8x M cars HARD only ever using stock fluid. i think the biggest thing is that it's fresh though and free of debris/air/water. i use ATE fluids, not the more expensive stuff because i haven't had a problem with it and it's not a big deal to use it over the OEM fluid so it's an easy thing to "upgrade". track pads are a nice thing to have and if you'll be swapping them out and have the cash, go for it. i'm sure you could probably get a few track days in on the stock pads especially if you manage your pads (shorter braking periods .. dragging them and having a longer braking period will generate more heat and less time for cooling between braking zones) and cut back on top speed on some of the straights. i'm not an expert or an instructor but i have read around a lot and done a number of events myself in different cars. the best thing you can do is just get out there and have fun, use an instructor and keep yourself hydrated and well rested. after going out for a weekend you'll be able to see what deficiencies you think your car has and what you want to upgrade. maybe brakes. maybe tires. maybe both. maybe a set of racing seats and harness bar (if they have them on this car?). take everyone's input and see what works best for you, have fun!
Gone but not forgotten: '09 STi // '08 335i // '02 M3 // '11 335i // '15 M3 // '16 M3 // '16 Camaro SS // '16 Audi S3 // '18 Boxster 718S // '17 Camaro SS 1LE // '16 M6 GC CP
05-12-2015, 09:27 PM | #14 |
51
Rep 269
05-12-2015, 09:53 PM | #15 |
1399
Rep 5,262
05-13-2015, 08:13 PM | #16 | |
463
Rep 957
That being said, camber plates, LSD, jb4 and sway bars, suspension, and proper track tires and I am in love. Have to be happy modding though. To give you perspective I track at least 40 days a year and have access to drive many many cars. With the mods it's a rewarding car to drive, I can fit the track tires in the back and still use it when the wife wants to go to dinner. I can't think of another car I can do all this in. I could get a smaller lighter car but I would be back to trailering (no where to put tires) or another dedicated car which will get me back into racing and make the cost of this look like buying a used yugo. |
05-13-2015, 08:16 PM | #17 |
463
Rep 957
Nope, what you really need is camber plates and track tires. Super sports are only good in rain. That roll over is at about 43-45 psi front. Did not have time or money to change tires on euro delivery. On the plus side they did last 2 days at spa and a day at the ring 😀
05-13-2015, 09:58 PM | #18 |
330
Rep 1,084
05-13-2015, 10:00 PM | #19 | |
1399
Rep 5,262
05-13-2015, 11:24 PM | #20 | |
450
Rep 845
I've done my fair share of modifications (and really like them), but the car was definitely capable out of the box. It just wasn't a race car (and wasn't designed to be). If you want to go that route (like I -- and it seems like you -- did), then more power to you. But I don't think it's a defect in the car. Except a the lack of a real LSD as standard. That's pretty lame. In any event, the car does lend itself to modification pretty well. Mike, if you want to modify, the car can become very, very special. It just needs some TLC. Hell, my list (so far) is: Camber plates Springs Exhaust Brake lines Brake fluid Brake pads LSD (with gear ratio change) P3 gauge (oil temps) Track wheels Track tires Harness There's definitely more to come (sway bars, then some power upgrades), but the car is a freaking blast now. And very capable on track. Last edited by Liquidpaper; 05-14-2015 at 03:25 PM.. |
05-14-2015, 12:59 PM | #21 | |
463
Rep 957
funny you say that, I did some damage to them, but most was done by a pro driver who won Sebring in GTLM class a few times..... |
05-14-2015, 06:01 PM | #22 |
119
Rep 221
Thanks for the additional info.
Are there any drawbacks to camber plates? I'm going to keep my current 225 square Pirelli setup for winter so I will likely get a good set of summer tires (too much money to go designated track tires plus summers at this point). Any suggestion on a good set of inexpensive 18" rims would be appreciated. It looks like stock tire size call for a 245/35-18. Tirerack only shows the PSS in this size as an option for the tires mentioned in this thread, unless I'm missing something. Also, does anyone know the difference between the PSS and the PSS BMW besides $47? Thanks, |
