e90 320i car jerking forward during low gear change/acceleration
02-20-2015, 01:00 AM | #1 |
12
Rep 51
Drives: F25 X3 xDrive 20i
I have been having a bad hesitation issue with my BMW 320i E90. When i press the throttle to accelerate out of a roundabout (rotary), the car stutters and hesitates to move for 2 seconds.
Its as if the gearbox can't select a lower gear, gears or clutch slipping. It is dangerous because sometimes the car doesn't respond in the crucial moments. It only does this from speeds of 10 - 30km/h. Very responsive at higher speeds. I have replaced VVT motor, Eccentric shaft sensor, sparks. Gearbox/diff fluid, head cover gasket, oil filter housing seals, , reset adaptive transmission. I've scanned for fault with INPA and cannot find anything. Has anyone had this issue and found a solution? Thank you |
02-20-2015, 01:15 AM | #2 |
15
Rep 152
Drives: 2007 328i Coupe
Could be a possible misfire due to ignition coils.
02-20-2015, 11:03 AM | #3 |
12
Rep 170
If there are no codes, the coils should be fine.
Try Techron and cleaning the Vanos solenoids. Then go for a long spirited drive. If that doesn't help then try spark plugs. How many kilometers? |
02-20-2015, 11:21 AM | #4 | |
52
Rep 405
02-20-2015, 12:16 PM | #5 |
Rep 17
I drive 09' E90 LCI 320i (N43 engine), 6MT.
Had same hesitation issue in low RPM for years. Had once a coil problem; later (2013) BMW replaced all coils under warranty. Hesitation was somewhat still there. Clutch shuddering in 1st gear, when engine warm up. In 2014, had 2 sensors raising fault codes and replaced; this time, I asked for DME software update. Since then, the clutch shuddering and engine hesitation issues are gone, and car is running smooth and has adequate low RPM power as it should. |
