Boost/Tune/Power on demand (With press of a button)
02-05-2008, 11:19 AM | #1 |
28
Rep 276
Does anyone know if SSTT, V2, HELIX, JB, ETC ETC ETC offer a tune, boost, or power on demand (whatever you want to call it)???
I mean, car should be normal (Hence, same gas mileage) and then press a button and become power mode? I haven't seen it... |
02-05-2008, 11:23 AM | #2 |
26
Rep 865
Drives: 2018 F15 X5 xDrive35d
AA Xede does have such a switch (button switch).
02-05-2008, 11:26 AM | #3 |
134
Rep 3,132
AA: switch, Helix: switch, V2: user activation or lack there of at start-up (can't be changed until next startup, but can be programmed to stay on permanently without user activation).
2018 R35 GT-R Cicio800 | 2007 E92 335i - RB Turbos, TC Kline DA Coils, HPA M3 Suspension, Quaife LSD, Stoptech BBK, JB4, FuelIT, AR Downpipes, RDSport Quads, Stett OC, Helix IC, Volk TE-37, Vorsteiner V-35, OSS Headlights | Retired - 2015 F82 M4
02-05-2008, 11:28 AM | #6 |
grand poobah
254
Rep 2,253
02-05-2008, 11:30 AM | #7 |
Never Go Full Retard
182
Rep 1,851
Helix has the option, but you have to wire it yourself.
2008 335i
02-05-2008, 11:35 AM | #8 |
Modder Raider
755
Rep 8,633
Drives: M3
I don't believe that any tune has a "tune on the fly"
I was thinking that this tune would be great as far as driving stock when going to and from work, but switch it when wanted.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
02-05-2008, 01:08 PM | #9 |
50
Rep 1,600
Drives: e90 335i
BMS JB2R. Switch puts car in Race Gas Only tune, with switch off regular JB2 mode. But really there is no need to ever put the car in stock mode except when taking her in for service since none of the mods listed above have a significant affect on mileage, and all drive pretty close to stock as long as you stay off the boost.
02-05-2008, 01:10 PM | #10 |
218
Rep 4,726
Gas mileage will be the same as long as you don't floor it.
02-05-2008, 01:19 PM | #11 |
Rep 63
02-05-2008, 01:22 PM | #12 |
39
Rep 1,349
You could certainly implement this, but with adaptation going on by the computer it could be very CEL-prone. At minimum you wouldn't get max performance right after the switch. So, if at a light you wanted to flip your switch, don't expect the car to perform as well as it would 10 miles down the road. I think.
Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves. ~Albert Einstein
02-05-2008, 03:25 PM | #14 |
27
Rep 620
Drives: 2007 BMW 335i coupe 6MT
I don't know how people are getting better gas mileage. There was a noticeable change in mine....about 3mpg. I drive the car the exact same as I did before the Procede. And when you watch the instant fuel economy on the gauges, it is much more sensitive to throttle position and drops much quicker than it did when stock.
SOLD!!! :-(Space Gray Metallic - Coral Red - 6MT - Sport - AA Exhaust - UR Catted Coated DP's - Procede V3.1 PnP - Stett CAI - BMW Group SSK - M-Tech Sides/Rear- OEM Aero Lip - GP 8500K Angels - Vorsteiner Boot Lid - Miro M6 Reps |
02-05-2008, 06:41 PM | #15 |
Rep 132
there is no switch on the Dinan, but reportedly there is a difference in that you only get full boost when you depress the throttle over 50%
07 e90 335i Black Sapphire on Black Leather
ZSP/ZPP/CWP/Navi/Sirius/iPod/CA 20% tint/Blacklines/OEM spoiler/OEM style splitters |
02-05-2008, 06:51 PM | #16 | |
33
Rep 496
With the AA xede piggyback i had before the procede, i had installed a valet switch in the glovebox. Turning the chip from the stock map to the aggresive map could be done at a light and when driving. Im sure you wont be at maximum power, but at least 90% it was. My boost gauge stayed at 8-10 with the stock map and 14psi with the xede on. It is def. more convenient than with the way procede does it.
Manny : 2008 335xi sedan : SG, Terra, Alum, 6mt, SPP, PP, 162s Mods; Procede V4 | Remus Quads | UR catless dps | H&R coilovers | Modified CDV | Injen Intake | Spearco IC | Forge DVs | Defi Boost Gauge w/controller | Vorsteiner CF Hood + Front Lip | OEM M-tech Body kit | Hamann eyelids | Predator Ice Angels | 19" Volk Progressive Me's | Rotora BBK | 18" Rota Torques w/Blizzaks |
02-05-2008, 07:00 PM | #17 |
Moderator
133
Rep 6,775
Drives: TiAg E92 335
You could always control it with your right foot.
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
02-05-2008, 07:35 PM | #19 |
33
Rep 496
I dont think so...i still have the switch wired into the ecu compartment from the glovebox, but the procede does not have anything to connect to to control it. I wonder if shiv has someting for us interested to hook up to the procede and have the option to switch maps this way. Im sure the procede is capable of this since there is a way to switch to the valet with the rpms. Just have to implement this configuration to work with a switch instead. Shiv? anyhting?
02-05-2008, 08:14 PM | #20 |
80
Rep 1,283
Yeah I'm sure
all you need to do is wire in a switch...mine is hidden in the glovebox. However, with the Helix tune we have integrated TPS boost modulation where you get stock boost and mpg at lower throttle inputs then taper to higher boost at higher inputs. check out the attache thread and see what the local users have to say about this feature. Last edited by TurboBullett@Ambient Thermal Management; 02-05-2008 at 08:48 PM.. |
