BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Lowering: Requires camber kit or not?
      01-17-2006, 11:55 AM   #1
ksfrogman
ksfrogman's Avatar
570
Drives: E90 330i 6MT
2006 330i  [0.00]
2006 330i  [0.00]
I'm assuming that the suspension geometry of the e90 gives the vehicle more negative camber when lowered (springs alone or coilovers). Can the camber simply be readjusted within stock parameters or does an aftermarket camber kit need to be added?
      01-17-2006, 12:00 PM   #2
HRC
MAUI BUILT
HRC's Avatar
485
Drives: 2006 330i MT
2002 E46 325i  [0.00]
2012 E70 35i  [0.00]
I think the e90 has adjustments for camber, but I'm not sure. I don't think camber adjustment is needed for a minimal drop, but couldn't hurt !
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
      01-18-2006, 08:54 AM   #3
snook
Drives: e90m3, 2500hd, 95ltw
camber kits don't necessarily give back positive camber, they often use the centerline of the stock settings as their starting point. before you purchase, ask if the kit in question gives back positive camber
      01-22-2006, 04:07 PM   #4
db17k
Chicketeh china the chinese chicken, you have?
db17k's Avatar
34
Drives: 335ci hold out
2003 S2000  [0.00]
so what are our options here, i've had a bad experience with tire wear on a minimal drop before (1.1" drop on my RSX) I really want to get wheels and drop my E90 about 1.2" when i get it, but i never wanna deal with that uneven tire wear again! (brand new yokos only lasted about 19,000 miles because they wore on the inside)
A professional alignment shop could fix this problem right?
"In Soviet Russia car forks you!"
      02-12-2006, 07:15 PM   #5
db17k
db17k's Avatar
34
2003 S2000  [0.00]
Any camber solutions out there yet?
      02-12-2006, 10:26 PM   #6
ksfrogman
ksfrogman's Avatar
570
2006 330i  [0.00]
2006 330i  [0.00]
I was talking to Mava and he has the H&R race 2" drop on his car, and was able to have the camber adjusted adequetly.
I've decided not to drop my car for two main reasons. Although I love the look, I occasionally will scrape the curb ahead of me when parking. It won't get any better when lowered. When parked parallel to a curb, I don't need to worry as much about passengers opening the doors into the cement.
      02-12-2006, 11:52 PM   #7
db17k
db17k's Avatar
34
2003 S2000  [0.00]
thanks buddy, you do make a good point about the cons. i think i'd go sport, but not race. The H&R's look better than the eibachs IMO, but you know the streets in SF can get kinda rough too so it's a toss up.
      03-09-2006, 11:57 PM   #8
HRC
MAUI BUILT
HRC's Avatar
485
2012 E70 35i  [0.00]
I've been driving like the car is lowered out of habit even though I'm still looking at my springs(living room) and still waiting for shocks. There is one driveway that I used to scrape all the time, but since I have started drivng the e90, I don't. I know I will scrape again once the car is lowered unless I cut the entry/exit at 45 degrees. I also back in alot to avoid hitting the front against the parking stops.
Danny
      03-10-2006, 12:28 AM   #9
Ghunger
Ghunger's Avatar
52
Drives: 330i
Just thought I'd add that I believe Dinan has camber plates for the E90 They're set to add negative camber. They seem expensive though, but I've never bought camber plates before so I guess I wouldn't know.
330i Monaco Blue, Terra /w aluminum trim, SP, PP, CA, PDC, Nav, Folding Seats, Sat Prep
European Delivery Blog
Picture Gallery
      03-10-2006, 06:30 AM   #10
ksfrogman
ksfrogman's Avatar
570
2006 330i  [0.00]
2006 330i  [0.00]
I had camber plates installed on my 260Z. They were welded onto the tops of my strut towers and were easy to adjust in either direction.
      03-10-2006, 11:07 AM   #11
shragon
Moderator
shragon's Avatar
No_Country
497
Drives: BMW
my advice is to lower it first, and then get an alignment. from that point, see if you need a camber kit. if you doing mild lowering, with h&r sport or eibach pro-kit, i'm thinking you'll most likely not need a camber kit. this is my experience from my past bmw.
honda's on the other hand are a different story.
i'm also used to driving a lowered car. even though my e90 is not lowered yet, i still drive it like it is.
      03-12-2006, 05:49 AM   #12
lux.sh
missing two turbos.
lux.sh's Avatar
577
Drives: fast around corners.
lol. Somehow what you said made me laugh.
Myself too, coming from lowered vehicles.. I drive my E90 as if it was slammed.
Going extremely slow over bumps, trying to avoid every little dips/potholes on the highway, slowing down when going up/down the steep road, etc etc, all this which is unnecessary with current ZSP suspsnion. Pathetic human beings. They can't adjust to changes fast enough.
