Quaife vs Wavetrac LSD
02-23-2015, 03:24 PM | #1 |
168
Rep 842
No one can argue the importance of an LSD especially with a FBO 335i.
I've ran a Quaife LSD for a little over a year and it performed flawlessly on the track and drift events. There's a very slightly thump going into first gear but otherwise it's silent. Regrettably I parted out some of the goodies on my 335i and thought I was ready to move onto a different platform. I sold the Quaife and rode around on an open diff again. I thought the LSD wasn't needed for a street car but boy was I wrong. After having the LSD then going back to an open diff I realized how important the LSD is for traction. The open diff completely sucks! Anyway, I'm back at rebuilding my 335i and just installed a Wavetrac LSD. After paying a shop twice to install my Quaife, then remove it I decided I'll tackle the Wavetrac install myself. Both diffs were built and bought from VAC Motorsports so it was just a pumpkin swap. Wavetrac so far... slight thump only in reverse, no thump when driving. Very, very slight whine on high speed decel (Wavetrac zero load patented technology?) Thus far, not much difference from the Quaife but I have a track day in late March. Stay tuned for my report. When I had my Quaife I bought an OEM finned diff cover from a forum sponsor for $400! After doing some research I realized it was just a 6 series cover that was slightly modified. I bought the finned cover and modify it myself (cost $150). I recommend a finned cover because after a drift event my fluid overheated and spat out. Anyway, if you don't have an LSD go get one now! I have a track event booked in late March and I'll report back on how the Wavetrac performs. On to the fun: Quaife: Wavetrac: stock diff removed 6 series finned diff cover installed video coming soon... Updated: 4/1/15 Came back from a track day a couple of weeks ago. Video here. So the difference I noticed between the Quaife and Wavetrac was that when I'm off the gas the rear still felt planted and ready to go. That was only felt at the limit and on the track. If you're looking for max potential then the Wavetrac "could" be better. In sum: you can't go wrong with Quaife or Wavetrac.
02-23-2015, 09:05 PM | #2 |
90
Rep 632
Thats a cool video doing doughnuts.
02-24-2015, 09:55 AM | #3 | |
ex deus machina
124
Rep 968
The LSD was my second mod after JB4, JB4 + race gas + open diff makes a one scary and unpredictable car to drive
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK Gone: E92 335i N54 468rwtq |
02-24-2015, 03:49 PM | #4 |
23
Rep 209
Drives: Z4M roadster
Please advise what was involved in modifying the diff cover? Which 6 series did it come from?
2006 Z4M roadster. Interlagos Blue, black extended leather with carbon trim. Apex EC7 8.5/9.5 x 18 rims, Strong Strut brace, KW V3s with RE rear shock mounts, Vibra Tech and Rogue engine/transmission mounts, Stromung exhaust, CDV delete.
02-24-2015, 03:57 PM | #5 |
711
Rep 3,251
+1, more info on the finned diff cover? Do you have the larger or small diff pumpkins?
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization |
02-25-2015, 01:04 PM | #7 | |||
168
Rep 842
I have a large pumpkin, manual... in sum, 6 series OEM diff cover (~$120), 130mm bolt ($15), ~15mm spacer ($5), cut a few fins w/ a cutting wheel or dremel.. coming soon...
02-25-2015, 08:37 PM | #8 |
1565
Rep 672
Wavetrac has been great so far. Works for donuts too Though mine are less entertaining with some wet ground.
02-26-2015, 09:38 AM | #9 |
DIYER
614
Rep 5,521
Have had my wavetrac a long time and no issues....my buddy had a quaife abd didn't have such good luck.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
02-28-2015, 12:19 AM | #10 | |
168
Rep 842
Hey Rob, I referenced part of your diy during my install. You've been an amazing contributer to the forums! Thanks!!!
03-01-2015, 11:30 AM | #11 | |
1549
Rep 3,788
Did you order any other short or long bolts besides the (1) 130mm bolt? Thanks for your post and the referenced post, rep'd! |
03-01-2015, 02:22 PM | #12 | |
168
Rep 842
yes I ordered 1 x short bolt for the diff cover.. instead of making or buying an expensive spacer I bought something like this: http://www.homedepot.com/p/Climax-5-...-062/203025026. also add 1 fender washer if necessary... it's hard to explain but once you're under there you'll see if you the gap you need to fill..
04-01-2015, 04:12 PM | #13 |
168
Rep 842
updated with post track comments & video
04-01-2015, 10:48 PM | #15 |
2203
Rep 3,336
Drives: X5 & E90 WTCC Widebody Racecar
04-02-2015, 08:48 AM | #16 |
370
Rep 620
I'm a LSD noob. What makes the LSD so good for normal street driving? Without it were you getting DSC intervention on a regular basis? The reason I ask is that I don't track my car and rarely get the DSC light.
04-02-2015, 10:41 AM | #17 | |
ex deus machina
124
Rep 968
With an open diff the car goes sideways into the next lane, and only then does the DTC intervenes and saves you from spinning out, it’s an electronic system and requires time to react but you are already slipping into the lane next to you. with LSD it’s a mechanical system that reacts instantaneously it feels like the backend wiggles a bit as power gets transfers side to side but while keeping you in a straight line…
04-02-2015, 01:04 PM | #19 |
62
Rep 954
MFactory.
cp-e GTX3071R TT kit, cp-e quad exhaust, cp-e fuelbar, Stage 3 LPFP+lines, AEM EFI, Custom Meth kit, Apex EC7 18s w/R888 295s, Stoptech, M3 front, m-sport rear, cp-e difuser, Custom Headlights, CFS Radiator, Custom OC, 1000hp Lvl10 trans, DSS Axles, MFactory LSD, DEFIV lockdown kit, M3 refresh kit, KWv2's, cp-e project "4doorbmwpower"
04-02-2015, 01:06 PM | #20 |
62
Rep 954
but if you really want to get educated on it, shoot them a PM and sincerely inquire about why you should buy theirs, listen to what they have to say. Tell them you dont know much about LSD they will explain. I knew what I was getting into and the questions I didnt think they could answer they were more educated on than I ever though anyone would be.
04-02-2015, 03:14 PM | #21 | |
168
Rep 842
04-02-2015, 07:14 PM | #22 |
453
Rep 2,973
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
