03-09-2015, 04:00 PM | #1 |
152
Rep 706
Easy entry/exit coding
Anyone done this or know how to code it in?
If you look at this http://www.xcarlink.co.uk/product.ph...&cat=16&page=1 it says: ------------------------------ The BMW Easy Entry/Exit Interface is an add on modules which will upgrade your BMW with an all important feature which is not available as a factory option. (1) When the ignition it turned off the drivers seat will automatically move back allowing you to easily exit the vehicle (Memory position #1) (2) When you re-enter the vehicle and turn on the ignition the drivers seat automatically moves to the most comfortable driving position (Memory position #2) The exact seat positions required can be programmed by setting them using the normal procedure to position "1" (exist position) and "2" (driving position). This feature can easily be enabled and disabled via the iDrive controller. Compatibility BMW F32 (4 Series) - 2012 Onwards ------------------------------- So it connects to the can bus but something tells me this can be coded in surely? |
03-09-2015, 04:18 PM | #2 |
328
Rep 1,450
This would be nice. I miss this about my old g35. Both the seat and wheel moved to allow easy access and this was ten years ago. Let's hope someone cracks it and posts here.
11-29-2015, 07:05 AM | #3 |
523
Rep 1,105
Just in case you have arrived here using Google search, see the following thread:
http://f80.bimmerpost.com/forums/sho....php?t=1085553 |
audioMeth222.00 Bluesummer587.50 |
