Car repaired after Deer hit - Now 30FF
03-03-2015, 11:16 AM | #1 |
217
Rep 1,909
body shop worked on front passenger fender, headlight, mirror and bumper, but now I'm getting 30FF & max boost is 10 PSI on map5 (used to be 17) ... JB4 tries to clear it but when in map 0 I get it almost instantly... I've gone underneath and checked all FMIC connections, forge DVs etc... everything looks good, vaccum lines were replaced last year too... now I'm scratching my head, I really dont want to do that laborious boost leak test, any ideas ?
Mods: 7" VRSF FMIC, Forge DVs, RB PCV, BMS Oil Cooler, VRSF DPs, MHD, JB4g5, OFT DIYs: Walnut blasting : Trans Oil at 45k, w Filter at 65k : Diff Oil Flush @ 45k : WP&TS @ 69k : Alternator @ 79k --- E70d Alphabet Soup del 44.4k : JR Stg2.25 tune : Buzzken Catted Exhaust : Trans fluid drain/ fill (3 Qrts), both Diffs fluids flushed Wheels: Style 95s on PSSs (Sold): AG 359s on S04s : 162s on Blizzaks : Rohana RF1 Matt black
03-03-2015, 11:22 AM | #2 |
GoofBall
50
Rep 1,055
When I hit a deer there were 2 things that didnt get fixed properly. I also hit passenger side, as well it took forever. I hope you didnt have an auto transmission.
1) the hot pipe from the turbos to the inter-cooler, the rubber flex piece had a slit in it. I only found it after a lot of testing and moving things around. As its compressed it hid itself well. 2) the vac lines that go over the head one of those had a leak. Had to replace that hose as well, it goes from the vac pump to one of the top of the vac canisters. Those were my 2 leaks. If you are getting to 10 pounds this is where I would start more than the hot pipe. |
03-03-2015, 11:37 AM | #3 | |
217
Rep 1,909
03-03-2015, 04:22 PM | #4 |
38
Rep 208
I would say check the bottom nipples and vacuum lines at the bottom of the canisters. would be pretty easy to tell if its damaged and causes 30FF.
AW E92 M3 DCT /// |
