03-16-2015, 04:06 PM | #1 |
104
Rep 835
TWO cracked suspension pieces (Updated w/ PICS)
So I was on my way to work this morning when I started to notice a clanking sound coming from the passenger side front tire area. I had just hit a minor imperfection in the road, so I pulled over to see if there was any rim or tire damage. No damage was visible and I didn't hear any air leaking so I got back in the car and proceeded to the dealership a few miles away. When I got to the dealership I was told that this was the result of an impact and would not be covered under warranty. I can understand this logic despite how frustrating it is. I reluctantly agreed to pay the diagnostic fee ($225) so I could get the car taken care of ASAP. I took a cab to work and planned to return on my lunch hour to see the damage. Well, when I got back, more than 3 hours later, they had not had a chance to get the car on the lift. Because I knew it would not be covered under warranty, I told them to give me back the car and took it to my trusted indy guy. He got the car up on a lift right away and was able to determine that the bearing and plate that sits above the strut had been cracked ON BOTH SIDES (passenger/driver). The part is not outlandishly expensive and my guy does good work, but I'm a little concerned that I will run into this problem in another 12k miles. My mechanic suggested the 19" wheels with low profile tires may exacerbate the problem, but I know the car is offerred stock with 19s and even 20s so I don't buy that. So, while the decision to fix the car is an easy one, I'm looking for some advice as to how to go about it.
1)Do you think because it is on both sides that it could be the result of normal driving and thus a defect with the car? Has anyone else had an issue like this? 2) Could it actually have been caused by my new wheel setup (only 3k on it)? If so would you suggest getting rid of the wheels or swapping tires? Right now I have Hankook V12s 3) Do you think this is something that BMW can and should take care of? They never did a diagnostic so if the damage is on the opposite side of the described impact shouldn't it be covered by warranty? READERS DIGEST: Can I make BMW pay for the suspension damage and regardless, after the repair should I return to 18" wheels. UPDATE 3/17 So I returned to the pot hole today to take pictures. Unfortunately much of the gravel that was around yesterday had been eroded away by passing traffic. When I hit the hole it was slightly more covered with gravel and thus less severe. Either way it is not an abrupt hole and I saw many cars hit it squarely with no damage. I hit the edge of it with my front passenger wheel as I tried to avoid the rest of that mess. I'm going to try to get the repair done under warranty, but if not I think I have a good chance of eventually being reimbursed. I still can't understand the exact same damage to both sides. Also after further inspection there is an ever so slight bend on the inside of the wheel. Here are some pics of the hole:
2020 X3M Comp., Alpine White on Black/Beige
RETIRED: 2018 440xi GC, Carbon Black on Black/Blue 2014 M235i Black on Black, DINAN Stage 2 Last edited by mmmmm235i; 03-17-2015 at 06:19 PM.. |
03-16-2015, 04:58 PM | #2 |
137
Rep 627
I'd recommend putting the stock wheels and tires back on and try another dealership. Last thing you want is for them to warrant something and then retract it because you changed a key component
03-16-2015, 05:22 PM | #3 |
104
Rep 835
Thanks, I don't think this is a bad idea. Do you really think the setup could be the actual cause of the damage. They have only been on the car for a few thousand miles and the car is offerred with 19s. Thanks for the input.
RETIRED: 2018 440xi GC, Carbon Black on Black/Blue 2014 M235i Black on Black, DINAN Stage 2 |
03-16-2015, 05:54 PM | #4 | |
137
Rep 627
And no, I don't think it broke it necessarily.. But you know how they are, they'll say anything for you to pay out of pocket |
03-16-2015, 06:03 PM | #5 |
3074
Rep 5,577
Wow, how did the strut mount bearings get damaged?
I'd do think if your on 19's with 40psi and your hard on the brakes going over an abrupt defect, you can do damage but I'm surprised the top of the tower was damaged as described. Who installed the 19's and were there any alignment changes done? Last edited by overcoil; 03-16-2015 at 06:17 PM.. |
03-16-2015, 06:09 PM | #6 | |
115
Rep 581
03-16-2015, 06:39 PM | #7 | |
104
Rep 835
03-16-2015, 06:43 PM | #8 | |
104
Rep 835
The car was in an accident in which I was hit from behind while on the brakes and the wheels slightly turned. Do you think it is possible that this weakened or damaged theses components. I have probably put 3k on the car since I got it back from the accident. It just seems like if both sides are damaged this was not caused by an impact.
03-16-2015, 08:31 PM | #9 |
3074
Rep 5,577
mmmmm235i what work was done on the rear impact ? Just trying to get a feel for severity of hit.
I don't have the knowledge to know about the collision causing the strut damage, but I'm certain a SHOP FOREMAN at the BMW dealership could give you guidance ? |
03-16-2015, 08:50 PM | #10 | |
463
Rep 957
03-16-2015, 08:56 PM | #11 | |
267
Rep 554
I've had incidents that were "borderline" warranty issues with other cars and found that a straightforward, honest approach works best. Dealers have latitude on what they can warranty and the ability to fight for you with BMW should the need arise. Gain their respect and good things happen. It always has for me.
The Stable
2015 BMW M235i | 2014 Porsche Carrera S | 2017 Porsche Macan GTS | 1996 Porsche Carrera 4S |
03-16-2015, 09:11 PM | #12 |
104
Rep 835
The hit was pretty severe. I was hit at about 50mph right at the rear wheel. The quarter panel and control arm were completely destroyed. Given the severity of the impact I was surprised at how little damage was done. At least these cars are safe.
03-16-2015, 09:18 PM | #13 | |
104
Rep 835
Also for BMW to suggest that the wheels caused the problem when the car can be ordered with 19s is nonsense to me.
03-16-2015, 09:38 PM | #15 |
463
Rep 957
Was your car at auto-nation in Orlando?
03-16-2015, 09:43 PM | #16 |
104
Rep 835
The car was repaired at a BMW dealership collision center. Do you really think its possible that this is residual damage. I don't question your knowledge, I just do not have enough familiarity with cars and accidents to know if that is something that could happen.
03-16-2015, 09:45 PM | #17 |
104
Rep 835
No I live down in Miami.
03-17-2015, 11:06 AM | #19 |
Little Deuce Coupe
391
Rep 635
Drives: SO M2C
^^Agree. I would start here. I've never heard of anyone breaking the suspension like that from a small pothole. Seems like the wheels would have broken first.
ex: 2004 Thermonuclear Yellow RX-8|6MT
ex: 2015 Estoril Blue M235i |6MT|slicktop|MP exhaust - PCD 2020 Sunset Orange M2C|6MT|Black 788s |
03-17-2015, 03:36 PM | #20 |
51
Rep 269
I'm not an expert either, just seems like a lot of damage from a pot hole. Also, this close to getting the car back from collision repair, it seems plausible that it could be accident damage that they didn't see originally.
03-17-2015, 04:53 PM | #21 |
41
Rep 825
I live in Idaho and a co-worker bent a rim on a pot hole. He contacted a state department and they paid for his damage. They even paid for a front end alignment. If Idaho has this program I am sure other states have something similar.
2019 X3 M40i - Black Sapphire Metallic - Mocha Lather - 21" 718M wheels - Every option except Sun Shade
03-17-2015, 05:11 PM | #22 |
104
Rep 835
The cost of the repair is not worth going through insurance, otherwise I would. Thats what I said to the dealer, wouldn't the tire or wheel absorb the damage. The SA pretty much told me the suspension is designed to break before the wheel, which is when I told him to get my car I"m leaving
