03-10-2015, 11:49 AM | #1 |
288
Rep 1,201
would like to recommend these guys if your after ACS springs on your XDrive Saloon, £495 all in. drives great just as straight as when it went in this morning. they had it done in 3 hours and dropped me in town while i waited. they let me keep old springs if i ever wanted to re use them. well worth the trip from manchester.
pics when ive finnished the modding + shes in bmw bodyshop tomorrow for new front bumper from when some tool drove into it at weekend in sainsburys. that is all |
03-10-2015, 01:47 PM | #2 |
8571
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
Good to know! Mine goes in there on friday to have my m Perf discs and pads fitted, new brake lines, spacers and new wheels.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
03-10-2015, 02:05 PM | #3 | |
288
Rep 1,201
03-10-2015, 02:16 PM | #4 |
8571
Rep 19,982
Me neither, not something I've done before, but a few others have done it and it does help to fill the arches a bit, so I figured why the hell not!
Also, I will add a stud conversion kit at same time and this has practical benefits when changing the wheels, so handy if you swap to winter tyres each year.
03-11-2015, 03:43 AM | #6 |
922
Rep 2,559
Look forward to seeing the pics after it's been done. Sam @ DT used to work in service @ BMW MK. One of the one people there who actually cared when I dealt with them.
03-11-2015, 03:44 AM | #7 |
1854
Rep 3,983
New wheels Terry - what you bought?
San Marino Blue M3 Competition Package with Carbon tat, ACS RS suspension, uprated brakes, 'modded' exhaust and a weeny bit more power courtesy of JF Automotive; M235i Convertible with ACS Sports Suspension; Disco 5 HSE Lux
03-11-2015, 03:59 AM | #8 |
8571
Rep 19,982
A set of the 442s from a coupe. Hoping it will make the most if the new brakes and differentiate from all the other EB coloured cars around!
03-11-2015, 04:01 AM | #9 |
1854
Rep 3,983
Oooh! Looking forward to seeing what it looks like! Any further along with your dampers investigations?
03-11-2015, 04:44 AM | #10 | |
8571
Rep 19,982
Will just wait to see where Birds development goes, or if Lorcan can do an irresistible deal!
03-11-2015, 05:09 AM | #11 | |
1854
Rep 3,983
Laugh about fact your MPG has dropped. Amusingly, since I changed my sound thingy over to M3 sound, my MPG has dropped considerably. Gone from 39mpg to 35mpg. Now on summers, I'm down to 33mpg!!! Thing is, if I was driving an M3 in that way, it would be struggling to hit 20mpg so won't complain!
03-11-2015, 12:55 PM | #12 |
86
Rep 630
What kind of brakes do you have? Standard or M Brakes?
M5 CP Alpine white
03-11-2015, 01:29 PM | #13 |
8571
Rep 19,982
The blue MSport ones. I'm fitting the M performance discs though, which are grooved and dimpled, and also changing the brake lines and fluid to a higher spec.
03-11-2015, 02:50 PM | #15 | |
86
Rep 630
Please see the attached from the german forum . Original-Bremsen Variante 1 / Modelle bis und mit 328i/330d (inklusive Allrad): Vorne Scheibe: 330x24mm (Millimeter) / Aluminium Bremssattel mit 1-Kolben Faustsattel (Kolbendurchmesser 57mm) Hinten Scheibe: 300x20mm / Gusseisen Bremssattel mit 1-Kolben Faustsattel (Kolbendurchmesser 42mm) Original-Bremsen Variante 2 / Modelle 335i, 335iX und 335dX: Vorne Scheibe: 340x30mm (Millimeter) / Aluminium Bremssattel mit 4 Kolben Festsattel (Kolbendurchmesser 40mm) Hinten Scheibe: 330x20mm / Gusseisen Bremssattel mit 1-Kolben Faustsattel (Kolbendurchmesser 42mm) Preisliste Option „S2NHA“ M Sportbremsen (blau lackierte Bremssättel): Das bestellen/montieren dieser Option ergibt: Vorne Scheibe: 370mm (Millimeter) / Bremssattel mit 4 Kolben (für die Modelle 328i, 335i, 325d, 330d, 335dX) Vorne Scheibe: 340mm / Bremssattel mit 4 Kolben (für die Modelle kleiner als 328i & 325d) Hinten Scheibe: 345mm / Bremssattel mit 2 Kolben (bei allen Modellen) (Die S2NHA Option M Sportbremsen, die man ab Werk bestellen kann, sind daher unterschiedlich. Die Sechszylinder-Modelle und 328i, 