TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Odd 6mt observations - advice
      02-23-2015, 06:44 PM   #1
Jklad
Jklad's Avatar
421
Drives: 2007 335i Coupe
Is the following behavior normal on a 6mt? Hope some experts could shed some light, or warn me of impending doom...
When rolling at 10+ mph with the stick in neutral, foot off the clutch pedal, if I push the accelerator (eg to rev match) the responsiveness is very laggy and slow. It takes more accel pedal and holding it for longer to get the rpm's to rise
If im rolling at 10+ mph, stick in neutral, but clutch fully depressed, pressing the accel pedal results in nicer snappier revs, more responsiveness.
When fully stopped, or rolling <3mph, revs are also nice and snappy in neutral.
I don't remember past vehicles responding sluggishly when revving while rolling...
'07 6mt 111k miles original clutch and fly
Thanks
2007 E92 335i MT
      02-24-2015, 09:54 AM   #2
NoTempoLimitN54
NoTempoLimitN54's Avatar
32
Drives: E92 335i
I've never noticed anything like this on my car. I'll try the specific combinations you described today and see if I notice anything.
I don't think this is a transmission issue. It's got to be DME related somehow.
For Sale: 2009 335i 6MT (E92/N54), Sport / M-Technic / no iDrive / Black Sapphire / Black Dakota Leather, ZCW, 6FL, PDC, 19" VMR VB3, Pilot Super Sport, M3 control arms + tension links (fr) S. California
      02-24-2015, 10:12 AM   #3
blaster3500
143
Drives: 07 E90 335i
Pretty sure the throttle mapping is changed in neutral. If you miss a gear and get back on the gas it helps from over reving.
      02-24-2015, 11:14 AM   #4
dbworld4k
583
Drives: '12 M3
2002 BMW M5  [10.00]
2009 BMW 335i  [10.00]
That's strange indeed. My 6MT exhibits no such issues :/ How is it when flooring it in gear, clutch pedal untouched?
      02-24-2015, 11:29 AM   #5
skim7x
skim7x's Avatar
208
Drives: 335i, C63 AMG
2007 335i  [10.00]
Thanks
My 2007 6MT is exactly the same. No problems.
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife
      02-24-2015, 11:54 AM   #6
C.Pop
65
Drives: 335i
Yep, noticed the same thing. The 6MT ECU has a few different things. Holding the throttle open between shifts when aggressively driving to not bleed as much boost off is another one of them.
2007 E90, 6MT, VRSF 7" FMIC, RR DP's, Vargas Stage 2+ (19t unclipped), CP-e Charge Pipe/Tial BOV, BMS DCI, Fuel-it! Stg 2 LPFP, E66, 118k+ miles Brentuned
      02-24-2015, 01:14 PM   #7
Tim603
Tim603's Avatar
483
Drives: 2007 335i E90
2007 335i  [0.00]
Do you think it has to do with the engine spinning just the DMF (neutral w/ clutch depressed) vs the DMF,Clutch, Input Shaft in transmission (neutral w/ foot off clutch).
That may explain why it is revving slower due to more rotating mass
"When fully stopped, or rolling <3mph, revs are also nice and snappy in neutral." - is your clutch depressed at this point?
      02-24-2015, 01:23 PM   #8
GODDSPD
35
Drives: 335i
Exact same thing with my 07 e92. I'm glad you mentioned it.
      02-24-2015, 02:16 PM   #9
Jklad
Jklad's Avatar
421
It seems ok, aside from a small occasional hesitation when initially pushing the accel pedal >40% (could be unrelated, idk)
2007 E92 335i MT
      02-24-2015, 02:24 PM   #10
Jklad
Jklad's Avatar
421
"When fully stopped, or rolling &lt;3mph, revs are also nice and snappy in neutral." - is your clutch depressed at this point?
Nope, in this example clutch is not pressed at all, stick in neutral.
2007 E92 335i MT
      02-24-2015, 02:25 PM   #11
Jklad
Jklad's Avatar
421
Hmmm...in my examples I'm not driving aggressively.
2007 E92 335i MT
      02-24-2015, 02:28 PM   #12
Jklad
Jklad's Avatar
421
This could explain it, I didn't realize there's more going on mechanically with stick in neutral and clutch fully out, as compared to clutch pedal fully pressed. I think I learned something!!!
2007 E92 335i MT
      02-24-2015, 02:40 PM   #13
Dmacc
200
Drives: 2011 BMW 1M
Same thing in my car. It annoys the living piss out of me. And I'm running the spec steel smfw.
thanks to MGallop
      02-24-2015, 04:53 PM   #14
max_k20
Bavarian Love
24
Drives: 230i xDrive
Same here ! 2009 335xi 115k km (around 71500mi) on original clutch and flywheel.
08 FG2 Civic SI FBO - SOLD
09 E92 335i Xdrive FBO - SOLD
17 F22 230i Xdrive | Alpine White | Coral Red | M-Sport | BMS Intake | JB4 | 666M Rep | M Carbon Mirrors | Roof Rack | Daily Driven
      02-24-2015, 06:47 PM   #15
nukezero
343
Drives: BMW 3 series
when you let go of the clutch pedal (foot off), stick in neutral, the engine is still connected to the tranny. But the tranny is in neutral internally. But that doesn't mean the engine isn't under some load. The engine is still spinning a neutral gear inside the tranny which puts a load on the motor.
Now when you depress the clutch (foot pushed down, no matter what position the stick is in, now the engine is fully disengaged from the tranny. So the engine technically has no load applied to it from the tranny, other than the mass of the flywheel. hence, that's why it will be easy for the engine to rev up faster.
      02-24-2015, 11:19 PM   #16
NoTempoLimitN54
32
Drives: E92 335i
It does that by cutting ignition timing so it doesn't have to open the waste gates as much to maintain boost. I've posted this several times but the 6AT guys refuse to believe it (even though I posted the info from a SAE paper by BMW engineers).
I did a QUICK test today and really didn't notice a difference clutch in/clutch out.
I'll try again tomorrow.
      02-25-2015, 12:16 AM   #17
C.Pop
65
Drives: 335i
I don't know about the timing, but I have logs showing the ECU just holding the throttle position wide open/slowly drifting closed with foot off of pedal. Cool feature.
      02-25-2015, 08:43 AM   #18
Jklad
Jklad's Avatar
421
Try it when rolling at around 20-30mph. When you put in n, let the revs fall to 800 before revving it.
2007 E92 335i MT
