03-05-2015, 03:31 PM | #1 |
11
Rep 111
water get into door speakers causing hiss noise
Has anyone experienced that water leaks into door speakers which causing hiss sound.
My rear door speaker started making hiss noise. I took the door pannel out to check. Just by chance it was right after I washed the car. There were some water in there. My speaker was wet and so are the connectors. The hiss sound went away after it was dried out. Just 2 days later hiss sound has returned! I would really hate if I had to replace this rainbow speaker It sounds very very good. Does anyone know how to remediate this problem? |
03-05-2015, 03:42 PM | #2 | |
2288
Rep 13,001
03-05-2015, 07:22 PM | #3 |
2006 TIME Person Of The Year
9720
Rep 6,445
If the speaker is getting wet you need to fix that even if it isn't causing the hiss.
03-05-2015, 07:49 PM | #4 |
2288
Rep 13,001
03-05-2015, 07:53 PM | #5 |
9720
Rep 6,445
I would take measures to protect the speaker from getting wet if I wanted confidence that the driver would last more than a couple years. It isn't like it requires building a fiberglass enclosure! Just make a little hood (out of Dynamat?) to shield the moving parts (and connections) from getting wet.
03-06-2015, 06:17 AM | #6 |
11
Rep 111
Thanks for your suggestions. I will need a weekend to remove all the panels and make the insulation! I think the speakers have some degree of water resistance,hopefully it will withstand some water.
Funny enough! I just found out that the rubber list on the door window is not tightly attached to the list on the door!! Man, this is f... disgrace for being a premium German car!! Any of you can check if your lists are properly attached.It looks like the list is too short causing some water leaks into the door chamber |
03-06-2015, 08:46 AM | #7 | |
2288
Rep 13,001
All aftermarket speakers have their wire connectors under the frame. And in the F30 that means that they will be exposed to water. |
03-06-2015, 10:10 AM | #8 | ||
9720
Rep 6,445
