Whistling noise from engine bay
03-12-2015, 08:43 PM | #1 |
Rep 2
Hi all,
I have this very annoying problem. Under acceleration around 2000 rpm, the car makes a whistling noise. This sound is loud on cold days and not so much on warm or have been driven for 30 mins or so. Also, I have to top off oil every 700-800 miles. Not sure if these are related or not. Spoke to the dealer and got the standard answer, its turbo spooling. Has someone experienced the same problem? Please help!! Its really annoying and have been struggling to find a fix for last 18 months. Its 2007 335i with close to 78k miles. thanks. |
03-13-2015, 04:25 AM | #2 |
28
Rep 321
As you have a turbo, this is the turbo PULLING air into the air intake, and is normal. HOWEVER, you may have a small boost leak somewhere. It is possible to get smoke bombs especially for this purpose to find out where the leak is. With the EGR blocked off (The last component before the Inlet manifold), a small smoke bomb is placed into the pipes, blocked off, and then external pressure applied, forcing the smoke out of any weak points. If you've had a Golf MkIV TDI, you'd have gone through this at least once in your car's lifetime.
If it's a whine, not a whistle, then I'd get your turbo looked at quickly. Actually, if you're going through oil that quickly, I would look at getting a look at your turbo. |
