05-07-2015, 11:15 PM | #1 |
Enjoying driving
388
Rep 1,169
Got Camber?
TC Kline plates are in, both front and rear are set to maximum negative camber. It looks ridiculous, and I know it is too much However, for me to approximate the camber curve of this car, I had to set it to maximum, drive on track and take some measurements, and compare them with stock settings; eventually I'll find the correct range for my tires.
It is not as bad as this: Reddit Kill Me Please But... Max Camber Fronts now are -4.1 and rears are -2.2. Certainly my street tires will suffer for couple of weeks, but I think it will be worth it. In the mean time, the turn-in with MPSS tires has noticably improved, I no longer feel the weight of the front end any more, it is much more sure-footed through interstate ramps. We'll see how this translates to R888s on track. Did I mention it looks ridiculous? It does, LOL. Although the side benefit is that now I can fit 295/30 tires up front |
05-08-2015, 11:14 AM | #2 |
1231
Rep 1,789
Drives: wife crazy
Garage List 2019 Ford Raptor [0.00]
2016 Porsche 991.1 ... [0.00] 1987 Chevy Camaro I ... [0.00] 1972 Chevy Corvette [0.00] 1999 BMW M3 race car [0.00] |
Road course laptimes for BMW M4 2015 6MT
WHP East Track: 1:04.880, Arizona Motorsports Park: 1:54.352 Road course laptimes for Porsche 911 991.1 GTS 7MT WHP East Track: 1:02.770, Arizona Motorsports Park: 1:48.889 |
05-08-2015, 11:18 AM | #3 |
Enjoying driving
388
Rep 1,169
, yeah no sh$t.
Test setup for end of month, pyrometers and digi pressure gauges warmed up, test crew ready, I just need some gas I forgot to mention, caster now is 9 deg. |
05-08-2015, 04:36 PM | #5 |
814
Rep 7,888
Remember as the caster goes up you need less static camber as your camber gain will be greater when the wheel is cranked.
05-11-2015, 08:58 AM | #6 | |
Enjoying driving
388
Rep 1,169
Btw, the MPSS tires loved the -4 deg. camber, the wear were right at the outer marks after our autox yesterday and grip was superb and carcass heat distribution was near perfect. Of course this is another indication that for track duty the camber will be too high as expected. This is also an indication why many keep chucking MPSS at the track, they seem to really want a lot of camber if my results are any indication at all. |
05-11-2015, 11:17 AM | #7 |
252
Rep 633
+1. FTS with E36/46 chassis you needed -3 degree up front but with the E9X there was dynamic camber built in (where you didnt lose a whole bunch of camber when turning the wheel), I dont know the technical term to describe this in detail but basically you didnt need crazy camber. -2.4 was recommended to me by race teams (Malek from MRF in West Coast) and Bimmerworld (I have a good relationship with them). I dialed in from -3 to -2.4 and my outside tire was wearing MUCh better. I have set it in at that setting now.
Rear -1.8 again slight bit less than previous gen. Anything more and the benefit curve falls (lose traction on putting power down, not utilizing the outside tire etc). That said this was previous gen. I doubt you'd need -4 camber and would start with -2.5 and -1.8. I have spent half dozen visits to the alignment shop and used pyrometer on the track to get readings and this is VERY consistent with lowered Eibach and R comps I am running. New gen (post E46) are much easier on camber.... FYI Lutfy |
05-11-2015, 12:02 PM | #8 |
709
Rep 3,251
Any idea how does the camber plate come together? HPA mentioned you reuse the stock trust bearings, but it would be nice to see some installation pictures or shots from the wheel wells.
Also what suspensions are you running with? Adaptive or non-adaptive? Or some aftermarket coilovers perhaps?
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization |
05-11-2015, 08:21 PM | #9 | ||
Enjoying driving
388
Rep 1,169
The installation of camber plates and alignment took 6.5 hours. I was very disappointed and thought it took too long for such a small job, however work done was really done well without any side effects of any kind and very cleanly; credit is given where it is due. Today, I tried to change the alignment myself and after seeing the amount of work involved and how poorly BMW designed the chassis setup, I gave up and took it to my usual shop where they also know performance cars very well. After seeing how they struggled to change the alignment and fail, because once you take off the strut braces and loosen the plates, nothing fits back in so nicely and easily. 2.5 hours of wasted work and we towed the car to the original race shop and they will fix it So, at the end, although I was disappointed that the work originally took so long, I now understand why it does and won't criticize the race shop's work for a second. For comparison purposes, I could align my GT3 in less than 1.5 hour; camber, toe, caster, ride height and A/R bars; my shop used to do it in half that time with proper alignment machine. The car was designed for easy maintenance. This is where i miss the Porsche frankly. BMW just made it so hard with their strut tops and overall adjustment points in general that I find it ridiculous. Camber plates are probably the first and only mod I will do to this car. And btw, because it takes so much longer to do these things on this car the maintenance costs thus far has been higher for me than on the Porsche, I am sure many other small things are worse than they first sound, e.g. removing the brake dust shield or the wheel hub etc. Apparently you cannot just remove the shield, the whole hub assembly has to come out and then you have to replace the darn hub assembly with new So, as I said it is all a learning process for me, I appreciate the patience, yours and mine So the short answer to your question, I do not know if they reused it I have stock adaptive shocks. |
05-11-2015, 08:48 PM | #10 |
1231
Rep 1,789
Drives: wife crazy
6.5 hours for camber plates and alignment, wow! Sounds like the F8x is kind of a bear to work on up front? Glad it's done for you though.
