BMS meth kit vs. others....
02-18-2015, 09:17 PM | #1 |
28
Rep 182
Since having the JB4 you would think it is only logical that I should go ahead and get BMS' meth kit right? But, just bc they make the software my car uses does that mean the kit they fabbed together really is any different? They have a FSB controller that integrates with the JB4. But the AEM meth kit I have seen also has a FSB controller. So isn't either one just as good of an option? The JB4 should detect the absence of meth with either kit right? Anyone running a kit other than BMS? I am wondering my other options and weighing costs etc. I love Burger but I can find kits with basically the same components and specs as theirs.....
07 335i...M2 exhaust...Macht Schnell DP's...VRSF 7" FMIC...MMP inlets....VRSF Chargpipe with HKS BOV....MHD w/WedgeTuning.... RB Stealths!!!....MFactory LSD...Stage 2 Fuel It...N20 map sensor....265/40/18 Sticky Mickeys in the rear
02-18-2015, 09:27 PM | #2 |
Joint Chiefs of Staff
4918
Rep 115,980
The BMS meth kit has compression fittings and some features not found in other kits like AEM. If not doing a BMS kit then do Aquamist. It's the only viable quality alternative.
Mike |
02-19-2015, 09:03 AM | #3 |
39
Rep 227
I put together a Devil's Own kit dual stainless line kit and used the BMS fsb. I went with the DO stuff because of the customer service, tank selection and friends who had good experiences with their products. I ended up spending quite a bit with the options I went with though. It works flawlessly. As far as I know you can integrate the fsb into any system although the Bms system is a good value.
02-19-2015, 09:51 AM | #4 | |
3441
Rep 79,211
If you have a JB4 you just need the FSB to integrate it correctly. Otherwise all meth kits are universal in nature; Pump, tank, lines, fittings, nozzles. As Mike already said the only other kit that stands out between coolingmist (BMS), devils own and other generic brands is Aquamist.
