Long-term Koni FSD shock review + tire tips
02-17-2015, 08:46 PM | #1 |
73
Rep 463
I've had Koni FSD shocks for a few years now and thought I should report back, since I benefited so much from forum posts when I was originally researching.
They work really well... I've had them for about 4 years now, and probably about 30,000 miles. They continue to be a nice compromise of comfort and performance. They still smooth out a lot of the bumps on normal roads, and they still load up nicely when cornering. So, basically they are softer than the sport package on normal roads (going straight or turning lightly) and stiffer than the sport package when cornering. But the one catch is that when there is a sudden elevation change in the road (i.e., big bump), the shocks get into their stiff mode and it can be jarring for you or your passengers. That's basically the one time when they are strictly worse than the sport package. Overall though, I'd say they were tremendous value for money and an upgrade. On a related note, perhaps the biggest factor in ride quality is tires. For a long time I was getting very stiff max performance tires (Pilot Sport PS2s, and then Pilot Super Sports) -- but then the Pilot Sport A/S 3 came out... and it gives almost identical performance to the PS2 with more comfort, double the tread life, and a lower price! So for me it was a no-brainer, and a nice improvement to ride quality to complement the Koni FSDs. Another choice is shrinking wheel size (if you are willing!) to reduce the profile of your tires. Definitely worth considering if you are thinking about comfort. So if you're looking at ride improvement, make sure you're considering tires, as it will save you a lot of $ long term if you're in the max performance category. I hope that's helpful! Last edited by Drivaar; 02-17-2015 at 09:03 PM.. |
02-17-2015, 09:41 PM | #3 | |
12
Rep 84
02-21-2015, 01:30 PM | #5 |
173
Rep 1,117
Drives: 2010 E90 328i 6MT ZSP BSM
Thanks for the feedback. Did the Koni FSD raise the ride height at all compared to the stock sport struts? I read from another thread that Bilstein B6 would offer similar performance improvements as the Koni's but would raise the ride height slightly when used with the stock sport springs.
02-22-2015, 09:47 AM | #6 |
886
Rep 2,720
I agree with your review.
I got Koni FSD and H&R sport springs on my e93 with 19" wheels. My wife n I enjoy the ride specially on the highways. Being in NJ with bad roads and potholes around this time of the year, I had to buy a beater X3 |
02-22-2015, 11:20 AM | #7 |
257
Rep 1,347
Thanks for sharing!!
02-22-2015, 12:01 PM | #9 | |
413
Rep 1,286
2012 Jet Black 328i Coupe / ESS Tuning Gen. 2 Supercharger / Evolution Racewerks Oil Cooler / BMS Oil Catch Can / BMW Performance Exhaust with Dinan Y Pipe / Eibach Pro Kit Springs / Koni FSD Shocks / MFactory LSD & Differential Bushings / Performance Rear Trailing Arms / BMW Performance Strut Brace / Stop Tech Slotted Rotors / Hawk HPS 5.0 / SS Brake Lines / Brass Guide Pins / M3 Front Control Arms, 28 MM FSB, Engine Cowl, and DCT Paddle Shifters / Michelin PSS / APEX ARC-8
03-05-2015, 09:13 AM | #10 |
73
Rep 463
Glad the review has been helpful!
Regarding ride height: I didn't notice any major difference, but I think that would be one to measure to be sure. Sorry... I hadn't thought much about adjusting springs also, but I guess that would be a smart combination. It would be really great to see an article where people compare the different factors on ride quality and show which have the biggest effects (i.e., tires vs springs vs shocks vs bushings)... |
03-06-2015, 08:34 PM | #11 |
173
Rep 1,117
Hi Drivaar, thanks for your sharing. I read from some other threads that there are complaints of the Koni FSD yielding inconsistent performance. Have you noticed anything along that line? Many are suggesting Koni Yellows instead of the FSD. What are you thoughts on that?
Thanks again. |
