SMFW & 335is clutch
02-23-2015, 05:32 PM | #1 |
18
Rep 66
Drives: 2008 335i E92 6MT
Garage List 2014 BMW 535D Msport [0.00]
2011 BMW 335D [0.00] 2008 Porsche 997TT [0.00] 2011 335i E93 [0.00] 2008 335i E92 [0.00] 2008 750i [0.00] |
SMFW & 335is clutch
has anybody used this combination? Really want the SMFW for later upgrades...Really don't want a LOT of gearbox rattle.
Was thinking about the Mfactory flywheel and either the spec 2+ or 335is, Thanks |
02-23-2015, 05:34 PM | #2 |
3441
Rep 79,211
If you don't want flywheel chatter don't get a SMFW. If you plan on going over 500WHP/TQ then you'll need it.
Honestly, if you are going to upgrade the clutch, I understand the 335is is a cheaper clutch but I doubt it has the holding capacity of a Spec stage 2+. If you are already talking about needing a SMFW it sounds like you'll need the torque capacity of an aftermarket clutch. Figure out your power goals first and then pick up a clutch based on that. |
02-23-2015, 05:36 PM | #3 |
18
Rep 66
FBO with meth now...figured when the turbos need to be replaced that I would be over the recommended power for the DMFW as I at least plan on upgraded twins or single kit
02-23-2015, 09:49 PM | #4 |
54
Rep 591
I'm running a spec Aluminum flywheel with the 335is clutch. Running the UUC oil combo and there is rattle when the trans is hot. Though under normal driving it stays pretty quiet.
02-23-2015, 10:44 PM | #5 | |
3441
Rep 79,211
So if you want to try to keep it you should at least get one new. The 500WHP figure is conservative. The real problem is as they age they become imbalanced so there is no exacct power figure that deems them no good. A fresh DMFW can likely go a little past 500WHP, where exactly nobody knows as everyones car is different. What I'm trying to say is there is a slight chance a new DMFW could be fine at the power level of RB's. But if you are going to single I'm pretty certain you'll need to go SMFW for sure and at the singles power level I'd sway heavily towards getting an aftermarket clutch that can hold the power. The steel would make a little less noise for future reference. |
02-24-2015, 04:03 AM | #6 |
18
Rep 66
I was hoping for a good twin plate option eventually. Heard many issues with the spec setup. Wondering when the Mfactory twin plate will get released
02-26-2015, 03:20 PM | #7 |
100
Rep 1,384
im in the same boat and thought i would share what i have found through my research.
If you want to go with a traditional single disk clutch setup. you may want to consider "bully clutch". ive talked to a few ppl running them on other platforms and on track cars and they say that these clutches perform! The one i was looking at was the stage 4 ceramic with their aluminum flywheel. They said that ther "buttons" on their clutch help with slipping the clutch in as opposed to other ceramics, so it gives you more practicality for daily while being able to be pusnished on track and with higher tq and hp of our modded cars. that being said you probably will still need to get used to this type of clutch compard to stock. the price on these is very good too. so might be worth checking out. cheaper than SPEC. the other option that might interest you is the motiv twin disk, twin disks will hold a lot of power (900 ft/lbs) and are slippable so it will be easier to drive daily. only downside is the price for these. although the motiv one is cheaper than the one from clutch masters. lastly, word has it that Comp Clutch is coming out with a twin disk as well for the e9x 335i (maybe within the next couple months), which will use 2 organic disks as opposed to ceramic disks. which allows them to be even better for daily but will still hold about 650ft/lbs. i was really close to ordering the bully clutch because the price difference between that and the motiv twin was about $900 CAD (canadian conversion sucks right now). im expecting the Comp to be somewhere in the middle of those two and want to wait to see what they come out with. |
02-26-2015, 05:49 PM | #8 |
18
Rep 66
Thanks for the input.