325d erhalten 370mm Scheibendurchmesser vorne. Alle anderen Modelle bekommen „nur“ 340mm Scheiben vorne.) Sportbremsscheiben: Für die Modelle mit original Bremsen mit 340mm Scheiben vorne (335i, 335iX, 335dX) kann man nachträglich original BMW angelochte und genutete Bremsscheiben kaufen. Vorne Scheibe: 340mm = Teilenummer 34 10 6 797 602 Für die Modelle mit Upgrade auf die S2NHA M Sportbremsen (blau gefärbte Bremssättel) kann man ebenfalls nachträglich original BMW angelochte und genutete Bremsscheiben kaufen. Vorne Scheibe: 370x30mm = Teilenummer 34 10 6 797 603 Modelle 328i, 335i, 325d, 330d, 335dX Oder Vorne Scheibe: 340x30mm = Teilenummer 34 10 6 797 602 Modelle kleiner als 328i & 325d Hinten Scheibe: 345x24mm = Teilenummer 34 20 6 797 600 Modelle 328i, 335i, 325d, 330d, 335d Hinten Scheibe: 345x24mm = Teilenummer 34 20 6 797 598 Modelle kleiner als 328i & 325d (Der Unterschied zwischen den beiden Artikeln weiss ich leider nicht) M Performance Power Kit (nur bei den Modellen 330d, 335dX): Erfordert installierte S2NHA M Sportbremsen in entsprechender Dimension 370x30, oder 18" M Performance Bremsen! 18“ M Performance Bremsen So und was ist das nun mit den "18“ M Performance Bremsen"? Diese ergeben für alle Fahrzeuge: Vorne angelochte und genutete Scheibe: 370x30mm (Millimeter) / Bremssattel mit 4 Kolben Hinten angelochte und genutete Scheibe: 345x24mm / Bremssattel mit 2 Kolben Sie sind verfügbar in den verschiedenen Bremssattel Farben: Gelb, Orange, Rot Das heisst für die Modelle 328i, 335i, 325d, 330d, 335dX: Grundsätzlich sind die 18“ M Performance Bremsen das gleiche, wie wenn man die Option 2NH M Sportbremsen und dann im Nachhinein vorne und hinten die angelochten und genuteten Scheiben montiert. Das heisst für die Modelle kleiner als 328i & 325d: Es ist ein viel größeres Upgrade. Da diese Modelle durch die 18“ M Performance Bremsen vorne 370x30mm Scheiben statt nur 340x30mm Bremsscheiben bekommen, welche sie durch die Option 2NH M Sportbremse für jene Modelle zu bekommen. Bei den Modellen 328i, 335i, 325d, 330d, 335dX könnte man ab Werk die Option 2NH M Sportbremse bestellen und diese nachträglich durch ummontieren auf die angelochten und genuteten Bremsscheiben zu einer vollwertigen 18“ M Performance Bremse hochrüsten. Man hat dann eben „nur“ blau lackierte Bremssättel, statt Gelb, Rot oder Orange. M Performance Power Kit (nur bei den Modellen 330d, 335dX): Erfordert installierte S2NHA M Sportbremsen in entsprechender Dimension 370x30, oder 18" M Performance Bremsen! Siehe Preisliste Seite 9 Gewichtsvergleich Vordere Bremsscheiben (pro Stück): 34 11 6 792 223 Standard Bremsscheibe 340x30mm (der Modelle 335i, 330d, 335dX) 10.2 Kilogramm (selbst gewogen von mir) 34 10 6 797 602 angelochte und genutete Bremsscheibe 340x30mm 10.03 Kilogramm 34 10 6 797 606 Standard Bremsscheibe bei S2NHA Option 370x30mm (S2NHA der Modelle 328i, 335i, 325d, 330d, 335dX) 16.50 Kilogramm (Angabe gemässe Teilekatalog. Vermutlich ist das ein Fehler. Rechnerisch dürfte das Mehrgewicht bei etwa 19% gegenüber der 340x30mm liegen. Somit bei zirka 11.95 Kilogramm) 34 10 6 797 603 angelochte und genutete Bremsscheibe 370x30mm (Nachträgliches Upgrade bei S2NHA für die Modelle 328i, 335i, 325d, 330d, 335dX oder Standard Bremsscheibe bei 18" M Perfomance Bremsen) 11.88 Kilogramm
M5 CP Alpine white
03-11-2015, 02:52 PM | #16 |
8571
Rep 19,982
As I know too...
Absolutely no idea what you're telling me though!
03-11-2015, 02:54 PM | #18 |
86
Rep 630
I will also order the M Perf. brakes from Germany (cheaper ). If I had more money for this I would go for this http://www.ebay.de/itm/Movit-Bremsan...item27f7de6037
6 piston , but only front kit costs 3000£ ... So will order the M Perf for 1400 front and rear
M5 CP Alpine white
03-11-2015, 02:56 PM | #19 | |
86
Rep 630
Oh sorry I speak german, it's not hard to understand check for the words and datas
M5 CP Alpine white
03-11-2015, 03:00 PM | #22 |
86
Rep 630
Disc size and name is the main point.
M5 CP Alpine white
