2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Steering Wheel Problem
      03-09-2015, 07:49 PM   #1
Stix
Stix's Avatar
Drives: 2021 X5M
I purchased my new 2015 M235i on 12/1/14 and after picking it up I noticed that the driving position seemed awkward. I lived with it for about a month and finally noticed the Steering Wheel was crooked (biased to the left).
While sitting in the car with both hands on the wheel, my left arm seemed to stretch out further than my right. After taking a few quick measurements, I confirmed that indeed the steering wheel was biased to the left.
I took it into the dealer and they confirmed it was crooked but there was nothing they could do. They said some are worse than others.
I checked various BMW forums but nothing has been discussed on this topic. With that in mind, has anyone experienced this - or - do you have any advice?
I absolutely love the car but I'm so focused on the wheel, it takes away from the driving experience. I want to purchase a performance exhaust and CF wing but not sure about adding money to this car if it can't be fixed.
      03-09-2015, 11:18 PM   #2
hoppy6698
hoppy6698's Avatar
127
Drives: M235i, Estoril Blue on Black
Never heard of it - maybe complain to BMW NA?
"Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." MLK Jr.
      03-10-2015, 12:41 AM   #3
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
Can't they just replace the steering wheel ?
      03-10-2015, 08:59 AM   #4
overcoil
3074
Drives: M235i 6spd
I'm not sure I understand, are you saying the steering wheel isn't symetric between it's right half and left half or the wheel is not in a perfect plane in relation to the seat back or instrument panel?
      03-10-2015, 09:40 AM   #5
Stix
Stix's Avatar
Drives: 2021 X5M
I wish they could. I believe it's related to the linkage somehow? The wheel feels perfectly round. - thanks.
      03-10-2015, 09:44 AM   #6
Stix
Stix's Avatar
Drives: 2021 X5M
Good point - The Wheel is not perfectly plane in relation to the instrument panel. So much so, that if you draw a straight line from center of the BMW insignia it hits me in the left shoulder vs. straight in the chest.
      03-10-2015, 10:01 AM   #7
2msport
204
Drives: '14 228 MT
Totally get it. Good picture easy to see. And yes that seems very odd! I can't believe they won't rectify it... I didn't know a car company could produce a car with a crooked wheel and say its okay. You'd think there would be stricter regulations. It's probably still very controllable but it's your sole source of control. I'd put up a fight
      03-10-2015, 11:17 AM   #8
overcoil
3074
Drives: M235i 6spd
Beside comparing to another 2-series, Google 'OFFSET STEERING WHEEL' actuslly very common
      03-10-2015, 11:47 AM   #9
Stix
Stix's Avatar
Drives: 2021 X5M
Thank you! I will check that out!
      03-10-2015, 12:09 PM   #10
pikcachu
pikcachu's Avatar
1399
wonder what happens if the airbag goes off... it might take your shoulder out
at least is not pointing down
      03-10-2015, 12:53 PM   #11
ciwhamc
12
Drives: M235i Alpine White
2014 BMW M235i  [0.00]
I bet that the bolt that hold the steering column to the dash support can be adjusted. All the columns that i have taken apart have some movement there for fine adjustment.
      03-10-2015, 01:02 PM   #12
Silvermike
Silvermike's Avatar
Trinidad_and_tobago
143
Drives: 2015 AW M220i 6MT
2015 M220  [9.50]
^ and even if there isnt an adjustment, shouldn't be hard for a machine shop make the bolt holes elongated to allow the adjustments.
When i saw this thread i went to check on my car. Im pretty much bang on straight.
      03-10-2015, 02:30 PM   #13
Stix
Stix's Avatar
Drives: 2021 X5M
Great Point! I will gladly sacrifice my shoulder!
      03-10-2015, 02:32 PM   #14
Stix
Stix's Avatar
Drives: 2021 X5M
Thank you for the illustration!! This is very interesting and I plan on showing this to the dealer.
      03-10-2015, 03:01 PM   #15
overcoil
3074
Drives: M235i 6spd
I don't think dealership will make any adjustment to the steering wheel beyond positioning the wheel on it's axis that may need to be done after an alignment or new steering wheel install - and usually with dealers they align the steering not by removing it but turn it to position brace it into position first then adjust the suspension to spec.
      03-17-2015, 07:31 PM   #16
Pparana
463
Drives: 2015 m235i
Just keep giving your dealer zeros on the service survey, I am sure they will solve it quick. Also find out when the regional service rep is in, he or she usually approves bigger work, they should take a look at it.
      01-25-2019, 01:40 PM   #17
Eddythepilot
Drives: Z4coupe3.0si
Hi Stix, i was wondering if you could have solved that steering wheel problem¿
2addicts
