03-23-2015, 10:38 AM | #1 |
839
Rep 2,363
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
Suspension Opinions
Hi All,
I have had my M235i now for almost 10 months and have had H and R lowering springs on it since about 1200 miles. Now at almost 15000 I'm struggling to remain content with the ride the springs provide. The springs are great for day to day, in look and comfort. But when I'm doing more aggressive driving I have found that the suspension is a bit too floaty and just not firm enough for me (I drive in sport+ 100% of the time, so the car is in its firmest suspension setting for the dampers as well). My question is, what might be the best setup to try next? I was considering BC coil overs. They seem to be the best bang for buck, my worry is that I have heard and seen many posts about issues resulting from the replacement of the stock dampers. Any experince with this? Can I do something to mitigate these issues? Any downsides? Another option would be Dinan springs and BMW Supplemental Ride Quality & Handling Kit from Dinan as well. From what I understand this would raise my ride height which I'm not really willing to do either... but I'm just looking for opinions. The other option i have been considering is getting hold of some sway bars, which i have contacted a few companies for that I have seen are in development but have not heard back from any of them. I want a ride thats firm without being uncomfortable. I want something i can throw into a corner and not feel like I'm floating as much as I am. I know I'm being a little picky here but I've already put a lot of work, time and money into my car and this is one of the main remaining problems areas so I would love some feedback, preferably from someone running one of these setups or who has driven different setups. Thanks in advance!
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
03-23-2015, 10:58 AM | #2 | |
451
Rep 845
I wanted a drop and a little more composure. I've heard differing opinions on the H&R -- some say great, others say just "ok." I did get them for $230 bucks though, so either way it was a screaming deal. I've done 10 days on the track with the stock suspension. I don't really feel the "floaty" you're talking about, but, to an extent suspension is subjective. I think a good idea for you might be the KW DDC plug n play kit. They're adaptive coilovers that are a dirct PNP into the M235i Adaptive Suspension system. I was considering these before I realized I had bigger fish to fry before I go that route (although some day, maybe). Check them out. Might be what you're looking for, and KW makes quality stuff. |
03-23-2015, 12:33 PM | #3 | |
839
Rep 2,363
UPDATE: Just emailed them, will see what they say.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 Last edited by abirmaher; 03-23-2015 at 12:44 PM.. |
03-23-2015, 12:47 PM | #4 | |
451
Rep 845
However, if this is one of those things digging into your brain (everybody has their thing), you might be persuaded... |
03-23-2015, 12:58 PM | #5 |
1777
Rep 4,515
OP,
BMW tend to have oem damping overdamped with stock springs and I think this may switch to sight underdamping when matched to H&R springs. Less noticeable when new but std dampers will wear quicker with shorter/stiffer springs and so now probably the underdamping is becoming more evident. I have H&R sport springs, quaife LSD and hartge sway bars on m135i for about last 6k miles. Its sticks the road like chewed gum on a fur coat. Ride is a tad firmer in comfort and then firmer still in sport/sport+ mode but still very useable on the street. As time has gone on, I think the adaptive dampers have adapted well to these springs especially as I feel springs have softened slighty with use. Have you played about with tyre pressures as a combo of lowered stance and low profile tyres makes the car sensitive to tyre pressures. I'm running cold pressures 36psi F and 39psi R and not experiencing any floatiness. Whilst I know the sway bars may add some resistance in pitch, yaw as well as roll, not sure this is your best solution. KW DDC is a great solution but comes at a cost. You might want to try some upgraded dampers ie Bilstein B8 for example first to retain your H&R springs. BP
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
03-23-2015, 01:03 PM | #6 | |
451
Rep 845
03-23-2015, 01:08 PM | #7 | |
839
Rep 2,363
Follow my builds:
03-23-2015, 01:54 PM | #8 |
1777
Rep 4,515
My cars chassis has been fettled by Birds BMW here in the UK.
