04-27-2015, 09:17 AM | #1 |
262
Rep 1,091
Engine coolant temperatures (M235i EU spec)
After I set up both my Torque Pro and Dashcommand to check how fast the engine oil and water temps get into the "fully operational" value range, I'm actually somewhat worried with the coolant readings (the oil is OK). Namely, not only does the coolant temperature go up pretty quick (which is good), but it actually has the tendency to stay in a somewhat high territory...
I'm probably a little too obsessed with it (after having read the research thread on which cars do and which don't have the left-side aux radiator - mine is EU spec, so it doesn't have it) - but 115C during just cruising around in comfort mode seems a little high to me. How is yours?
previous: 2003 E46 330i SMG
just sold: 2013 F10 528i xDrive my AWD beater: 2015 Golf R mk7 DSG my RWD pirate & long-distance cruiser: 2015 M235i AT8, LSD |
04-27-2015, 10:25 AM | #2 | |
288
Rep 874
2018 F87 M2 | LBB | Executive | Moon Roof | Apple CarPlay [2018 F22 M240 (sold) ; 2015 F22 M235i (sold); 2006 E90 330i (sold); 1983 E30 Coupe 320i (sold)]
04-27-2015, 10:53 AM | #3 | |
1753
Rep 2,942
Personally, I don't think there's such a thing as TMI when it comes to monitoring operating temperatures on a performance car. At the very least, a coolant temp gauge (and digital speed indicator, natch) should be info display options along with fuel range, avg. speed, instant fuel consumption, etc.
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> |
04-27-2015, 04:16 PM | #4 | |
Little Deuce Coupe
391
Rep 635
Drives: SO M2C
ex: 2004 Thermonuclear Yellow RX-8|6MT
ex: 2015 Estoril Blue M235i |6MT|slicktop|MP exhaust - PCD 2020 Sunset Orange M2C|6MT|Black 788s |
04-28-2015, 01:40 AM | #5 |
262
Rep 1,091
Thanks for confirmation, Supernaut - I only hope that at higher speeds, when the radiator does its job, the temperature will slightly drop and stabilize. I also don't think the high temperature at cruising is in any way related to the lack of the (second) aux radiator - if it was so badly needed at cruising speeds, tracking this car would simply be impossible!
04-28-2015, 05:03 AM | #6 |
19
Rep 138
Engines these days are programed to change temperature depending on driving conditions to either optimize performance or efficiency. Usually they'll run hotter when cruising and will drop a few degrees when under load, like closer to the mid 90's ºC
04-28-2015, 09:36 AM | #7 | |
Little Deuce Coupe
391
Rep 635
Drives: SO M2C
108C/226F=Economy mode 104C/219F=Normal mode 95C/203F=High mode 90C/194F=High mode and control with characteristic map thermostat I also didn't realize the coolant pump is electric and can shut off for warmup and keep running after the engine is shut down. Here's the rationale for the higher temps with lighter loads:
04-28-2015, 09:46 AM | #8 |
262
Rep 1,091
Thanks for that info; I didn't have an opportunity yet to drive spiritedly with my Torque installation on. Will try it and report my temperature readings here for reference.
PS Indeed - in my F10 (which probably had a very similar water pump management system), I usually saw 95C on the motorway; never paid attention to it when cruising though...
just sold: 2013 F10 528i xDrive my AWD beater: 2015 Golf R mk7 DSG my RWD pirate & long-distance cruiser: 2015 M235i AT8, LSD Last edited by moldcad; 04-28-2015 at 09:59 AM.. |
05-09-2015, 06:46 AM | #9 |
262
Rep 1,091
Supernaut - your info is spot on! Yesterday I was on my way back home after a long (1,500 km) business trip, and - driving on a motorway when the clock went past the 2,000 km - I did the "what the heck" thing and floored the gas pedal
The speed of 250 km/h I kept for several seconds only (still too low a mileage), but - having my ODB2 transmitter in and DashCommand running - I saw 90 C of coolant temperature for the first time. Just to remind those who didn't follow this thread: seemingly defying logic, the coolant temperature can go as high as 115 C when just cruising - but with more load (and admittedly also air action on the radiator), it goes down to some 95 C in normal highway driving. When going extreme (like I did for the first time with this car), the coolant temperature drops by another ca 5 C. So - all seems to be fine (even without the left-side additional radiator)
05-09-2015, 08:34 AM | #10 | |
Little Deuce Coupe
391
Rep 635
Drives: SO M2C
05-01-2017, 04:54 AM | #11 |
44
Rep 51
Sorry to bring up an old thread. But my '15 M235i just showed up a CEL with the following codes U1408 and P0128. Car is running fine. I hooked up an OBDII reader, and it shows my coolant temp approx 220-228F while cursing in "comfort mode".
Is this normal? I looked at the temp guide, but not sure if that is reflecting coolant temp. I cleared the faults as suggested, to see if it comes back. At that point I guess I'll work on checking the sensors. After I cleared the codes, U1408 remained as a permanent manufacture defined code while the P0128 has been removed. Side note: is it normal to only have O2 sensor #2 show values and O2 sensor #1 not showing any? Last edited by SwolePatrol; 05-01-2017 at 05:26 AM.. |
05-01-2017, 07:29 AM | #12 |
3848
Rep 2,873
No such thing as TMI, but do yourself a favor and figure out what it is 'supposed to be' before you monitor it or get upset. I know I am constantly reminded of how different things are with these intelligent and overcompetent machines - i.e. for this, they have unused cooing ability that they can exploit as directed, rather than the old school sytems that were always just open or closed. And a rise in temp while going slower would be expected, even w/ the old school systems - at least now I don't have to keep the heater going full blast to try to keep it from overheating at a stoplight (that was the old version of the 'auxiliary radiator' c.1978).
05-01-2017, 08:48 AM | #13 |
44
Rep 51
I see what you are saying, but why would it throw a code if the temperatures are where they are supposed to be? It just doesn't make sense lol.
I'm hoping to attach screenshots of the codes when I get to the house, and hopefully this will help me get a clearer picture. |
05-02-2017, 04:24 AM | #14 |
377
Rep 596
Ive got Euro spec cooling and on track the oil temp for me never exceeds 116c in ambient temps of 12-15c. The 8AT however does touch 100c (usually not much above 85c with spirited road driving) by the end of a 20-25 minute session. Which is more concerning for wear rates. I believe the transmission does have a heat exchanger with the engine coolant (which also helps tranny warm up) though which would explain the high temp ceiling. If i was going to get additional cooling it would be prioritised for the transmission more than the engine.
