Missfire cylinder 6 with new HFPP, injectors, coils and spark plug...
02-21-2015, 08:42 AM | #1 |
64
Rep 412
Hello guys,
I going to be crazy, since a long time now, I have missfire on hard map 7 and 6 (20.5psi). I'm running on fuel mix 60% of e85 and 40% of SP98. I changed first my spark for NKG irridium twice with 0.57mm, a month a go, I changed the high pressure pump since I had the first number part. After that, I changed all the coil and now the injectors of the cylinder 4, 5, 6 and after some test in second gear, missfire on cylinder 6, I changed coil with another cylinder, just in case but always cylinder 6 in missfire. Please help, I don't know where to look, maybe need to take a fuel pump upgrade for e85? Give you 4 log of tonight. Information about my car, 335i of 2007 with 53000km, 2 turbos KKK K04, wagner intercooler, DP, JB4 with flash e85, PCV valve, KW V3 suspensions, M3 e92 arms and anti roll bar, LSP Schnitzer 70%, clutch Sachs performance, Brembo 380x34 in front. On map 6 with 20.5 psi, 504hp on wheels. |
02-21-2015, 10:24 AM | #2 |
265
Rep 1,392
If you dont have a upgraded LPFP then thats your issue. cyl 6 is the last in line to get fuel so when all other cylinders drop the pressure in the rail and your HPFP cant keep up with demand because the LPFP is out of steam then thats your problem. SteveAZ has a solution for you.
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust 335i 2009 e90 665RWHP VFF900 ST RIP . |
02-21-2015, 02:33 PM | #3 | |
352
Rep 2,050
'10 e92 N54
DCI intakes, ER chargepipe, TIAL BOV, VRSF 5in FMIC, BMS Downpipes COBB e30 |
02-21-2015, 07:43 PM | #5 |
64
Rep 412
What a dmfw
The missfire appears almost all the time in 2egear between 6000-6500rpm. Sometime in 3e gear. You think that with a high flow gay pump, it will be ok? Some people told be about flywheel... |
02-21-2015, 09:07 PM | #7 |
64
Rep 412
Thank you. I think I'll try to reduce the gap of the spark plug, maybe a new gas pump and then, the fly wheel because I already have to change soon my water pump with just 52000km
02-28-2015, 01:36 AM | #8 |
64
Rep 412
Hello guys
I tried to reduce the gap at 0.5 and I think my misfire was worse than before. I will put a new spark plug with the original gap 0.57mm. I think I'll try to buy a used smfw to try because I can't buy a new set for now and if it's not working again... This month I already changed HPFP, rear tyres, front brakes, 3 injectors and now I have the water pump... |
02-28-2015, 02:19 AM | #9 |
65
Rep 385
Make sure you reset a/f learning adaptations with Bav Tech tool or INPA.
2007 E90, 6MT, VRSF 7" FMIC, RR DP's, Vargas Stage 2+ (19t unclipped), CP-e Charge Pipe/Tial BOV, BMS DCI, Fuel-it! Stg 2 LPFP, E66, 118k+ miles Brentuned
02-28-2015, 11:18 AM | #11 |
292
Rep 1,473
Switch back to OEM plugs and I bet that your misfire will go away. I tried those plugs in my Z4 and I never could get them to work without a misfire.
03-03-2015, 01:05 PM | #15 |
BimmerPost Supporting Vendor
24197
Rep 190,805
You cant run E60 without an upgraded fuel pump
you need to get the Fuel-it Stage 2 Low pressure fuel pump
03-03-2015, 03:52 PM | #16 |
128
Rep 664
Just trying to learn here, what is it about the DMFW that causes problems? And what does one do? Replace it? With another oem part? Or aftermarket?
08 E92 335xi 6AT, Sapphire Black Metallic
Modlist: 19x8.5+32/19x9.5+35 BBS CH-R Black, Michelin PSS 225/35/19 - 255/30/19, rolled rear fenders | KW v3 coilovers | Akrapovic exhaust Keep it on the black stuff shiny side up! |
03-03-2015, 04:02 PM | #17 | |
3441
Rep 79,211
However, if the stock DMFW has high mileage, say 75K or more, then the internals begin to wear and fall apart. So then DMFW should be replaced at high mileage or or switch to a SMFW for a set up of over 500WHP. We've had customers take apart those DMFW with high mileage vehicles and they said it was literally about to fall apart. Most that go with a single mass flywheel upgrade get it cause its either cheaper then a DMFW or they plan on running more then 500WHP. When going over 500WHP the stock DMFW becomes imbalanced. This imbalance will cause chronic check engine lights as a result of the vibrations. If you are staying on stock turbo's I typically recommend folks to stay with the new OEM DMFW, as it will drive like stock, especially when mated to a good clutch kit, like Spec Stage 2+. Last edited by Jeff@TopGearSolutions; 03-04-2015 at 10:10 AM.. |
03-04-2015, 08:18 AM | #18 |
64
Rep 412
I have 504hp et more than 700nm of torque, I just bought tmap sensor, charge pipe and forge DV to put little more boost on it. Actualy, i'm at 20.5psi and I want to try with 22psi.
I think I'll have 550hp and maybe 740nm so the simple mass is necessary in my case. I gave my log to Russel and my fuel pressure is fine. |
