Pre-LCI paddles shift to LCI Paddle Shift
03-16-2015, 05:01 PM | #1 |
34
Rep 130
Drives: 2015 M235i xDrive
Okay - I've searched the forums high and low and can't find a definitive answer on how to accomplish this. I first tried the paddles out of the box and they didn't work.
I then re-wired them as per this thread: http://www.e90post.com/forums/showpo...8&postcount=22 Well, the paddles still don't work. I'm at a loss as to what to do next. Any thoughts? Here are the paddles I purchased: http://www.ebay.com/itm/NEW-BMW-E90-...870980?vxp=mtr Any help is appreciated!
Current: 2015 M235i F22 BSM (FBO)
Current: 2015 X5 M Sport CBM (hers) Previous: 2008 335i E90 Tiag (FBO) |
03-17-2015, 01:19 PM | #2 |
34
Rep 130
Disregard. Ended up fixing it.
03-17-2015, 01:23 PM | #3 |
530
Rep 2,083
Please tell us how, in case someone in the future has the same issue.
2013 135is DCT Carbon Black Metallic |
03-27-2015, 07:45 AM | #5 |
34
Rep 130
My bad guys - I should have posted what I did. Here goes:
Assumptions: -Your car is a Pre-LCI and has installed the sport package steering wheel with the chrome push/pull paddle shifters. -Your multi-function buttons are stock (Pre-LCI). -The paddles shifters you are installing are from a LCI and are the pull type with left being downshift and right being upshift. -You are not trying to retrofit the M3 paddles as I believe they are a direct plug and play. To start out with, you will need to follow this guy's DIY on removing the resistors and shorting them. http://www.e90post.com/forums/showpo...8&postcount=22 After that, you need to move the ground wire on the new paddles (can't remember if it's pin 1 or 3 but you can reference your old paddles) to the middle pin. That is really it and it's quite easy to do. I have an extra set of paddles I can modify and sell if anyone is interested. PM me for questions.
teknic9098.50 |
