03-11-2015, 08:41 PM | #1 |
Rep 29
Drives: 2013 328i xdrive
Heated steering wheel question?
A week ago, it was around -5 degrees here, I pressed the button on the side of the steering column for the heat and the dash showed "steering wheel heat active". After about 10 minutes or so I realized the wheel was still ice cold, I pressed the button a couple more times and each time the dash would display "....activated" then "...inactivated" with each press of the button, still no heat. I stopped to get gas, and looked at the button as I pressed it, the orange LED on the switch was never coming on even when the dash would say "active". This went on for a few days and I noticed the wheel not getting warm in the past, but never looked at the LED. I took a short video of this and sent it to the dealer, I made an appointment but when it warmed up here to about 35 degrees the heat and LED started working again, needless to say the dealer said they can't fix it if it's now working!!! Any body else had this scenario with the LED not lighting up, and what was the resolution? (I am so sick of intermittent issues with this car!)
03-15-2015, 11:26 AM | #2 |
Rep 29
No one else has had tis problem?
03-16-2015, 12:34 PM | #5 |
17
Rep 212
Mine don't have the dash message either but I think a software upgrade does that.
Not had issues yet with it not working properly and we've had -9 here. |
03-16-2015, 01:00 PM | #6 |
130
Rep 1,029
Drives: 2019 440xi Gran Coupe
Need software update from dealer to get the message. One of the new features you get with the latest update
03-16-2015, 06:52 PM | #8 | ||
2809
Rep 5,316
Drives: G80 M3 6MT
This notification was actually available two or three versions ago, so not only available with the "latest" update, technically.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
12-03-2019, 10:23 AM | #9 |
Rep 1
Apologies for necroing. But I appear to be having the same issue. Did anyone ever find a solution for this?
Press the button and I get the dash notification that its been toggled, but the LED doesn't come on sometimes, and no heat when the light isn't on. Seems like it stops working when it's coldest too. |
11-30-2020, 09:18 AM | #10 | |
Rep 46
When you push the button, it tells the steering column switch cluster module (that is located right behind the steering wheel, inside the steering wheel column, what the indicators are connected to) that you requested the heated wheel to be on, which tells the front electronics module that you turned on the heated steering wheel. This tells the instrument cluster to give the notification that the heated steering wheel has been activated. Then either the front electronics module or the steering column switch cluster module (couldn't figure out exactly which one) will tell the Electronic steering wheel module to turn on the heated steering wheel - sending power (PWM controlled with temperature sensor in the wheel) to the heating element. Reviewing the schematics, the Electronic steering wheel module has a constant power source going to it (the controller inside of it will modulate the power to the heating element). This comes directly from the steering column switch cluster module. So as long as your indicators are all working, the Electronic steering wheel module should be getting power. Hence, there shouldn't be any issues with it receiving 12V power. Mentioning this cause I saw some posts of people suggesting to check the fuse for the heated wheel. There is no individual fuse for this module. I'd recommend that you take the wheel apart, and check that the heating element is not broken. You can do this with a multi-meter and check for continuity on the heating element of the wheel. Then also check the temperature sensor to make sure that is OK. The temperature sensor is a resistive sensor (resistance of circuit changes with temperature). So you can check that by making sure that you can measure a resistance through it. There should be about 30 ohms of resistance. |
12-13-2020, 11:37 AM | #11 | |
178
Rep 274
The steering wheel electronics module is brand new and the other functions, such as the steering wheel controls, the paddles, and the lane departure vibration function so I do not think the issue is in the module. Looks like the steering wheel is no good?
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #578262 as a referral.
F10 535i M-Sport | Gone but not forgotten: G01 X3 xDrive30i M-Sport; F15 X5 xDrive35i; E70 X5 4.8i |
12-18-2020, 09:50 AM | #13 |
1303
Rep 1,626
Searching for a steering wheel heating issue, I thought I was about to resurrect a thread from 2015, but glad to see that it has been resurrected already last month.
This morning, after yesterday's heavy snowfall and some of the lowest temps we've seen of the season, my steering heating unit did not work for the first time in 8 years this morning. Thanks xxfinity for your post. I am going to check out that part. I wonder if it will start working again when its a little warmer like it did for OP (although this has never been an issue in prior winters)? BTW, both the led and the dashboard notification lit up when I pressed the button.
2020 M550i (G30) | Carbon Black/Black Nappa | DHP | DAP | Executive | Luxury Seating | Park Asst | Ceramic Controls | Front/Rear Heated Seats | 20" 668M wheels
2021 X3 (G02) | Dark Graphite Metallic/Cognac | Premium | DAP | Front/Rear Heated Seats Sold/Retired: 2012 328i (F30) |
12-20-2020, 05:38 PM | #14 |
Rep 29
Fixed mine by getting rid of the 3 series!
I never got any resolution to the problem along with numerous other electronic glitches with that 3 series. I had it back to my BMW Dealership 12 separate times for camera malfunctioning, collision warning malfunctioning and a bunch of other intermittent bugs. After a long year of ownership I traded it in.
12-20-2020, 09:56 PM | #15 |
1303
Rep 1,626
To update my previous post - as I suspected, the steering heater started working on its own on my evening commute home and it has been working fine since then. I guess it was just those one-off quirks that fix themselves...
12-21-2020, 04:37 AM | #16 |
135
Rep 457
It's possible this is a result of load shedding. A heated steering wheel is probably very low in priority for loads that need to be supported so it might be one of the first to be shed if the battery is too low/too cold to accept charge etc.
02-05-2021, 02:28 PM | #17 | |
Rep 46
Just a bit more details on my experience with this issue. After some troubleshooting, I believe the LED on the steering column is actually the feedback LED - when the heating element is actually ON it is ON. BMW don't actually include any details regarding the exact function of this button and the pre-conditions for its illumination unfortunately. I came to this conclusion because I was troubleshooting my wheel which had this problem. Luckily, I also had a spare wheel that I knew was working (don't ask me why I have 2 wheels... LOL). Both wheels checked out with respect to resistance and continuity measurements for the temperature sensor and heating element. However, with my original wheel, I got this issue. But when I replaced it with the known working wheel, the wheel heated up fine (the LED on the button remained on). While I was troubleshooting and took the broken wheel on and off, there were times where it did started to work (after a few removals and reinstallations). When it did work/heated, the LED on the button did light up. However, it stopped working soon after and the LED stopped lighting up. I suspect it is still likely the temperature sensor that failed. I guess I could find myself a 12V power supply and test to see if the heat element on the broken wheel is still working lol. I suspect it would... |
02-06-2021, 05:00 AM | #18 |
13
Rep 115
my cousin had this issue and it was solved by changing a setting on the climate control pane and then setting it back to normal using bimmercode. the ambient light setting was what he changed.
so i would use bimmercode or if you have esys try recoding the climate panel. this might seem weird but on his car i personally stripped back the steering wheel with him as well as the steering wheel button thinking something was wrong there and they were all fine. the light would show on like your but it wouldn't get warm. this solved it so assuming its one of those quirky problems |
