02-25-2015, 02:25 PM | #1 |
86
Rep 630
12 mm front, 15 mm rear WHEEL SPACERS
I know, some of you have had these fitted on your car , looks gorgeous!
Also improves the handling first of all combined with ACS springs. However, you can hear so many disadvantage of them too for example they shorten the life of the wheel bearings, the arm of force is bigger , suspension parts have get in different position. What's your opinion ? Definitely talking here about thin, 12-15 mm spacers , not the >20 mm one. |
02-25-2015, 02:42 PM | #4 |
114
Rep 383
02-25-2015, 02:50 PM | #5 |
The artist formerly known as AC Schnitzer UK
3609
Rep 4,518
You're unlikely to feel the difference in handling unless you are extremely sensitive (like Nick ). It's all about the look. Our wheels use a more aggressive offset than standard which has much the same effect and there is no measurable impact on the life of wheel bearings or suspension components using these. You're not altering the geometry of the suspension. The only difference, to my mind, between using a spacer and a more aggressive offset wheel is that the spacer is a separate part instead of part of the wheel casting. There may be issues with tyre rubbing if you go too far and you will need the correct length locking wheel bolts but apart from that they shouldn't cause any problems.
02-25-2015, 02:51 PM | #6 |
86
Rep 630
Mark sent me very good before and after pictures, he has 12-15 mm as well, Eibach, looks great!If you read this Mark, would you mind uploading them here as well ?
02-25-2015, 02:59 PM | #7 |
205
Rep 1,152
Not sure if F30 has more clearance than the F32, burger recommended not to exceed 10mm F and 15mm R, however I notiiced a lot of our American friends seem to be going with 12mm F on F30's
02-25-2015, 03:04 PM | #8 |
3609
Rep 4,518
One thing to bear in mind if you are copying someone else's setup is tyre brand and model. Tyre sizes are nominal and a "255" in one brand could be as much as 10mm different in actual width to another brand (or even same brand, different model). Even tyres of the same actual width can be a different shape (some are more square, others more round) so it's not by any means guaranteed that you can run the same spacers as the next guy if you have different tyres. The only way to be sure that you won't have rubbing issues is to copy identical setups.
02-25-2015, 03:07 PM | #9 | |
205
Rep 1,152
02-25-2015, 03:08 PM | #10 | ||
86
Rep 630
255 mm is 255 mm. Not 245 or 265 , I suppose.. Where the difference would come from ? |
02-25-2015, 03:08 PM | #11 |
19
Rep 59
I have 13mm H&R s pacers on the rear only.
It definately improves the car's looks, however it also definaltey increases understeer also. On the limited sizes your quote I do not envisage any bearings issues. Over 20mm perhaps..... |
02-25-2015, 03:09 PM | #13 | |
114
Rep 383
02-25-2015, 03:19 PM | #14 |
3609
Rep 4,518
Yes it depends on lots of factors. Which mould the tyre came from. Which wheel size it is fitted to. Pressure, temperature, the shape of the sidewall. Like I said, the tyre size is nominal not actual, like those 30" waist jeans you can't fit into anymore.
02-25-2015, 03:29 PM | #15 |
8569
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
Well timed thread given my spacers arrived today!
I've gone for same set up as Mark and D4springer so don't expect any issues. Surprised to hear that just 15mm spacers on the back has appreciable effect on increasing understeer though!
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
02-25-2015, 03:31 PM | #16 |
86
Rep 630
02-25-2015, 03:42 PM | #17 | |
114
Rep 383
What size, type and where did you buy them? |
02-25-2015, 03:44 PM | #18 | |
86
Rep 630
19" 255/35 and 20" 255/30 has exactly the same circumference. Does anybody use wider tyres maybe on the rear ? Have you seen this car, guy put 255/30 R20 all around, car is just amazing ! http://f30.bimmerpost.com/forums/sho...d.php?t=667029 |
02-25-2015, 03:45 PM | #19 | |
86
Rep 630
Me too , would expect the opposite.. Not on the xdrive anyway |
02-25-2015, 03:50 PM | #20 | |
86
Rep 630
Did you order conversion kit as well ? Or longer studs ? |
02-25-2015, 03:51 PM | #21 |
8569
Rep 19,982
Courtesy of D4Springer:
"I purchased the parts from CA International (http://www.ca-int.co.uk) Their website is crap, it's best to just phone them, can't recall the name of the guy I spoke to but he was very helpful and explained everything to me in detail. I initially called them about the Macht Schnell spacers but they explained the Eibach's were better, a bit cheaper and TUV approved (also didn't realise Macht Schnell is American!). Basically the Eibach Spacers come as a pair and so I have two seperate boxes for the front and rear wheels accordingly. Also there is the Stud Conversion Kit. There are part numbers on each of the two boxes but I'm not sure if these are CA's own part numbers or Eibach's 12mm; Pro-Spacer 120/5-72,5-160 S90-2-12-002 15mm; Pro-Spacer 120/5-72,5-160 S90-2-15-001 The Stud Conversion Kit unfortunately came in a plastic bag and doesn't seem to have a part number as such. You don't need the conversion kit, the Eibach's come with longer bolts to fix the wheels back on, however the conversion kit was recommended as they are stronger and safer (plus look better, easier to fit the wheel if you are going to do it yourself etc...), if you are going to change over to winter wheels this will help as the studs are fitted to the hub first so you have something to hang the wheel on whilst you tighten the bolts up." I phoned Roy at CA last week and the parts arrived today as above.
