03-18-2015, 02:03 PM | #1 |
30
Rep 120
brake pop when reversing
There is a popping noise when I press the brake while in reverse. It's usually only one, noticeable noise coming from the front of the car (update: I think it's the rear). Only in Reverse and not in forward. Spoke with my SA and he says this is normal. Do I need to worry about this or is this normal?
03-18-2015, 02:25 PM | #2 |
8270
Rep 16,122
I'd be concerned. It probably indicates some wear or loosening. Most of your braking, and all of your breaking at speed, stresses the brake parts in one direction, so they'll wear/loosen accordingly. Braking in reverse could cause the parts to shift, causing the pop noise, whereas going forward again they just settle back to what's for them become normal.
03-18-2015, 03:03 PM | #4 |
2810
Rep 5,316
Drives: G80 M3 6MT
Isn't this something about something moving within the caliper when you do the initial slide back in reverse?
Funny I hear this on my buddy Igor's car last night when he backed up. Not you Igor_1080, other Igor, lol. EDIT: yay tagging isn't working again, so stupid.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com Last edited by smithf80; 03-18-2015 at 03:04 PM.. Reason: tagging never works |
03-18-2015, 03:25 PM | #5 | |
30
Rep 120
03-18-2015, 03:28 PM | #6 |
253
Rep 1,003
Drives: 16 340i, 15 X3d, 91 318i
It's normal. I can't describe the mechanism in detail from memory, but I do recall that there is a built-in "self-adjustment" of the handbrake that occurs when using the brakes in reverse. The noise, I think, is something like the slack being taken up. I could be wrong but I think every car makes a similar noise braking in reverse.
03-18-2015, 03:46 PM | #7 | |
299
Rep 693
Normally have my radio on when I am driving though, unless it was a decent sound I wouldn't hear it.
2018 M240i X-Drive | Sunset Orange Met
2015 328d X-Drive Touring M-Sport (Traded) 2015 Audi S4 Sepang Blue P+ | DSG | Tech Package | Adaptive Suspension | B&O 2015 Audi S3 Misano Red | 19" Sport pack w/Mag Ride | B&O 1983 Porsche 944 All stock |
03-18-2015, 03:47 PM | #8 | |
8270
Rep 16,122
03-18-2015, 05:34 PM | #10 |
8270
Rep 16,122
03-18-2015, 07:28 PM | #11 |
105
Rep 159
Drives: '15 328i (M) Wagon, '91 318is
M Sport brakes? I haven't heard it with mine *yet*, but it's been completely normal on my other cars equipped with 4 piston brembo calipers.
03-18-2015, 08:34 PM | #12 |
30
Rep 120
I have m-sport package, but not the m-sport brakes. Are the 4 piston brembo calipers regular non m-sport brakes? And when you say "completely normal," do you mean you do not hear the noise?
03-18-2015, 08:36 PM | #13 | |
30
Rep 120
03-18-2015, 08:37 PM | #14 |
1/2 Asian Sensation
217
Rep 397
Drives: 2011 BMW M3 e92 ZCP
I have had the M performance brakes about a month and I have heard them pop a few times. I was beginning to wonder myself if there was an issue.
All too easy...
03-19-2015, 12:25 PM | #18 |
105
Rep 159
When I said "completely normal", I meant that hearing the popping noise is "completely normal". The pads are slightly shifting on the retaining pins inside the calipers (brembo 4 piston calipers).
03-19-2015, 12:55 PM | #19 |
30
Rep 120
08-14-2018, 12:25 PM | #20 |
165
Rep 400
recently changed my brakes on the brembo 4 piston calipers, I am having the same issue, I was wondering if this has anything to do with the caliper springs/clip (did i install it upside down lol)
Should we grease the retaining pins? |
08-14-2018, 03:22 PM | #21 | |
OO=[][]=OO
262
Rep 337
Pad-shifting mechanics - completely normal. Here is what's happening p.s. using Brembo M-Brakes [THP+M Sport] - get the same sound every time [initial application though] brakes get applied after reverse. |
Poon Stick42.50 |
