M3 Subframe bushes - downsides?
04-23-2015, 10:12 AM | #1 |
622
Rep 3,198
Drives: E92 325i MSport Coupe
A question for those of you who've changed your E9X subframe bushes to M3. I get the improvement to the handling, but what I want to know is an honest opinion on the effects on NVH and ride quality. Preferably from someone who's only changed the subs, and not most of the entire suspension! Thanks guys.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
04-23-2015, 10:24 AM | #2 |
261
Rep 435
There are no real downsides, no extra noise or vibration. But the car will feel quite stiff in the rear compared to the front at first if you only do the bushings. The front needs to be balanced afterwards with the M3 front arms and an overall stiffer suspension (shocks at least) will complete the balance.
04-23-2015, 11:07 AM | #3 |
Rep 33
I agree, no noticeable increase in vibration or harshness, just a more solid feeling rear axle. Especially noticeable when hitting mid corner bumps where it doesn't feel like the body is stepping sideways over the suspension anymore. Only downside is the cost and PITA install.
'10 335xi, VTT stage 2, wagner I/C, ER oil cooler, PTF tuned, M3 rear arms & bushings, ecs trailing arms, ST S3 coilovers, Corsa exhaust
04-23-2015, 11:11 AM | #4 |
300
Rep 4,040
Drives: 130i coupé ;)
From what I read across all e8x e9x and M
If you have a a Diff lock down kit OR very stiff Diff bushes, then the wrong choice of Subframe Bushes will add to NVH noises etc. If you dont plan to run stiff Diff bushes you can get Alu/Derlin Subframe bushes with out any extra downsides, NVH will not be much of an issue
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff "The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is |
04-23-2015, 06:32 PM | #6 |
4276
Rep 9,209
04-24-2015, 07:22 AM | #7 |
Custom User Title
412
Rep 1,337
Only downside I figured was that they were not solid like Turners
04-24-2015, 08:35 AM | #8 |
102
Rep 1,903
Drives: e92 335i 6MT
No downsides, just do it!
04-24-2015, 11:10 AM | #12 |
Custom User Title
412
Rep 1,337
Solid aluminum bushings.
Yes, yes, your instinct is to say OH MY GAWD. SO NOISE. MUCH VIBRATION. But, I assure you. If you can handle run flat noise, these are nothing. I'd die before I go back. http://www.turnermotorsport.com/p-14...m-e82-e9x.aspx
04-24-2015, 01:29 PM | #13 | |
71
Rep 510
Kagan
'2018 F87 M2 LCI | LBB | GC Camber Plates | Ohlins R&T 90/190N/mm | 18x10 et33 square 275/35 | MPe | Poly Transmission Mounts | Recaro Sportster CS
04-24-2015, 01:35 PM | #14 | |
Custom User Title
412
Rep 1,337
It has stabilized the rear end to no belief. No wheel hop over bumps in the road. It seems to transfer more power as well, it could be all mental, but it feels like the car is transferring more power to the actual ground. You DO hear a whine (with the diff bushings I also upgraded to) I wish I did this mod before anything else, honestly.
04-24-2015, 02:43 PM | #15 | |
71
Rep 510
04-24-2015, 02:48 PM | #16 | |
Custom User Title
412
Rep 1,337
If you're going to do the sub, I'd suggest do the diff as well and get it all on lock down. I state again, you will hear a 'whine' but it's actually pretty cool. I enjoy it and in conjunction with any catless exhaust - it just sounds cool. I don't know how to explain it. It's almost like I feel more connected to the car in a way and often will drive with the radio off. I'm with you, M3's ive ridden in seem very soft and more towards enjoyable comfy driving rather than more aggressive responsive. I literally feel any pebble on the road, hell, when I drive over painted arrows now I can feel it in the rear end. It might drive some crazy, but I just like the driver feedback and responsiveness. If you do this, PLEASE follow up, would love to hear your thoughts and impression.
04-24-2015, 03:08 PM | #17 |
2032
Rep 8,339
For me the downside was they were too soft. I didn't want to go all the way to solid and subject my butt to feeling paint on the street, but I wanted more stiff to kill wheel hop. So I'm going to AKE black. Powerflex Black would be similar. Stiff as heck but still a lil give to kill NVH. Best of both worlds as far as I can see.
'08 e93 AW 335i 6MT,Vargas Stg 2+ 20T clipped,VRSF catless dps & 7"FMIC,ER chargepipe&Tial, MMP inlets&outlets,Motiv Stg 2 fuel rail&dual disc clutch/fly, JB4G5,MHD w/Motiv tune,Fuel-it Stg 3 LPFP,Wavetrac LSD w/lockdown, KwV2,M3(Strut brace,frt control arms,steering wheel)AKE blk sub bush,re11 245/305,19x8.5et30&19x11et43,SmartTop,RE trans mounts,Msport rear bump & skirts,15%tint,ZSP knob,Stoptech rotors,241k miles
04-24-2015, 04:57 PM | #18 | |
71
Rep 510
04-24-2015, 05:10 PM | #19 |
4276
Rep 9,209
04-24-2015, 05:17 PM | #20 | |
2032
Rep 8,339
coilovers check LSD with new bushings check good tires check good alignment check have to look at better rear toe arms lol
04-24-2015, 05:41 PM | #21 |
4276
Rep 9,209
yes, because under load the oem bushing twist which is affecting toe in/out causing the tire to lose its optimal contact area with the surface. Go with Megan or Manzo
http://www.e90post.com/forums/showthread.php?t=1075804 i'm sorry OP for Last edited by feuer; 04-24-2015 at 08:09 PM.. |
04-24-2015, 07:16 PM | #22 |
232
Rep 2,643
There is a slight difference when you first install them. They are rubber and take time to soften and break in. I experienced this in a E90 with M-sport suspension and no other mods, running on conventional tires. The M3 bushings will soften gradually over about 1,500 miles or so. Don't let that that make you worry. Its probably the best single mod you can do to the car.
