Those with stock HiFi stereo/amp with add-on sub...
04-04-2015, 08:32 PM | #1 |
17
Rep 149
I just installed a sub and amp to my stock HiFi system using Technic's wiring harness and have a question about what bass setting to set on the EQ.
I feel like the bass setting set at 0 the underseat subs are a bit too loud and bottom out. I keep alternating between having the bass set at -3 to -5 so I'm not overworking the drivers or risk eventually blowing them with constant loud volume. What does everyone else have their EQ set at? |
04-04-2015, 08:55 PM | #2 |
223
Rep 5,120
How did you add a trunk sub using Technics hifi harness and you are still using the stock amp? It sounds like you have logic 7 and not hifi. If you are still using the stock amp they should be fine with bass at 0. You didn't change the amp for the underseats right?
04-04-2015, 08:57 PM | #3 |
17
Rep 149
I definitely have the hifi system. His harness has RCA outs and remote wire which I hooked up to an JL amp for the sub. Everything else is stock.
04-04-2015, 09:07 PM | #5 |
17
Rep 149
My VIN decode lists a hifi system and I bought the hifi harness from Technic last week...I'm using a JL amp to power a 12" sub, everything else including the stock amp in the trunk and underseat subs are all stock.
He even calls his hifi harness the "add-a-sub" harness. I'm really just interested in hearing what EQ settings people are using that add a sub in addition to their stock systems. Even without an additional sub, 0 bass EQ seems to cause a bit of bottoming out. |
04-04-2015, 09:39 PM | #6 |
1917
Rep 13,114
Stock amp sucks there is no way to keep up with a sub
Stock amp sucks there is no way to keep up with a sub(and sub amp)
You will just overwhelm the stock stereo with big bass. |
04-04-2015, 09:43 PM | #7 |
17
Rep 149
I know I'm not the only one on here with a stock stereo with a subwoofer added to it, as long as I have my gain adjusted properly I won't be overwhelming my stock stereo, I'll just be able to play lower frequencies.
04-05-2015, 01:40 AM | #8 | |
2306
Rep 13,010
I think that you are confusing yourself and others by mixing a HiFi system with an "EQ" setting.
There is no "EQ" in the HiFi system. It is either Bass or Treble adjustments. If you feel that the OEM woofers are "too loud" at Bass "0" then there must be something going on with the particular music that you are playing. Because no HiFi that I know of have "too loud" OEM woofers powered by the OEM amp at Bass level "0". None. I would be out of business if that would be true. Quote:
04-05-2015, 01:51 AM | #9 |
17
Rep 149
Ok yes bass/treble adjustment. And for the type of music that I listen to, electronic dance music on CDs burned from FLAC files, bass at 0 definitely sounds like the stock woofers are bottoming out, not saying its a good or deep bass by any means which is why I bought your harness and a sub obviously. When everything was stock, bass at -3 sounded best at louder volumes without me thinking I was going to blow something.
04-05-2015, 02:06 AM | #10 | |
2306
Rep 13,010
04-05-2015, 07:11 AM | #12 | |
2306
Rep 13,010
I had a customer complaining about the opposite of yours -lack of bass in a HK system. I mean, there was really no bass at all in his MP3 songs regardless of the settings in his iDrive. Maxing out the Bass and the 100Hz EQ band produced nothing. Then I removed his memory stick and plugged my reference iPod. I had to set his iDrive Bass and EQ back to the center because the bass was too much. The software that he was using to burn his Lossless files was set to filter out bass from the conversion somehow. He ended up buying a new Sony Walkman and using its software to play its music via the USB in the iDrive. Problem solved. Check your burning software settings. |
04-08-2015, 03:51 PM | #14 |
31
Rep 228
Dance music in general is pushed hard when mastered. Its sole purpose it to be played loud by a bunch of jerk offs who think overdriving at every gain stage, smashing it through a hard limiter and bottoming out a bunch of haggard ass club PA speakers sounds "good." Seriously though, they don't produce club music to be anything but loud, 95% of the digital files I got when I was still DJing regardless of the source type contained overs from the jump; lossless included...transcode them to mp3 and with quantization error it gets even worse. Its just the nature of the beast, the lower midbass especially is heavily compressed and the underseats cover too broad a pass band to handle this type of material. In your burning/transcoding software, if you have a subsonic filter option make sure you use it, it may help a little, but otherwise your only real options are to not listen as loud or upgrade your system. Just adding a sub doesn't really help because you still have no way to narrow the pass band of the underseats to relieve them some where the sub can fill in the gap.
