FS: OEM M3 Black Novillo leather front seats with heat/lumbar/powered
03-07-2015, 11:15 PM | #1 |
325
Rep 5,370
OEM M3 Black Novillo leather front seats only with heat/lumbar/powered - $1000. No door panels or rear seats. Seats are located in Little Neck, NY 11362 If you have AHR you can code out the error Using NCS Expert ABG module AKS_LINKS_1_CD aktiv (Make this nicht_aktiv, this is the left side active head restraint.) AKS_RECHTS_1_CD aktiv (Make this nicht_aktiv, this is the right side active head restraint.) More pics 4/6/15 Last edited by Ph0zenstone; 04-09-2015 at 08:14 AM.. |
03-08-2015, 08:23 PM | #2 |
Rep 67
What year?
2011 335D M-Sport: Nav, Cold Weather, Harmon Kardon L7 Premium. Mods: Full M3 Interior & M3 Rear Spoiler, JBD Tuner, Carbon Fiber Front Lip Splitters, LED Angel Eyes, K&N Filter, LED Interior Lights, Carbon Fiber Door Handle & Key Entry Accents.
03-08-2015, 10:22 PM | #3 |
325
Rep 5,370
Unsure if 2009 or 2008...but its without active headrests. If you have AHR you can code out the error
Using NCS Expert ABG module AKS_LINKS_1_CD aktiv (Make this nicht_aktiv, this is the left side active head restraint.) AKS_RECHTS_1_CD aktiv (Make this nicht_aktiv, this is the right side active head restraint.) Last edited by Ph0zenstone; 03-08-2015 at 10:41 PM.. |
03-09-2015, 07:22 AM | #5 |
325
Rep 5,370
unfortunately I rather not ship due to the size/weight. Not even sure how I would wrap them. If you want to arrange for a courier to pick it up and take care of everything then I would ship...otherwise prefer local pickup
03-16-2015, 09:44 PM | #10 |
325
Rep 5,370
03-31-2015, 09:24 AM | #14 |
Rep 46
I am interested in these seats...I'm about 3 hours away from you in NY. Will these work for sure in an e90? I have a 2007 335xi that has non-sport heated seats. Will these seats plug an play into mine? Will they cause any errors?
Thank you! |
03-31-2015, 10:20 AM | #15 |
13
Rep 245
Iirc when I was doing research I noted that the lower mount for the seat belt on the e90 is on the seat itself, whereas for the e92 its on the bottom of the b pillar
Seller, maybe you can pop off the panel at the end of the seat to check if it still has a mounting point for the belt.... |
03-31-2015, 06:05 PM | #16 | |
325
Rep 5,370
These can fit on your e90 no problem. No coding is necessary so no errors. |
03-31-2015, 06:07 PM | #17 | |
325
Rep 5,370
It's vice versa.. E90 has it mounted on the car while e92 seat belt receptacle is attached to the seat. My seat doesn't come with the seat belt anyway so you'd just reuse the e90 belt anyway |
04-05-2015, 10:29 PM | #19 | |
13
Rep 245
on the coupes, the lower mount is on the bottom of the b pillar, on the car itself and not on the seat..... |
04-05-2015, 11:52 PM | #20 |
325
Rep 5,370
ah i'll take a pic tomorrow to see. Pretty sure there is a slot for a mouting point there but i'll double check and take a pic tomorrow
This isn't my pic but rather a pic from google which shows that removable panel where the bolt is. Pic is of a E92 M3 seat |
04-06-2015, 12:32 AM | #21 |
123
Rep 852
How differently does Black Novillo looks from Black Dakota leather?
Let's say if I have Novillo fronts, but backs and door panels in Dakota, will it be noticeably different?
"Let me see what I can do... sir"
04-06-2015, 06:36 AM | #22 | |
325
Rep 5,370
They blend in pretty well. I ran just fronts for a few months before putting in the backseats and no one could tell. |
