BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > All 4 o2 sensor codes
      02-22-2015, 12:57 PM   #1
Acekid187
Acekid187's Avatar
27
Drives: E92 335i, E90 335i
Got on it on the highway and service engine light soon came on and bumped to map 4. These codes popped up
29F3 Faulty Low Fuel Pressure Sensor
2C9C Lambda probe heating in front of catalytic converter, input signal
2C9D Lambda probe heating in front of catalytic converter 2, input signal
2C9E Lambda probe heating behind catalytic converter, input signal
2C9F Lambda probe heating behind catalytic converter 2, input signal.
I have tried erasing codes threw the JB4 I have disconnected the battery in hopes of that doing something. Im at a lost. I have posted this on the other fourm but still havent been able to figure it out. If anyone can chime in it would be appreciated. I been looking for a fuse to see if that blew out but havent had luck on finding the right one.
6K Halos, 6K interior Lights, 6K License plate lights, 5" VRSF FMIC, 3K Fogs, JB4 G5, Cyba air scoops, 19in ST1s, ACS Roof Spoiler, DCI, VRSF 3" DP, VRSF CP w/ Tial BOV, VVT Stage 1
      02-22-2015, 01:11 PM   #2
chepy24
chepy24's Avatar
30
Drives: 2009 alpine white 335i xdrive
did you recently install dp and or o2 sensors?
      02-22-2015, 01:26 PM   #3
Shadow007
63
Drives: 2009 335i coupe monaco blue
+1
Those are the same codes I got when I did my turbo swap. You need to switch you o2 sensors they're backwards.
F90 M5 Comp/ FI Exhaust, MAD pdownpipes / PG Intakes/ H&R Springs/ AG wheels
E85 Z4M
      02-22-2015, 01:39 PM   #4
chepy24
chepy24's Avatar
30
Originally Posted by Shadow007 View Post
+1
my first guess
      02-22-2015, 01:50 PM   #5
Acekid187
Acekid187's Avatar
27
I had the VVT stage 1s installed 3 months ago. DPs have been on for 2 years. Most recent work was a valve cover. I check the o2 connection on those and they are good
      02-22-2015, 02:03 PM   #6
Acekid187
Acekid187's Avatar
27
Someone on the other fourm said to check the little black fuse box near the ecu which i have now found but cantt seem to get it open
      02-22-2015, 02:40 PM   #7
Acekid187
Acekid187's Avatar
27
Ok after searching on youtube and google for forever i finally found a video on how to open the fuse box near the ecu. there is a blown 30 amp fuse in there. I will replace and report back
      02-22-2015, 04:10 PM   #8
chepy24
chepy24's Avatar
30
easy fix! awesome keep us posted
      02-22-2015, 04:56 PM   #9
HeavyMetalRocker
HeavyMetalRocker's Avatar
34
Drives: 2007 BMW 335i E90 6MT
can you post the link to the youtube video?? Might have a similar issue currently!
2007 335i e90 6mt | Motiv 750 XR8267 | RB PCV | JB4 G5 | MHD Pump Flash | Walbro 255lph | VRSF CP & Tial BOV | NGK Plugs | Custom Side Exhaust | CxRacing FMIC | Spec 2+ & SSMFW | StopTech Drilled/Slotted Rotors | Hawk Performance Pads | DEFIV Lockdown kit | Mtec V3 | Apex PS7s | 35/15% Llumar ceramic
      02-22-2015, 05:35 PM   #10
shawntech
The Wolf
shawntech's Avatar
247
Drives: stuff
  [0.00]
2019 BMW M850i conv ...  [0.00]
If the fuse blew o2 wires are probably grounding out.
      02-22-2015, 07:40 PM   #11
Acekid187
Acekid187's Avatar
27
Video is for an E46 but its the same little fuse box.
And so far the codes are still present. I was instructed by my bimmer tech buddy to do some driving and if it doesnt clear then its another issue or like some just stated that the wire is grounding out and causing that fuse to blow again
      02-23-2015, 02:20 PM   #12
HeavyMetalRocker
34
Thanks man!
      02-23-2015, 08:41 PM   #13
Acekid187
Acekid187's Avatar
27
you where completely right. The wire had touched something and cause the fuse to blow. I moved it and rewrapped it and replaced the fuse. Cleared the codes and all is well. thank you everyone for all you help
      02-23-2015, 08:44 PM   #14
shawntech
The Wolf
shawntech's Avatar
247
Drives: stuff
  [0.00]
Excellent. Enjoy the car, wish I had downpipes!
      02-23-2015, 09:02 PM   #15
Tiago@VRSF
Tiago@VRSF's Avatar
2095
Drives: F90 M5
Thanks for posting the result, should be helpful in the future
      02-23-2015, 09:55 PM   #16
JDuke335i
JDuke335i's Avatar
57
Drives: 2009 335i , Alpine white
Is the fuse in the same place on a e90
FBO , MHD , tuned
      02-24-2015, 08:17 AM   #17
chepy24
chepy24's Avatar
30
woop woop!! glad it was an easy fix!
      02-24-2015, 12:57 PM   #18
Acekid187
Acekid187's Avatar
27
On e90/e92 it's in passenger side.
      02-24-2015, 08:26 PM   #19
JDuke335i
JDuke335i's Avatar
57
Thanks
FBO , MHD , tuned
