FBO w/o oil cooler
02-17-2015, 07:10 AM | #1 |
26
Rep 199
FBO w/o oil cooler
Just ordered all the goodies to go FBO for my 07 E90 A/T. It is an early build (10/06) so does not have the oil cooler installed. Anyone else running this as a DD with no oil temp issues? I would hope that if not tracking, I will be ok with a high quality oil but looking for data. If and when i do add a cooler, is ER the only retro fit option....seems very expensive but clearly high quality also.
02-17-2015, 10:27 AM | #3 | |
Professional Monkey Trainer
65
Rep 423
JB4 G5 ISO / ER Charge Pipe and Tial BOV / Wagner FMIC / CYBA Tips & Air Scoops / AFE DCI / BMW PE Exhaust Mod / M3 Rep Bumper / Dynavin E9x
02-17-2015, 10:29 AM | #4 | |
Joint Chiefs of Staff
4918
Rep 115,980
Mike |
02-17-2015, 10:31 AM | #5 | |
ex deus machina
124
Rep 968
As long as you can keep the water temp (by using max cool mode on JB4) low you won’t have issues with oil temp. You can get an auxiliary radiator (from a PPK stage 2) for about $300 to keep the temps even lower. If you are going to have a dedicated track car, then yes you would need an oil cooler.
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK Gone: E92 335i N54 468rwtq |
02-17-2015, 10:32 AM | #6 |
3441
Rep 79,211
As other said, if you start creeping past 250F oil temps then it's time for an oil cooler. If you can stay under 250F in your hardest driving and hottest temps then you are OK.
02-17-2015, 11:09 AM | #7 | |
BimmerPost Supporting Vendor
24198
Rep 190,805
It really depends on your driving style and if you track your car or not
02-17-2015, 11:36 AM | #8 |
Boost
1354
Rep 3,692
Drives: 135i M-Sport
Just buy an oil cooler, it's not fun having to monitor your temps on a DD when you're trying to carve the twisties. One can build a retrofit for <$400 on eBay
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
02-17-2015, 12:17 PM | #9 | |
30
Rep 780
02-17-2015, 01:45 PM | #10 |
2203
Rep 3,336
Drives: X5 & E90 WTCC Widebody Racecar
I was in the same boat as you, FBO and no factory OC. I frequently worried about oil temps when it warmed up because my temps were consistently sitting at 240+ regardless of how hard I was driving. After reading about how higher oil temps can start shearing/breaking down the oil viscosity, I didn't need much more convincing.
I started keeping my eyes open for a used oil filter housing and the other parts for the retro. I found a used housing for under $80 on eBay and picked up a Setrab core, lines, fittings for another couple hundred bucks. And I had a shop do the install of the OC housing while they were doing my walnut blasting since both require the removal of the intake mani. Keep in mind, if you do decide to retrofit, that since you're driving an early model, you would also need a special factory bracket to hold the oil cooler in the fender that us early model guys did not get. Part #: 51647975360 (it's more or less this part but for the passenger side - this is of the bracket on the drivers side) Be glad to chat more if you plan on retroing. I remember it being a bit tedious when I was piecing it together on my own. |
02-17-2015, 01:51 PM | #11 | ||
ex deus machina
124
Rep 968
02-17-2015, 02:04 PM | #12 | |||
Boost
1354
Rep 3,692
02-17-2015, 02:06 PM | #13 |
3441
Rep 79,211
Normal operating temp on stock vehicles with the oil cooler is ~238F +/- 10. I've seen some non oil cooled stock vehicles tip over to 255-260 on hot days normal driving.
Most other vehicles (High Performance and exotics) barely tip over 215F when pushed to their limits. BMW designs these cars to run hot and for 1 reason only and that is emissions purposes. Every other performance vehicle runs an average of 170F oil temps up to 215F max. Keeping that in mind it's really up to interpretation and your feelings if the 238-250F range is "normal" or not. It's normal for your stock BMW for emissions purposes but from a performance and longevity standpoint I'd beg to differ if its the ideal temp. I for one would at least tell guys with the oil cooler to run the thermostat by pass which means I'm partial to seeing lower temps then factory recommended specifications. I'd tell the OP to get an aftermarket oil cooler and thermostat bypass but I really don't want to sound like a salesmen. I genuinely do believe that it should be done though. |
02-17-2015, 02:10 PM | #14 | |
26
Rep 199
Thanks all for the feedback. Consensus is monitor but no urgent need if temps and driving style don't demand otherwise. I use Motul or Redline oil so should be as good as it gets in terms of heat/shear stability. I am not against the auxiliary radiator from the PPK down the road regardless...I wish these had aux transmission cooler to help with that heat load but is what it is. I have Cobb AP coming, not JB4 so no max cool mode for me. Waiting for parts to arrive and for a warm day to start installing! Got 11" of friggin snow yesterday....ain't doing poop til I get a 50F day minimum! |
02-17-2015, 02:11 PM | #15 | |
26
Rep 199
02-17-2015, 02:14 PM | #16 | |
26
Rep 199
Thx Srb |
02-17-2015, 03:16 PM | #17 |
ex deus machina
124
Rep 968
both are good choices, I prefer motul myself since I had oil consumption issues with redline in two separate cars...
02-17-2015, 03:20 PM | #18 | |
3441
Rep 79,211
The T stat bypass typically sees a 15F drop in average oil temp. |
02-17-2015, 06:39 PM | #19 | |
26
Rep 199
02-17-2015, 08:10 PM | #20 |
DIYER
614
Rep 5,521
My car stays at 180 with my cooler.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
02-17-2015, 10:06 PM | #21 |
2203
Rep 3,336
02-17-2015, 10:54 PM | #22 |
DIYER
614
Rep 5,521
100% sure its fine, 180 degree by temp sensor is actually a lit warmer. 140,000 miles and ticking.
