04-29-2015, 06:55 PM | #1 |
341
Rep 1,184
LSD in every CPO car?
So i am looking at getting a 2014 M235i in the next couple months. Going through the BMW CPO part of the site I looked at many of the cars for sale. Every one I looked at had "limited slip differential" listed.
From what I understand this was an option, not on the base model. Is it possible that the BMW site is actually accurate and most 2014 M235i's out there have this? Or is this just marketing and when you call to confirm they tell you that its only in some? Prob the more expensive ones. Thanks! also is there any way to check options via a vehicle number or something or would you have to call and ask? |
04-29-2015, 07:29 PM | #2 |
17
Rep 63
Drives: M235i BSM
as far as i know they're not standard, it's a 2.8k option when I ordered mine earlier this year in February. Probably won't come standard unless it's the M2.
Try using this VIN decoder, seems to show all the details when I entered mine: http://www.bmwarchive.org/vin/bmw-vin-decoder.html |
04-29-2015, 07:31 PM | #3 | |
341
Rep 1,184
04-29-2015, 08:01 PM | #4 |
What goes here?
452
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
Probably just a bunch of dealers incorrectly assuming the car has a LSD, or, by default the system checks off that box because it is configured incorrectly.
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
04-29-2015, 09:02 PM | #5 |
1538
Rep 3,331
It's extremely unlikely that any of those cars have a mechanical LSD which is the $3000 M performance option that very few people opt for.
If it was showing up for every car I suspect it is just an error, or a strange way of them pointing out the car has an "electronic Limited Slip Differential"
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
04-29-2015, 09:17 PM | #6 | |
341
Rep 1,184
Am I right in that the f30 335i has an open dif? So is ELSD standard on the m235i where MLSD is the option? Or is ELSD an option and MLSD the "M" option? |
04-29-2015, 09:30 PM | #7 | |
10661
Rep 6,937
Drives: 2018 M2 AW DCT
04-29-2015, 11:57 PM | #8 |
43
Rep 147
Drives: 2015 M235i EBII Coral Red
Is there a definite way to tell if there's a mechanical LSD by looking under the car?
04-30-2015, 01:23 AM | #9 |
257
Rep 721
04-30-2015, 04:22 AM | #10 | |
310
Rep 886
Yes. Yes. No.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/BimmerTech amp, Enhanced BT
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi |
04-30-2015, 12:36 PM | #12 |
118
Rep 143
It's highly unlikely they're actually equipped with the M performance LSD. If I remember correctly, they weren't even available to be port installed until the '15 model came out
04-30-2015, 04:41 PM | #16 | |
1538
Rep 3,331
If you plan on tracking the car extensively, the MLSD is a better way of getting the power down and provides better and more predictible handling at the limit, especially if you're going to be sliding the car around. Without the LSD the car is still extremely capable, so I would not consider it a crutch in any way since the eLSD does a good job of helping to balance the torque when it needs to.