I used H&R springs as I wanted to retain adaptive dampers for the time being as Birds had not yet developed their B1 spring/dampers yet. I got the B1 package # 1 as noted in the link below. http://www.birdsauto.com/tuning/sear...mi=M135i&pg=10 They do a B2 package #1 and # 2 for M235i http://www.birdsauto.com/tuning/sear...mi=M235i&pg=10 Heres 2 write ups about their B4 chassis package their do for 3/4 series, which includes sway bars http://www.pistonheads.com/news/ph-d...i-review/30963 http://www.birdsauto.com/editorial/e...tions-sep-2014
03-23-2015, 02:32 PM | #10 | |
839
Rep 2,363
Follow my builds:
03-23-2015, 02:32 PM | #11 | |
839
Rep 2,363
Is your car Manual? Did you get that clutch upgrade mentioned in the article? I'm super interested.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 Last edited by abirmaher; 03-23-2015 at 04:59 PM.. |
03-23-2015, 09:46 PM | #13 | |
839
Rep 2,363
Follow my builds:
03-23-2015, 10:28 PM | #14 |
127
Rep 765
After a day on the track this weekend, I think you may want to start small with sway bars. It was amazing how much they controlled the balance of my last A4 once installed. I do wish I experienced the sways before lowering my Audi, they made that much of a difference. I'm waiting for a few to be made for the M235 before upgrading sway bars.
On the track, the car is VERY sorted though, no floating. On the way home, it did feel a bit more floaty on the highway. So my take on this floating: the car was made for more aggressive driving but soft enough for DD. When the suspension is loaded (in corners, under braking, or heavy acceleration), the car hooked up very well - I never felt at a loss. Punching out of the last corner into a long straight, hard on the gas, she tucked down and tracked out very cleanly. Improving the sway bars will make loading up the suspension quicker in transitions. Can't wait to get some
"Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." MLK Jr.
03-24-2015, 12:34 AM | #15 | |
839
Rep 2,363
Follow my builds:
03-24-2015, 01:55 AM | #16 | |
451
Rep 845
I think a few bits and bobs here and there could help optimize it for track/street use, but generally it is a wonderful suspension to start with. If it was my money, I'd stick with springs and sway bars (which is what I intend to do). Those adaptive dampers are way too good to just pitch for some non-adaptive coilovers imo. |
03-24-2015, 04:35 AM | #17 | |
1777
Rep 4,515
YES
YES - I was a repeat customer so I got a deal that worked out QLSD + sways supplied and fitted for about same price as BMW MPLSD only supply and fit. Quote:
Also, my cars going back into Birds to have M3/M4 front lower control arms fitted - widens the front track slightly and adds more camber at the front, trying to save the softer outer shoulder on my 18" Mich PSS's !!!
03-24-2015, 04:39 AM | #18 | |
1777
Rep 4,515
03-24-2015, 04:43 AM | #19 |
1777
Rep 4,515
Sorry I keep making reference to UK based websites, but Litchfields are well respected outfit here in the UK. They have bilstein coilovers on their M235i demo car.
http://www.litchfieldimports.co.uk/BMW/M235i Its been getting some good press in the motoring media this side of the water, as an alternative to KW's
03-24-2015, 04:54 AM | #20 | |
1777
Rep 4,515
http://f30.bimmerpost.com/forums/sho...2&postcount=87
03-24-2015, 08:23 AM | #21 | ||
839
Rep 2,363
I won't be doing this for a few months through but when I get it done ill be sure to post reviews and opinions as well. Thanks for all your help!
Follow my builds:
03-24-2015, 09:34 AM | #22 |
31
Rep 199
The problem I'm seeing most of the time with many of the springs for these cars is they're designed for one thing. Looks. Look at the specs of the springs, if you can't find the spring rates, chances are they're only going to improve the looks. Sure it may "feel" like it handles better but in reality, I'd be surprised if it actually did.
Cheap coilovers are a great way to make you hate your car if you're daily driving it. I've played that game and once the "fun" wears off of "oooh new parts, car feels like a racecar!" and you have to spend hours on crappy roads with it, you'll very quickly regret it. If you can't do it right, save until you can. Bilstein/KW/etc all cost more because they're worth more. Most of my friends thought I was insane when I spent $3600 on AST coilovers for my last car. Until they rode in the car, then they understood. The car handled amazingly but also wasn't punishing to commute with. |
