New Injectors = Loss of Torque?
02-23-2015, 06:41 PM | #1 |
Rep 70
I searched but couldn't find anything specific so I was hoping you all could help. A few months ago, my N54 developed the rough idle and was getting a cylinder 3 misfire error. A couple months before that, I had replaced all my coils and plugs. So I suspected the injectors had gone bad.
The dealership confirmed that I needed new injectors. I was just out of my CPO warranty, but qualified for the warranty sharing program so I only had to pay $400 to have all six injectors replaced. So the problem I'm having now is since the injectors have been replaced, I'm noticing a significant loss of low-end power. Maybe below 3,000 rpm, there seems to be a less torque. If I got WOT, I wouldn't notice any difference, but if I'm at half-throttle, there is definitely less power. I'm not familiar with the mechanical workings of injectors, but is the loss of power normal? Maybe the latest revisions of injectors flow less fuel? Any ideas? |
02-23-2015, 08:40 PM | #2 |
ex deus machina
124
Rep 968
They most likely updated your firmware to 29.2 which has been known to cause extra ‘lag’ at low rpms
What tune are you running?
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK Gone: E92 335i N54 468rwtq |
02-23-2015, 08:45 PM | #3 |
The Wolf
247
Rep 987
Drives: stuff
I noticed less Boost but more response/lowend especially sub 1700rpm but I'm sure I had 29.2 long before
02-24-2015, 08:21 PM | #6 | |
135
Rep 1,075
One of my friends told me the newer injectors have a higher flow rate. So the car needs to adapt. It took a couple of days but my car is great now!!! |
02-24-2015, 11:00 PM | #7 | |
352
Rep 2,050
02-25-2015, 10:56 AM | #8 |
Rep 70
I thought the same, but it's been over a month for me with no change. Even a tune didn't solve the problem. I'm taking it for a drive today with the tech. I still think the folks above are correct about the software, but what do I know?
02-25-2015, 11:06 AM | #9 |
Rep 70
I don't recall what the official name of the program is, but my car was just out of CPO warranty when I had the injector problem so I asked if BMW would extend me goodwill to cover the costs under warranty. They wouldn't do it for free, but the manufacturer will look at the problem and the age and mileage of your car. If you qualify, you only have to pay a portion of the cost of repair and BMW will pick up the rest. My car had only 56,000 miles so I was well within the warranty range. So I had to pay only $400 for my share to replace all 6 injectors.
The good news that I found out yesterday when I called is that I should be getting that money refunded to me because there was an injector recall related to emissions which is part of the 8 year warranty. If you're getting a repair and you're just out of warranty or having a similar issue, I would talk to the SA to see if they can arrange a repair under the voluntary emissions recall. |
02-25-2015, 12:03 PM | #10 | |
352
Rep 2,050
02-25-2015, 03:52 PM | #11 | |
135
Rep 1,075
02-26-2015, 12:28 PM | #12 | ||
Rep 70
02-26-2015, 12:37 PM | #13 | ||
Rep 70
02-26-2015, 12:38 PM | #14 | ||
Rep 70
02-26-2015, 07:40 PM | #16 |
Rep 44
NEVER PAY FOR INJECTORS IN CA. Covered under emissions Warranty
I am not sure on the rules in other states. With the N54 in California injectors are covered up to 70k miles or 7yrs. No need for good will anything.
I got them to change mine at 68k miles. It was a battle. For the most part your going to have to have near new Spark plugs and coil packs. You can buy coil packs on online for $200 and plugs are about $70. But it costs about $2k for injectors with parts and labor... GO look in the owners manual it lists all the parts covered in CA on the emissions warranty. On some of the SULEV Injectors are covered to 120k miles. The N54 us a ULEV.... |
02-27-2015, 08:19 AM | #17 | |
Rep 70
I installed new plugs and coils a few months ago so I should be good to go. I'm taking the car back in a couple of weeks to see what they can do about the lag. |
03-11-2015, 08:59 PM | #18 |
Rep 70
Update and I could use your advice: I took in the vehicle again to follow up on the loss of torque/lag that I'd been experiencing between 1000-2000 rpm after they installed new injectors. The dealership has come back with the explanation that I have carbon buildup and need walnut blasting. Of course they want about $1,200 to do it.
So I said there's no way that my issue started the second the injectors were installed and the DME was updated. This is the diagnosis they're sticking with. Is this possible? I'm not sure what to do here. They can't flash back to older software and I sure as hell don't want to pay the dealership $1,200 for walnut blasting to attempt to fix the problem. Any ideas? |
03-11-2015, 09:54 PM | #20 |
Rep 70
03-11-2015, 10:02 PM | #21 |
ex deus machina
124
Rep 968
have them goodwill it, talk to the service department manager if needed
03-11-2015, 10:12 PM | #22 |
Rep 70
