Cobb prep and a few related questions
02-20-2015, 08:08 AM | #1 |
26
Rep 199
Ok folks, I have several parts out for delivery hopefully today so the time draws nigh. Parts are:
Helix/ATM FMIC VRSF CP VRSF Catless DP Cobb AP V3 I have an 07 e90 with 76k miles on it. I plan to swap spark plugs but do not plan to touch coils or injectors. I have stock air box/filter...planning to go AFE sealed intake in a month or so. Questions are: Do I need any other engine maint/prep? Will I have any issues on stock air box for a short window if time? With the hardware installed, which OTS map should I use with the Cobb? I am planning an tune from Wedge, should I wait to log til summer to get worst case conditions or can tuning parameters accommodate those variables effectively? Can't wait to unleash the monster within! |
02-20-2015, 08:56 AM | #2 | |
72
Rep 438
I added the K&N drop in air filter to my FBO. I don't know if it was really necessary, but COBB recommends it for Stage 2+ FMIC Aggressive and what's $50, after all of the other expenses.
02-20-2015, 10:10 AM | #3 |
3441
Rep 79,211
Only downside to the stock air box with stock filter is your turbo's need to work a little harder. The stock intake is like breathing through a straw.
The mods would be Stage 2+ FMIC but you should consider at least upgrading your air filter at a minimum. It would relieve your wastegate duty cycles which would improve efficiency of the turbo's. |
02-20-2015, 07:09 PM | #4 | |
26
Rep 199
02-20-2015, 07:11 PM | #5 |
3441
Rep 79,211
