04-19-2015, 04:39 PM | #1 |
Rep 32
USB: Is there a playlist limit?
Not all the playlist are showing from my USB key, most works, but I am missing 3-4. All the newly added.
The key is 64Gb formatted in NTFS. Thanks |
04-20-2015, 04:51 PM | #2 |
Rep 32
Is there a way to force a refresh?
I wiped everything and just syned the 3 playlist that were not showing.. It worked great. Now added all the them and they don't show... just the 3 are still showed. |
04-21-2015, 08:11 AM | #3 |
Rep 24
Hi, I don't have an answer, but I have the same issue.
iDrive doesn't pick up all playlists on the drive... I have about 50 playlists I'd like to sync, but after finding and presenting 28 playlists, no more turn up. I even try deleting some of the ones that have been identified, in case there is some issue with full memory. These disappear, but no new ones appear. I am 100% certain that the playlists are "correct" in terms of path, \ version, etc., and I have tried exporting them using both Playlist Export and Doubletwist. Any ideas how to solve this? |
04-21-2015, 01:15 PM | #4 |
Rep 32
Formatted to FAT just in case.
Same issue. It just seem to be bad a scanning & don't seem to rescan & found no way to make it happen. I will play with the folder structure tonight but mine is pretty simple. |
04-21-2015, 07:48 PM | #5 |
Rep 32
Seems like iDrive just isn't good at refreshing it's cache or something is broken..
I have reformatted and re-sync my music without subfolder. Plugged it back in the car and got a bunch of errors. It could not find the previous structure and would not refresh or rescan either... Seems like the cache is based on the key name, as when I change the name it scan the content... Maybe if I make sure not to interrupt it it will find everything... Kinda a pain in the ass, might go back to bluetooth.. |
04-24-2015, 08:03 PM | #6 |
Rep 32
I deleted one playlist which was very large (100kb). Left it alone, eventually it seem they all showed up, but it took a good day. That's with 7000 songs for about 40Gb.
