Widest possible rear size on e93 335i?
04-06-2015, 02:24 PM | #1 |
2032
Rep 8,339
What is the absolute widest rear tire I can get on my 335i e93 and on what 19" rim and offset? I have 19x9.5 with 275/30-19 Michelin Pilot Super Sports on rear now but would like more and I saw an e92 with 295/35-18 fitting. Hoping to upgrade to 295/30-19 rear and 245/35-19 front.
Thx.
'08 e93 AW 335i 6MT,Vargas Stg 2+ 20T clipped,VRSF catless dps & 7"FMIC,ER chargepipe&Tial, MMP inlets&outlets,Motiv Stg 2 fuel rail&dual disc clutch/fly, JB4G5,MHD w/Motiv tune,Fuel-it Stg 3 LPFP,Wavetrac LSD w/lockdown, KwV2,M3(Strut brace,frt control arms,steering wheel)AKE blk sub bush,re11 245/305,19x8.5et30&19x11et43,SmartTop,RE trans mounts,Msport rear bump & skirts,15%tint,ZSP knob,Stoptech rotors,241k miles
04-06-2015, 03:21 PM | #4 |
2032
Rep 8,339
Standard 335i e93. I need as much rubber as possible to hold the power I'm adding. I'm not against rolling the fenders. I'm also concerned I have 9.5 wide rims and the tires recommend 10-11inch if I go 295. Finally I was planning on lowering it 1/2"-1" more than stock sport suspension. Tires would raise the ride height 1/4". So net lower less than an inch in the rear, probably halff inch more lower in front than rear. This would be about 1/4" lower rear, 3/4" front. Hmmmmm
04-06-2015, 09:29 PM | #5 |
223
Rep 5,120
It can be done with a 10.5 or 11" wheel with a high offset. I'm not sure exactly how much room you have on the strut side but et40 or a little higher should work. You want it as close to the inside as possible.
I have 11" et28 with 275/30/19, fenders rolled and shaved near the bumper, -1.9 degrees camber. Here is what 11"et40 295/30/19 should look compared to that. http://www.willtheyfit.com/index.php...et2=40#content Last edited by bmw325i; 04-06-2015 at 09:34 PM.. |
04-06-2015, 09:42 PM | #6 |
432
Rep 1,602
04-06-2015, 10:56 PM | #7 | |
2032
Rep 8,339
04-06-2015, 11:34 PM | #8 | |
371
Rep 2,838
Drives: e92 335i, e34 525i & e60 530i
04-07-2015, 07:19 AM | #11 | |
2341
Rep 3,542
04-07-2015, 11:28 AM | #12 |
77
Rep 466
ROBC1976 has been running 305's for a long time and I think he was going with 315's. There is plenty of room if you have the right offset.
I'm running: Apex EC-7 wheels and PSS tires: 245/40-18 x 9 et 31 285/35-18 x 10 et 43 When my tires are due to be replaced, I am planning on going with 255/295. Since your car is a pre-lci, you should have another 8mm to play with than me. At your power level, I would go with the 305's. You should be able to fit them in with just a standard fender roll. |
04-07-2015, 06:14 PM | #13 |
223
Rep 5,120
Just enough to fit. When I got my wheels I was going for flush with as little stretch as possible for a tight fit. Now I want more stretch and poke but I'm going to wait until I need new tires.
I posted some pictures here. http://www.e90post.com/forums/showth...=996697&page=3 |
04-07-2015, 08:23 PM | #14 |
2032
Rep 8,339
Ok. Restating the parameters, 335i e93 vert with kwv2 coilovers, sport suspension, probably lowering front about 1/2", im trying to get biggest tires without rubbing. I'm willing to roll fenders if needed.
Shopping for wheels it's hard to find something affordable and that fits. I see TSW has wheels in 19x10.5 with 27mm offset for the rear. Looking at the Monaco in brushed silver with chrome lip. Fit this with 305/30-19 michelin pilot super sports would this be possible? Outer diameter is 26.3". If not 295/30-19? Outer diameter 26". In the front the rim could be either 19x8.5 with 35 mm offset or 19x9 with 15 mm offset. Front tires could be 255/35-19 outer diameter 26" or 245/35-19 with outer diameter 25.8". Again looking for widest possible rubber and wheel. Thx for your input. http://www.getyourwheels.com/view-wh...and-chrome-lip
04-08-2015, 10:03 AM | #15 | |
223
Rep 5,120
04-08-2015, 10:16 AM | #17 |
2032
Rep 8,339
Thx. Just hard to find wheels that I like, that have the right size and offset, and are in the budget.
04-08-2015, 10:18 AM | #18 |
2032
Rep 8,339
I already have the stickiest available that you can drive reasonably on a daily basis. And with approximately 625-650 rwhp and rwtq the extra rubber will be welcomed
04-08-2015, 11:16 AM | #19 | |
77
Rep 466
http://www.rimsntires.com/specspro.jsp This link will help you figure out what offset would work the best for your wheel/tire combination. |
04-08-2015, 11:18 AM | #20 | |
2032
Rep 8,339
04-08-2015, 03:31 PM | #21 |
223
Rep 5,120
Some good options here.
http://www.e90post.com/forums/showthread.php?t=935601 9.5 et30 and 10.5et40 would be a good choice. You might need front camberplates depending on how wide you want to go on the front. 245/35/19 should fit without camberplates. |
04-08-2015, 07:03 PM | #22 | |
141
Rep 989
Here are some extreme summer tires: http://www.tirerack.com/tires/types/extremeperf.jsp |