I did consider the Motiv and was prepared to pay for it, however I read A LOT of people having issues with it. There is a huge thread on ***********. So I have ordered a new DMFW and 335is clutch for the time being. Stock drivability and slightly better torque capacity. If a reliable, drivable twin comes to market I am on board and will have to pay again, If the Is clutch wont hold the power I will get something else that will work with the DMFW. Bad timing I guess, since the Platform is improving, but still not many great option for a clutch. |
02-27-2015, 09:14 AM | #9 | |
100
Rep 1,384
02-27-2015, 10:08 AM | #10 | |
3441
Rep 79,211
This was sent to me just two days ago by a customer looking for a good clutch kit that holds the power and similar to stock. I don't believe hes a big forum go'er but figured it was worth posting his testimonial as I think people are selling the Spec 2+ short.
02-27-2015, 10:20 AM | #11 |
18
Rep 66
I don't doubt the spec 2+ will hold the power, but at my age nvh is also a concern which is why I chose the Is clutch. Might be a mistake, only time will tell
02-27-2015, 10:22 AM | #12 |
162
Rep 1,264
Nobody has fully tested the 335is clutch, but its held up in JB tuned 550i's which make over 500rwtq and weigh 4300lbs.
2010|335i|LMB|E92|6MT|MSport|Logic7|335is Clutch|AE Performance|BMS|Walbro|VRSF 7"| 149.7mph NFZ AZ 1/2mi
1992|Pontiac Firebird|Mild 355ci|T56| -I will look on your treasures, gypsy. Is this understood?- |
02-27-2015, 12:20 PM | #13 |
65
Rep 385
I've been on the 335is/550i clutch and a SMFW for about 6000 miles, at/above 550 wtq for over the last 3000 miles with VTT 2+'s no issues.
2007 E90, 6MT, VRSF 7" FMIC, RR DP's, Vargas Stage 2+ (19t unclipped), CP-e Charge Pipe/Tial BOV, BMS DCI, Fuel-it! Stg 2 LPFP, E66, 118k+ miles Brentuned
02-27-2015, 12:43 PM | #14 |
Rep 131
Do you get any drone in lower rpms (from idle upwards) when accelerating in 2th or 3th gear, daily driving?
I ask as it's a complete undampened setup. How does it feel in terms of mushiness in the drivetrain vs a DMFW? Does the drivetrain response become more direct on throttle input? Thanks |
02-27-2015, 03:03 PM | #15 | |
65
Rep 385
2: Feels a LOT more direct. It feels like quite a bit better throttle response.
02-27-2015, 03:15 PM | #17 |
3441
Rep 79,211
There shouldn't be any NVH on the 2+ with the DMFW. It will pretty much drive like stock with a slightly stiffer pedal feel.
02-27-2015, 03:40 PM | #18 |
Rep 131
Thanks for the clarifications.
I'm thinking on getting a SMFW but with a dampened clutch. The mushy DMFW takes away quite a bit from the drivelines sportiness. |
02-27-2015, 03:42 PM | #19 |
Rep 131
What setup do you run?
Ups, saw you posted already your setup! Last edited by serotoninsteve; 02-27-2015 at 04:33 PM.. |
02-28-2015, 10:37 PM | #20 |
32
Rep 269
11-18-2015, 06:23 PM | #21 |
65
Rep 385
Update: 335is/550i clutch is starting to slip with about 20k on it. Depending on temps and tune between 550-600 wtq for the largest percentage of those miles. I drove aggressive but not many launches and nothing on drag radials, I don't think the clutch would handle that well at all. Lots of 2-3 WOT pulls and many, MANY 3rd gear logs from 2500-7200 rpm. It's a good value in a clutch but probably not for hugely upgraded turbos like the 2+'s. FBO stock turbo unless you do torque bomb tuning it should be an awesome and cheap upgrade. Just updating my results.
11-18-2015, 06:33 PM | #22 | |
533
Rep 2,872
Thanks for giving the feedback though so anyone expecting durability at those power levels can plan on something else. I'm going for the 335is clutch myself very soon I hope. What flywheel are you using with it? I know it's a SMFW, but is it the steel one or aluminum? |
