04-23-2015, 10:10 PM | #1 |
Car OCD
263
Rep 595
Drives: 2017 EBII F36 430d M Sport
Still no harness solution for the F30?
I am planning on occasionally taking my F30 to the track. It is not my main track car but would have fun stretching its legs once in a while. Therefore, and because it is my daily driver, I am not considering anything like a rollbar, bucket seats and 6 point harnesses.
Knowing the pro's and con's, I would happily go for a 4 point removable harness like the Schroth QuickFit Pro so that I could even use my HANS device. There does not seem to be anything available for the F3X yet. I think that in the past, E9X drivers were successfully using Mini R55 QuickFits. Is there anything similar we could do for the F3X? (I am aware of Schroth's warning that you will suffer a broken neck and decapitation when you do so). I am running out of ideas: I have already tried the CG-lock... that disintegrated, was uncomfortable and only holds the waist in place. I also tried the seatbelt inertial lock trick... but could not get it to work (not a good fit for me). I do not trust the cheap GForce $25 AutoX Torso Harness (or should I? Maybe it just ruptures in case of an accident instead of crushing your chest?). I searched the forums and could not find alternative options Thanks for any suggestion you may have
2017 BMW F36 430D M Sport Estoril Blue, 2002 E46 M3 Imola Red & 2006 Porsche Cayman S Artic Silver
More about my ride @ ATLBlue's 2014 F30 Journal. Instagram Inline6_ATL |
05-20-2015, 04:22 PM | #2 |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
I'm interested as well if anyone has any ideas...
Ahead of the curve for specF30
06-07-2015, 04:34 AM | #3 |
3220
Rep 6,218
You said you tried the belt lock trick. Did you do it properly?
06-14-2015, 09:17 PM | #4 | |
Car OCD
263
Rep 595
Last time I was at the track, I used a combination of this trick and the CG-lock. I took the opportunity to do a quick fitment test of a Schroth QuickFit Pro from an E92 and it seems to be OK for the F30. I know that Schroth is not going to make the product 'legal' for the F30 until they crashed enough of them, but the size, angles and position of the harness look the same. I'll give it a try soon.
06-25-2016, 06:36 PM | #5 | |
558
Rep 1,477
Drives: 335i
06-18-2018, 11:04 AM | #7 |
¯\_(ツ)_/¯
945
Rep 1,762
Bump... any harness options that work for our cars?
Tensioner/belt DIY | Side skirt extension DIY
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC |
08-19-2018, 12:03 AM | #8 |
1072
Rep 2,351
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
