Not the same...
02-26-2015, 09:37 AM | #1 |
23
Rep 234
Not the same...
Ok, so I recently had a walnut blast done by my local shop, while also replacing the spark plugs, and when I picked up my car and drove it home, it felt like a million bucks! The throttle response was amazing, and there was almost no turbo lag whatsoever. To be completely honest, it didn't even feel like I was driving my car.
Well, all good things come to an end, and one morning, on my way to work, some jagoff decided to cut me off on I-95 and box me in between two 18-wheelers. I began to panic as I felt claustrophobic as the semi's swerved in and out of their lanes, but as soon as I saw an opening, I went for it. I was in fourth gear, dropped it into third, and pinned it to safety as I gave the "look" to the d-bag driver who cut me off. I was so caught up in the moment, I forgot to shift, and over-revved in third gear until my CEL came on and my car went into limp mode. I immediately pulled over to the shoulder and shut the car off. Upon popping the hood and inspecting the engine bay, and everything appeared to be fine. There was no smoke or any loose hoses/belts that I could see. I turned the car back on, and all was good again. No lights, no noises, no problems.. right? Wrong. Since that day, my car has not driven the same. There is tons of lag, poor throttle response, and what appears to be a vibration throughout the car at WOT. My boost gauge reads 14lbs, but there does not seem to be power like there was before this happened. I took my car to my shop to run a diagnostic, but the only thing they found was a fouled oil temp sensor. They replaced it for me, but the car still drives like crap and just doesn't feel right. They told me there are no codes being thrown, and everything appears to be fine, but I am convinced otherwise. Does anyone have any idea what could be causing these issues? There has to be a way to pinpoint what is causing this loss of power and vibration. Any information would be greatly appreciated!
02-26-2015, 09:41 AM | #2 | ||
72
Rep 438
02-26-2015, 09:50 AM | #3 |
23
Rep 234
That is correct, I am running a JB4 set to Map 5. The only other mods I have are performance exhaust and Injen cold air intake.
02-26-2015, 10:52 AM | #7 |
74
Rep 390
sounds odd, unless your a manual the auto transmission will change gears regardless. are you still hitting boost targets? post some logs, staying at redline shouldnt pose must of a porblem unless your driving around town at it for a while. but 10 or so seconds should be fine, as mentions before theres a fuel cutoff,
Automatic transmissions can test this in snow, from first, upshift into second and hold the knob up, gun it, itll hit redline, gas will cutoff, then continue,.
My Build Thread: http://www.e90post.com/forums/showth...8#post16918878 |
02-26-2015, 11:03 AM | #8 |
23
Rep 234
Car is a 6-speed manual. Could it be a transmission issue? Or possible a fouled spark plug? That would throw a code though, wouldn't it? The vibration is felt from the pedals all throughout the car. It's a very strange feeling.
02-26-2015, 11:20 AM | #11 |
The Wolf
247
Rep 987
Drives: stuff
WUT
-2019 BMW m850i convertible
-2021 Dodge Charger Hellcat Redeye Widebody |
02-26-2015, 03:19 PM | #13 |
23
Rep 234
No, the idle is definitely far from smooth. I was told by my shop the plugs and coils were not an issue since they were just replaced at the time of the walnut blast. I don't think that they ever took them out to have a look either. Should I go back there and ask them to do that as well as look for a boost leak and log everything?
02-26-2015, 03:28 PM | #14 | ||
3441
Rep 79,211
The first step is checking plugs. Checking for excessive fouling, burnt, lean condition and/or pieces missing. I wouldn't even log the car as you may cause more damage. Only thing I would do electronically is try resetting adaptations. Then do a boost leak and/or leak down test to confirm the engine compression is healthy. I don't think the shop is responsible for inspecting anything since you may have potentially caused the damage however if you trust their opinion maybe they will diagnose it but I'm sure they will charge a diagnostic fee. |
02-26-2015, 04:51 PM | #15 |
23
Rep 234
At this point I don't care if it is going to cost me anything, I just want everything to be okay and for my car to run as good as it did the day I took her home from the walnut blasting.
02-26-2015, 05:01 PM | #16 |
3441
Rep 79,211
Hopefully it's something simple. If it was my car I would reset everything including adaptations.
If that doesnt work I'd go to the plugs. If those check out the compression leak down test. |
02-26-2015, 05:02 PM | #17 |
421
Rep 1,643
I remember reading on here in the past that the crank bolt on some manual trans cars came loose causing engine damage, and BMW told these folks that an overev condition caused the bolt to come loose.
2007 E92 335i MT
02-26-2015, 05:05 PM | #18 |
23
Rep 234
How do I reset these adaptations you speak of? And I will definitely look into that crank bolt issue, thanks for mentioning it.
02-26-2015, 06:15 PM | #19 |
3441
Rep 79,211
02-26-2015, 07:46 PM | #21 |
23
Rep 234
I run a JB4 map 5 tune. Should I get one of these to run my own diagnostics and reset adaptations: http://jb4connectkit.com/store/index...&product_id=50
02-26-2015, 08:07 PM | #22 |
60
Rep 333
Could you have possibly mechanically over revved and bent a valve? This will cause the engine to vibrate and run rough.
11 E92 ZCP
02 Honda S2000 -741 whp 471 wtq (dynojet) @ 29.6 psi on e85; now on 34 psi, 800+ whp. |
