05-07-2015, 09:21 AM | #1 |
Rep 4
no-hole front license plate holder... parking sensors
So I bought the front license plate, no-holes holder from Turner Motorsports and can't seem to install it where it doesn't counteract with the parking sensor...
Solution...? Different holder that does work? Advice on installation from someone who figured it out? Turn off the 1 sensor that it covers? (how?) |
05-07-2015, 10:02 AM | #2 |
1910
Rep 5,103
I used the usmillworks version on my '15 and seems to work w/o issue. I can't speak to the version you're using, but the millworks one allows you to tilt the plate in a variety of angles.
A little pricey, but works great. I have it on my x3 as well.
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
05-07-2015, 11:03 AM | #3 |
1538
Rep 3,331
I can't get the US Millworks to not buzz the sensors on my car. Even if it falls into a groove where the PDC doesn't see it, even the slightest bump or shift will twist it back into a position where it blocks one of the two.
If I could turn the PDC beeping off I wouldn't care, but I have not had much luck. My next thought is to take the bracket off, bend the bracket curved so that it forms to the bumper better, and then try reinstalling it.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
05-07-2015, 02:03 PM | #4 | |
257
Rep 721
05-07-2015, 03:09 PM | #5 | |
1538
Rep 3,331
05-07-2015, 07:06 PM | #6 |
8937
Rep 2,010
Double-sided tape is your friend.
///M235i | Mineral Grey Metallic | Premium Package | Technology Package | Driver Assistance Package | Dakota Coral Red/Black Leather | Harman/Kardon Premium 360 watt sound system | 8-speed automatic
When writing your life's plan, use a pencil with an eraser |
05-07-2015, 07:43 PM | #7 |
115
Rep 418
05-08-2015, 08:36 AM | #8 | |
1538
Rep 3,331
My mount does have a slight amount of curvature outwards though. Not sure if it's from the car wash or what. I am thinking if I can remove it and bend it the opposite way (So it follows the curve of the bumper) that will help out. I also noticed when I first installed it with JUST the mount, it did not set off warnings, but it does with the plate installed because the plate sits 4-5mm outside the edges of the mount. I may just need to grab a pair of tin snips and cut the sides of the plate down. All things to do in my "Free time".
05-09-2015, 10:34 AM | #9 | |
115
Rep 418
<sigh!> |
05-09-2015, 06:35 PM | #10 | |
17
Rep 81
http://www.amazon.com/Bell-Automotive-22-1-46230-8-Adjustable-Mounting/dp/B0013HP98C I was eventually going to do a diy guide but just haven't had a chance, although if you Google you'll find existing diy guides for f30 vehicles. I ended up buying toggle bolts from home depot plus a couple of pieces to make it work. All in all it cost me about $30-$35 I believe. But in the end I mounted with no drilling and in the center (no side like a toe hook) and it doesn't affect any sensors. |
05-09-2015, 09:34 PM | #11 |
257
Rep 721
You really don't have the thing tightened properly then. I can yank on mine and it wont deflect more than 1-2mm before going exactly back to where it was.
