04-23-2015, 11:38 AM | #1 |
119
Rep 623
BMW can't fix my car...
What kind of stupid shit is this?
The car never exhibited the things they are pointing out, all I got was the check engine light. Took it in and they cleared it, but in the process also wiped out all my custom changes I had made (5x blinker, no nav warning screen, no seat belt chime, etc). If this shit happens 2 more times before they can actually fix it, isn't there some lemon law that applies?
2014 BMW M235i 6MT
2012 Mercedes E350 Bluetec |
04-23-2015, 12:00 PM | #2 | |
310
Rep 886
We did one of the first lemon law returns in MA back about 30 years ago, when my wife's car continually set an engine overheat light, even though the engine wasn't overheating. Chevrolet took about 5 tries to fix it, then gave up, but they fought the lemon return as the car wasn't actually overheating. 6 weeks of spitting contests ensued before they finally took it back, accepting our argument that even though the car didn't have a problem, we couldn't reliably use it as we couldn't be sure it wasn't actually overheating at any point in time. In your case, I believe that an SES light is emissions related, which may give you a bit of a leg up in the argument. EDIT: Then again, you coded your car, changing BMW default software in the process. I'm not sure I'd mention the custom changes you made to the car's operating software. You may find yourself SOL on any warranty coverage as it looks to be a software fault and they'll certainly claim that you caused it. EDIT 2: You know, I realize it's veering into Black Helicopter territory, but if someone from BMWNA saw the post above, they could identify your car from the PUMA number in the picture and, if they wanted to be a pain about it, start sending "you kissed your warranty goodbye" letters. Interesting times.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/BimmerTech amp, Enhanced BT
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi Last edited by Zooks527; 04-23-2015 at 12:10 PM.. |
04-23-2015, 12:31 PM | #3 |
701
Rep 2,337
I agree with Edit 2... I wouldn't post stuff like that on here. It isn't out of the realm of possibility that it could come back to bite you in the ass.
04-23-2015, 04:19 PM | #4 |
1030
Rep 1,190
So it sounds like your check engine light is on because there's was a one time issue with the fuel level detection sensor reading. They cleared the light and found the sensor to be fine, and confirmed that there will be a permanent fix for the issue in an upcoming software update.
I don't understand what you're complaining about. It should be obvious that taking the car in for a CEL might result in your custom coding being erased. There should be no effect to the drivability of the car. As far as having the BMW Lemon Law the car over this issue? That's a bit extreme, especially considering you modified the software.
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
04-23-2015, 05:44 PM | #5 | |
360
Rep 1,797
Legal system Darwinism...
Previous Rides: 535xi, M235xi, X3, E92 M3, E70 X5 35d, X6 50i, X6 35i, E60 550i, E46 M3 Cabriolet, E39 540i, E36 328i
04-24-2015, 01:16 PM | #6 |
119
Rep 623
You guys are funny...what modified software? This is stock BMW stuff that can be turned on/off, it's nothing "custom".
2014 BMW M235i 6MT
04-24-2015, 01:22 PM | #7 |
197
Rep 2,802
04-24-2015, 01:25 PM | #8 | |
3074
Rep 5,577
More important I didn't realize you could nix the seatbelt chime through iDrive. |
04-24-2015, 01:25 PM | #9 |
701
Rep 2,337
If it's a toggle switch, button or iDrive setting, I'd agree. If it's something you configured using internally leaked, hacked software...... I mean, come on.
04-24-2015, 01:29 PM | #10 | ||
310
Rep 886
But, hey, you're right. What do we know? Give BMWNA a call (1-800-831-1117). Make sure you give them your VIN. Tell them you've been making coding changes within the ECU settings, and make sure they know you're disabling safety features (seatbelt chime and NAV warning). Ask them if you've voided your warranty for sensor and software faults. Quote:
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi |
04-24-2015, 01:35 PM | #11 | |
154
Rep 4,528
Drives: M2 CS
Very minor changes so I doubt BMW would go after the OP but I agree that I certainly wouldn't post about it if possibly going after lemon law |
04-24-2015, 01:43 PM | #12 | |
3074
Rep 5,577
To read the printout I don't see how you could fault the tech. |
04-24-2015, 02:28 PM | #13 |
310
Rep 886
Looking at the level the tech went to, I'd buy the guy a beer, and still be ahead with the cost of a full tank.
04-24-2015, 03:53 PM | #14 |
1030
Rep 1,190
Sorry man, maybe you were lead to believe something different, but "coding" is not authorized by BMW and can absolutely void your warranty if BMW decides to do so.
04-24-2015, 09:29 PM | #15 | |
1622
Rep 3,402
How did you program those custom settings? |
04-25-2015, 02:03 AM | #16 | |
119
Rep 623
Its like with car mods...an auto manufacturer would have to prove that the specific mod caused the failure and then they could only void that part of the warranty, not the warranty on your whole car...at least that's how I've understood it to work.
2014 BMW M235i 6MT
04-25-2015, 02:06 AM | #17 |
119
Rep 623
Like this: http://www.2addicts.com/forums/showthread.php?t=997749
And I have a OBDII Bluetooth dongle thing as well, so I assume I can probably clear the code if it comes back. I do have to say that the car feels world peppier for some reason, maybe it's in my head, but it feels great. Whatever software update they did was a good thing.
2014 BMW M235i 6MT
04-25-2015, 04:13 AM | #18 | |
310
Rep 886
But, look at the case you've presented. You're changing elements of the ECU. Granted, you're only turning some options on and off, but there are options in there that may require equipment you don't have (none of the ones you've listed fall into that category). The tech is coming back and saying he's seeing inconsistent readings between sensors read by the ECU. It wouldn't take much effort for BMW to claim that your setting selctions created an unvalidated configuration of the ECU, and that's why they're seeing sensor discrepancies. Will you still have a warranty on your turbos? Sure, but BMW could blow off any sensor related failures as your fault. Could you fight it? Probably. Could you fight it cost-effectively? Maybe not.
04-25-2015, 08:12 AM | #19 | |
1241
Rep 875
My dealer in Germany would be submitting a report to BMW about his coding. He would not be pleased with the feedback from Munich. |
04-25-2015, 04:24 PM | #20 |
90
Rep 351
stupid question....
if your car seems slugglish could that be a fuel pump issue? there was a recall for 2014 2ers. figured I'd bring it up. |