05-29-2015, 03:53 PM | #11 | |
709
Rep 3,251
It is nice to know these little details that only come with a long term ownership. Which GT3 do you also own, 997.2 perhaps? Would be nice to hear some comparison between a well sorted out F8x like yours to a 911 down the line. Kind of gathering information at the moment on future car purchase.
05-29-2015, 07:23 PM | #12 | |
Enjoying driving
388
Rep 1,169
And my first review of the F8x that includes some comparisons are here: http://f80.bimmerpost.com/forums/sho...d.php?t=999575 I don't think I am yet qualified to compare the F8x to any Porsche from a track perspective, I am quite far off the M4s capabilities still. However, I'll add few thoughts: I have a renewed appreciation on how easy it is to work on Porsches compared to Bimmers, and believe me, for me it has been less costly to maintain a Porsche than a BMW thus far. I still maintain though the M4 is a bargain. I believe we are getting about 80% of the performance that a 997 or 991 GT3 offers at 50% price discount, and to me that is a bargain. As long as one can accept the fact that the 20% gap cannot be eliminated in any way, can be narrowed, but not eliminated. With the use I get from the M4, that gap is not important to me; however, for people that have never had it and don't know what that 20% is, getting a GT3 is an obsession nowadays. At the prices the 997 cars are selling, I am in shock there are people paying and driving them. They are not worth it IMHO. The first and most important problem I have with the 991 GT3 is that it is not motorsports derived. To most people that does not mean anything, it is similar to ///M no longer means Motorsports, and I understand that. However, a Porsche GT has to be linked to the GT3R and GT3RSR and the GT3 Cup has to be based on the homologation of the GT3RS. The reason I believe that is important is because:
None of the above are part of the 991 GT3, and to me it is not a GT car, but a marketing ploy, similar to ///M brand. So, if I am right, why would I pay a premium to Porsche over an ///M? As you probably know, there are major engine and chassis changes to the 991.1 GT3RS. It is supposed to truly homologate the upcoming GT3R that is in testing right now, and the GT3RSR will follow shortly. Wonderful and I am on the list for a 2016 model, but I have to see it win first. It is likely I will wait for 991.2 or 992 GT3RSR just for that reason. It may be silly to most, but it is important to me if I am to pay double the price of an M car. So, IMHO again, the best performance or sports car from Porsche today is probably the GT4. However, I'd never buy that either because of its compromised rear suspension. Again, if I am to pay a premium to Porsche I want all of the above, not a compromise. If I need to accept a compromise, the best compromise car is an M car in my determination, hence the reason I am here Btw, here are my views and discussion with Pete_VB on the topic of GT4 (although he still ordered one and I did not ), starting with post #28: http://www.2addicts.com/forums/showt...1061058&page=2 |
06-01-2015, 02:13 PM | #13 |
329
Rep 984
I have the same camber plates and am running -3.2 degrees in the front (middle setting) and -2.3 in the rear (if I remember correctly) - seems good so far.
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
06-01-2015, 02:44 PM | #14 | |
386
Rep 2,988
06-01-2015, 04:12 PM | #16 |
21115
Rep 20,741
Drives: 2021 911 turbo
As far as camber in front, you'll be stuck with whatever you car came with. I understand it is not adjustable at all.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
06-01-2015, 04:15 PM | #17 |
3187
Rep 10,509
06-01-2015, 11:48 PM | #18 | |
709
Rep 3,251
I wholeheartedly agree with pretty much everything you said. But it is inevitable that Porsche does away with the old school port injected Mezger engines in search of better efficiency on with newer 9A1 based engines. Nonetheless, chassis upgrades from the Carrera models to the GT3 are substantial, and price that Porsche charges on the GT3 is not so bad in all consideration, IF you can still find a allocation for the 2015-2016 models or a used one that doesn't sell more than the msrp... GT4 is a great car no doubt, but in my opinion it is as much a glorified part-bin special from Porsche as the BMW 1M was (it was nothing more than a 135i with the bolt on M3 suspension parts and some flared fenders...none of which demands the premium that BMW or the used market charges for that car) On the other hand, GT3 probably has the lowest front clearance of any non-exotic production cars, which will severely limits its drivability in my region, and I don't find the appeal nor have the resource to keep a car as garage queen in the near future. F80 is probably the most logical choice at the moment, given the my familiarity with the chassis, engine, and its aftermarket supports. But the emotional side of my brain has been yelling at myself to get a 911 ever since I was old enough to know what kind of a car it is. Guess I wait and see how does the 991.2 c2s/gts turns out in a few months or just pick up a used 991.1 down the line. From my understanding, if you can confirm, is that even a relatively basic 991 (even more so w/ sport PASM) will out run a well prep'd BMW (due to its stock camber and softly sprung stock suspension), with the same driver and just some track capable tires/brake pads, while still capable as serving as a reasonable DD.
06-02-2015, 12:46 AM | #19 | ||||
Enjoying driving
388
Rep 1,169
06-02-2015, 11:54 AM | #20 |
329
Rep 984
Middle setting, lowered on HAS.
06-02-2015, 01:31 PM | #21 |
Enjoying driving
388
Rep 1,169
06-02-2015, 01:33 PM | #22 |
329
Rep 984
About .7 inches.