06 AW E90 330i ZPP/ZSP/Step/Expired Warranty
: Prior Design Front : ACS Rear : ACS Roof : BlackLines : Simota Intake : Carbon Fiber Interior Trim :
: MTEC V3 : 24% Charcoal : V1 Hardwired : Solaris Invisibulbs/LED interior :
      03-13-2006, 12:27 PM   #13
shragon
Moderator
shragon's Avatar
No_Country
497
Drives: BMW
hahaha. it's all in good practice. i'm planning on lowering the e90 anyways. remember to go into those driveways at an angle.
      03-13-2006, 01:38 PM   #14
dkizerian
Digital Ruler
Drives: 325i AW/Terra
This sounds like you just had a toe issue. Too much toe(in or out) will wear the inside edge of tires at a greatly accelerated rate, while too much negative camber will do very little to wear tires.
I'v had cars that I ran 2-3 degrees of camber on and had NO adverse tire wear on a car with properly set toe. I had a civic with a toe out issue and burned through a set of tires in about 7000 miles.
      03-26-2006, 10:44 AM   #15
chino1972
chino1972's Avatar
Drives: 325i SG
So can anyone answer whether or not cambers are required if you drop your car? There are so many people saying they lowered their cars but no mention of camber adjustments. I spoke with a BMW rep and he was not sure if the E90 came with adjustable cambers. I have had problems in the past with bad tire wear and don't want to make that same mistake. Has anyone actually worried about cambers or did they all just lower the car and pray for no premature tire wear. You would think this was the first time anyone lowered their cars or this would be answered already!
      03-26-2006, 11:01 AM   #16
ksfrogman
ksfrogman's Avatar
570
2006 330i  [0.00]
2006 330i  [0.00]
After I started this thread, it had become apparent that those who lowered their cars had had them aligned to readjust camber.
      03-26-2006, 12:08 PM   #17
HRC
MAUI BUILT
HRC's Avatar
485
2012 E70 35i  [0.00]
For Sport type springs with a minimal drop, camber kits are not required. For more agressive drops, they might be needed. Here are my specs after my alignment with H&R Sport Springs and Koni Shocks (if I had the race springs, I would've needed a camber kit):
Front Left:
Camber: -0.3"
Caster: 7.2"
Toe: 0.11"
SAI: 14.3
Included Angle: 14.0"
Front Right:
Camber: -0.7"
Caster: 7.2"
Toe: 0.11"
SAI: 14.4
Included Angle: 13.7"
Front:
Cross Camber: 0.4"
Cross Caster: 0.00"
Cross SAI: -0.1 Degree
Totall Toe: 0.22"
Rear Left:
Camber: -1.5"
Toe: 0.17"
Rear Right:
Camber: -1.6"
Toe: 0.17"
Rear:
Cross Camber: 0.1"
Total Toe: 0.34"
Thrust Angle: 0.00
The only thing that is not within factory specs is my front right camber, it's off by 0.1" from factory range which is 0.0 to -0.6.
Danny
      03-27-2006, 04:08 PM   #18
chino1972
chino1972's Avatar
Drives: 325i SG
Originally Posted by HRC
For Sport type springs with a minimal drop, camber kits are not required. Danny
Would this also apply for those non-sport packages as well?
      03-27-2006, 04:42 PM   #19
HRC
MAUI BUILT
HRC's Avatar
485
2012 E70 35i  [0.00]
I'm talking about H&R Sport springs or Eibach Pro-Kit springs not needing a camber kit compared to installing H&R Race or Eibach Sportline springs. It doesn't matter if your car has zsp or not.
Danny
      04-01-2006, 04:55 PM   #20
chino1972
chino1972's Avatar
Drives: 325i SG
So does anyone know if the non sport has the same type suspension in regards to zsp? I would think zsp has some upgrades but would that also include adjustable dampers or cambers? Lastly, has any non sport owners lowered their cars and only had alignment done to correct the problem ?
      04-01-2006, 07:29 PM   #21
HRC
MAUI BUILT
HRC's Avatar
485
2012 E70 35i  [0.00]
...So does anyone know if the non sport has the same type suspension in regards to zsp...
Umm...nope, different springs and shocks at the very least, could include bigger sway bars to, but neither the stock or zsp suspension has adjustable shocks. The both however how a range of camber adjustment for the rear. If you use H&R Sports or Eibach Pro-Kits, the stock adjustment range will correct too much negative camber. If you go with Race or Sportline springs, you may need a camber kit.
Danny
      04-02-2006, 05:02 PM   #22
db17k
db17k's Avatar
34
2003 S2000  [0.00]
Good stuff, i'll look out for that next time
