Now that we have the power potential what's next...?
02-26-2015, 08:05 PM | #1 |
135
Rep 1,075
I'm referring to the turbo options we have that are capable of 600+ tq/hp... My question is: What other supporting mods need to be done to get us there, support that power safely and make the best use of this new power?
These are some of my thoughts but I'm sure there are many more... - LSD - oil cooler - upgraded lpfp - larger inlets for twin turbos - upgraded axles - hpfp assistance - upgraded driveshaft - upgraded tranny - 3.5 bar sensor |
02-26-2015, 08:44 PM | #3 |
DIYER
614
Rep 5,521
Everything but driveshaft imho. I would get the upgraded quibo instead.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
02-26-2015, 08:59 PM | #4 | |
135
Rep 1,075
Look what happen to this poor guy... http://www.e90post.com/forums/showthread.php?t=799428 Unfortunately he had to replace the driveshaft and LSD... It's expensive but it does more than just transfer the increased power... It eliminates the hesitation/slingshot effect produced by the factory design... |
02-26-2015, 09:07 PM | #5 | |
DIYER
614
Rep 5,521
02-26-2015, 10:25 PM | #6 | |
ex deus machina
124
Rep 968
- oil cooler: unless you track your car not needed - upgraded lpfp: unless you plan to use Ethanol, not needed - larger inlets for twin turbos: this is almost a requirement for Super RB;s and VVT stage 2+ - upgraded axles: good idea but I would wait until they break. - hpfp assistance: not needed unless you plan to run ethanol - upgraded driveshaft : remains to be seen - upgraded tranny: if Auto don’t do a WOT shift from 5th to 6th, and you will be ok, if MT get SMFW - 3.5 bar sensor: mandatory if running 21psi or more, which in this case most likely.
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK Gone: E92 335i N54 468rwtq |
02-26-2015, 10:31 PM | #7 | ||
135
Rep 1,075
02-26-2015, 10:38 PM | #8 | |
DIYER
614
Rep 5,521
