upgrade clutch for N54?
04-04-2015, 05:36 PM | #1 |
170
Rep 1,843
I swear at least twice I've felt my clutch slip under hard acceleration running Cobb Stage 1+ FMIC tune... is there an upgrade part available that isn't much more expensive than a stock replacement that won't be bad for daily driving?
I figure tuned + 100K miles + who knows how nice the PO was to it = might as well start planning for replacement... |
04-04-2015, 06:55 PM | #3 | |
432
Rep 1,602
Flywheel needs replaced too. Luk has a replacement you can score for about $500 if you shop around. Clutch will be $390 plus figure in another $100 for extra parts you will need. |
04-04-2015, 07:31 PM | #4 |
BimmerPost Supporting Vendor
24265
Rep 190,951
Spec clutches are the most popular
04-04-2015, 09:23 PM | #5 |
Rep 75
I just got my 335is clutch and new LUK flywheel installed today and it feels exactly like it did before . Very easy engagement and pedal effort . Gonna wait a couple of hundred miles before I start dumping e85 into the gas tank again . Life's been boring with no e85 lol
04-05-2015, 09:15 AM | #7 |
170
Rep 1,843
I understand the flywheel thing, would you replace with stock or an aftermarket single mass (and if so which one?)
If I do this myself I'll probably delete the CDV and I don't mind a *little* heavier feel - in fact I would like *more* feel, heavier or not, I judge engagement by pedal position, can't actually feel a thing through my foot. I just don't want anything like some of the hairier cars I've driven, that is, big old American V-8s with clutches that require me to brace myself with the steering wheel to physically push the pedal down. |
04-05-2015, 10:28 AM | #8 | |
533
Rep 2,872
I replaced my CDV with an M3 version which is the same as the modified ones being sold on the market. My pedal got lighter than it was before, but the engagement is much smoother now it feels. I can actually walk the clutch up normally. Last edited by 335NJ; 04-05-2015 at 10:42 AM.. |
04-05-2015, 02:04 PM | #9 |
261
Rep 1,093
I debated going SMFW and SPEC 2+ vs 335is and DMFW vs SPEC 2+ for DMFW for months. At the end of the day I couldn't find a good enough reason not to go with the 335is clutch and DMFW. Even the stock clutch is damn respectable. I'm at 110k and been tuned/e85 for 40K of that (even though its been slipping for 10k miles now lol). Got the flywheel off of eBay for $550 shipped and the 335is clutch kit, flywheel bolts, bellhousing bolts, rear main seal and D6 tranny fluid from ECS for $498 shipped.
04-05-2015, 06:50 PM | #10 |
432
Rep 1,602
That's because people have only recently (about a year or so) known about the 335is / 550i clutch upgrade.
IMO, unless going single turbo, there isn't a good reason to go with anything other than the 335is clutch. No SMFW gear rattle issues, the clutch is less expensive, far less likely to have issues with an OEM clutch, more stock feel while holding the power. |
04-06-2015, 09:15 PM | #11 |
Some dude
92
Rep 1,780
The feel of a worn-out clutch is completely eliminated with new OE parts. The is/550 clutch is my personal choice unless you really need the extra holding power for 500+lb-ft of torque. Also went with a new lightened-stock DMFW from Dinan, and it is the perfect balance between quicker revs and no trans rattle noise.
RRT
E92 335i/6MT with stuff and things |
04-07-2015, 08:30 AM | #12 | |
Rep 75
04-07-2015, 08:41 AM | #13 |
261
Rep 1,093
Organic (oem) clutches don't need nearly the break in of Kevlar clutches. I don't think the metallic side of the SPEC 2+ requires much break in but the Kevlar side probably requires the 500 miles. I'd still break in the oem for several hundred miles.
