New datalogs at 95%.....one good...one not so good
01-28-2008, 06:45 PM | #1 |
658
Rep 10,587
Went out tonight and did some runs to see what my boost was looking like. the car has felt great recently and 3rd and 4th gear just rip . the one thing I have noticed is that if I start in 3rd gear and floor it, there seems to be dip in power in the midrange in 3rd gear. If I start in 2nd gear 3rd gear feels strong the whole way. It made me curious.
I was able to capture the drop in boost in this datalog. The ambient temps were 28 degrees. Keep in mind I have never been able to get boost logs in the 14's like most people. I have a much larger intercooler than stock which is the most likely cause. SHIV - we need an intercooler map please You can see the dip in 3rd gear here....it actually went below 8psi! Thats lower than it will boost stock sometimes.....weird. I immediately turned around and ran 2nd thru 4th and the boost was good and stable. It hit 13psi in the beginning of 4th but dropped all the way back down by the end of 4th. Honestly the car feels great. I did dyno the car and on a dynojet it hit 350whp w V2, the intercooler, and forge DV....no other mods, and that was w/ no fan running into the intercooler.
01-28-2008, 08:42 PM | #2 |
Rep 122
If you want to feel better check out my last logs…
I’ve done logs two separate days in cold weather (~32F) with similar dips. I can’t imagine what the cold weather has to do with it but after seeing your log I think it might be worth some more cold vs.warm weather testing. Only time I ever had decent logs was when we had warm weather a couple weeks ago (~60F). By the way I’m completely stock except for V2, I always warm the car up before logging, and I have no reason to believe I have a boost leak other than these crazy dips in my logs. Anyone else have a similar problem? All of these pulls were full throttle 3rd gear. Sine wave or boost log?: Best one but still a dip: |
01-28-2008, 08:48 PM | #3 |
1740
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
There's always going to be a boost dip around 4000-4500rpm. This is caused by a valve timing phase shift at often occurs right here. Totally normal. And the colder it gets, the lower boost you will see. Especially during the first (of several) runs when intake temp readings are the lowest. It never really gets below 50F here so I can't speak from firsthand experience when temps drop to freezing levels.
shiv |
01-28-2008, 08:59 PM | #4 | |
658
Rep 10,587
01-28-2008, 09:01 PM | #5 | |
1740
Rep 17,960
Drives: A Lot
Shiv |
01-28-2008, 09:04 PM | #6 | |
658
Rep 10,587
so you think I could go to 96-98% in those ranges? I'm already at 95% on 93 octane.
01-28-2008, 09:10 PM | #8 |
441
Rep 18,331
Wow...To change the intercooler to make the engine cooler gets you better performance, but if temps outside is too, too cold, it takes away performance...that is totally a oxymoron!!
01-28-2008, 09:13 PM | #9 |
658
Rep 10,587
its not really taking away performance, I think its just allowing for more
01-28-2008, 09:30 PM | #11 | |
658
Rep 10,587
thats my understanding as well....as the ECU sees it, it can hit xpsi and make the horsepower. If the new intercooler is delivering a much cooler intake charge then the ECU decides that xpsi - 3 can do the same thing. Of course I'm making up the "3", but thats the logic that I'm seeing in it. Hopefully Shiv can shed some light on this for us mortals....and at the same time show me how to squeeze some more hp out of my car safely. It looks like a downpipe and intercooler map may be in order. If I'm already tuning up to 98% or so on 93 octane and still only seeing 14psi.......what am I going to do when I'm running 104 octane at the strip.....tune to 105%? Note - I'm going to need to wait until we have some 50-60 degree ambient temps before I can really see what the boost is doing. Unfortunately the road I test on is only really safe and deserted in the evening, which recently has meant 20-35 degree temps.
01-28-2008, 09:37 PM | #12 |
Team Zissou
3077
Rep 10,198
same here, this 15-30 degree weather at 2am probably isn't the greatest for tuning
i'm gunna be back out there tonight |
01-28-2008, 09:39 PM | #13 |
658
Rep 10,587
01-30-2008, 09:18 AM | #15 |
62
Rep 774
Drives: E90 335i & E60 550i
I have noticed the same thing since I upgraded to V2. With V1.4x I did not have this issue. I have a spearco intercooler installed.
Pure S2 Turbos | Vargas Outlets | RB Inlets | OEM SS Kit & Performance Steering Wheel| LCI Rear Conversion | Euro Xenons | RD Sport Quad Exhaust | Spearco Intercooler | Cobb V3 | MORR VS7 | KW V3 | H&R Sways | Mtech Bodykit | Vorsteiner CF Hood, CSL Trunk & Front Lip | Quaife LSD | Rotora BBK | GruppeM Intake | Forge UK DV | AR Design Catted DP's
01-30-2008, 10:04 AM | #16 |
658
Rep 10,587
my guess is that it has something to do with our larger intercoolers. Shiv recommended that I try bumping the tq values up in this range by 2-3%, but that would put me at 97-98% still running 93 octane. Im going to try it and see how it feels....listening reallllly closely for any knock.
01-30-2008, 10:10 PM | #17 | |
62
Rep 774
01-30-2008, 10:24 PM | #18 | |
658
Rep 10,587
could you post a few datalogs in this thread? What are you tq settings now? I'm at 95% across the board. If you are not at too high a psi at that settings could you try 95% as well so we can compare?
01-30-2008, 10:27 PM | #19 | |
Rep 122
01-30-2008, 10:42 PM | #20 | |
658
Rep 10,587
01-30-2008, 10:58 PM | #21 | |
62
Rep 774
I won't be able to datalog until this weekend.
