Top Mount ST Question
03-09-2015, 03:46 AM | #1 |
15
Rep 315
For those that have experience with a top mount kit, what are the under hood temps like? Melting of wires, valve cover leaks, etc.? Are these show cars or can you make repeated pulls without setting the car on fire or damaging wires?
Thanks in advance. |
03-09-2015, 08:57 AM | #3 |
456
Rep 6,478
Depends. Mixed results, some kits seem to be fine, others absolutely have caused wire looms to melt, valve covers to melt, all sorts of fun stuff. FWIW i've seen the VM kit in person and it appeared to fit nicely, owner was able to get the engine cover back on (honestly easier said than done w a top mount).
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
03-09-2015, 05:25 PM | #5 |
265
Rep 1,392
I just got my headers back from getting ceramic coated. I'm also using the supplied turbo blanket, coating and wrapping the dp and also coating the WG tubes for no reason. First thought on my mind was performance second was heat management. I'll let know when I get it installed. This is with the vm kit. My bottom mount was fine just wrapped and the tubes came up to the valve cover. I even had a wire loom sitting on the header for a month before I found it. Zero damage sitting on the heat wrap
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust 335i 2009 e90 665RWHP VFF900 ST RIP . |
03-09-2015, 07:39 PM | #6 | |
15
Rep 315
03-09-2015, 09:02 PM | #7 | ||
265
Rep 1,392
03-11-2015, 01:26 PM | #9 |
265
Rep 1,392
Its already 85*F here. Ill hook my IGrill2 up and i can record and graph out the Delta between under hood and ambeint. Lol. I knew it would come in handy for other things than just cooking.
03-11-2015, 01:57 PM | #10 |
99
Rep 565
Drives: G20 M340i
^ lol
03-13-2015, 11:09 AM | #11 |
265
Rep 1,392
@Aerotest I have 3 temp probes and 1 ambient probe. I was thinking putting one temp probe on the plastic valve cover over cyl 2 and cyl5 and maybe the third near the intake? Or any other area of concern? The ambient will go in the cowl closest to the windshield wiper. This will be done on my fbo before the ST to compare to the ST when it gets installed
03-13-2015, 01:36 PM | #12 | |
15
Rep 315
