Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > adjust front wastegate rattle
      02-27-2015, 10:36 PM   #1
rpa440
Drives: E92
Thefront wastegate is petty inacessible somebody adjust it without removing entire turbo ?
      02-28-2015, 09:23 AM   #2
messar
Drives: 2008 E93
I can't claim credit for this - someone posted how to do this at one point.
You can adjust the front wastegate by moving the actuator with shims. I took out the fan, and the air pipe that runs across the front of the engine (sorry, don't know the correct name for the part).
You loosen the 3 bolts, and you can use spacers - I made mine taking washers and cutting out a section to make a C shape, since putting a washer there is a huge pain. I ended up stacking the spacers (superglue to each other) one at a time until I could feel a bit of drag on the wastegate under vacuum. (I don't think you can do this properly without removing the downpipes to actually feel the wastegate itself). In my car, I ended up moving the actuator about 1/4 inch.
Since you are in there, good time to replace the vacuuum line to the actuator as well.
matt
      02-28-2015, 09:29 AM   #3
Opo
30
Drives: 07 335i E92 6MT (12/06 build)
It is possible, but it is an absolute pain in the ass. And you really should have your down pipes off in order to adjust it properly.
see this thread:
http://www.e90post.com/forums/showth...just+wastegate
      02-28-2015, 09:39 AM   #4
boost junkie
16
Drives: e93
Take your downpipes off and wiggle the wastegate flapper. You'll understand why it rattles and there isn't a whole lot you can do about it. My car is a 2010 with 30k miles and the wastegate flappers seem like they are about to fall off. They are just shitty.
      02-28-2015, 10:05 AM   #5
Opo
30
This is 100% true, they are a shit design. But adjusting them can help eliminate rattle.
When I first bought my e92 it sounded like a bag of recycling so I adjusted them and it is astronomically less now, of course still rattles a bit though.
