Bulb issue. E92 2007 335i
02-21-2015, 06:48 PM | #1 |
26
Rep 218
I just noticed this afternoon as I was warming up the car that my right rear tail light was out. No biggie I thought until I checked the dash and it did not tell me there was a bulb outage. This function has happened in the past to alert me to this fact. Any thoughts as to a solution?
ZPP, ZSP, NAVI, STEP, PADDLES, CA, PDC, HEATED SEATS, debadged, painted reflectors, plate frames, & keyhole cover, GP Thunders 8500 angels & fogs, Euphoria 6K High Powered Interior LED's, pearlescent E-brake handle, and mud guards, Split Second Turbo Tuner. |
02-24-2015, 03:54 PM | #2 |
26
Rep 218
Good Grief. 92 reads and not one possible solution Guess it will warrent a dealer visit. Not what I hoped for but it is what it is.
02-24-2015, 04:25 PM | #3 | |
54
Rep 185
I pulled the bulb, cleaned the contacts and reversed the way the bulb sat in the socket. Havent had a single issue since. A little different than not being told bulb out but im guessing along the lines of similar issue w the housing. Did you pull the bulb to be sure it is in fact dead? |
02-24-2015, 05:14 PM | #4 |
298
Rep 2,015
1+ on above.
Clean the contacts of the harness not the bulbs. Check for water or rusting on the trunk left and right sides under the battery and under amp if rusty or water. Then you have a leak from the rear lights. Gasket needs to be changed. DN |
02-25-2015, 05:19 AM | #6 |
26
Rep 218
Thanks guys. Thats the project for today.
