Garage Clear out
02-16-2015, 03:54 PM | #1 |
Rep 139
Garage Clear out
WEEKEND PRICE DROP! what isnt sold goes on ebay on sunday
So after the sale of my E91 (some time ago) i have a few bits that I have left in the garage that others may be able to use.. - M3 Front Suspension Setup - Sold - 2012 CIC nav update discs - £free + P&P - Powerflex ARB bushes - £30 + P&P - AR Design Oil Catch Can - Sold - E91 DAB Diversity Unit - £45 inc P&P - E90/1 PDC module Front and Rear - Sold - 3 Sets of 20mm Spacers and bolts - £20 + P&P for the bold on pair and the bolt through units are sold The M3 Suspension, set of wishbones and tension arms i bought but never fitted. i believe half is new, and have is off a low mileage salvage car (no front end damage). complete with Xenon adjustment arms. BAD BITS, the salvage chaps were in a rush to unfit one of the arms and cut the nut off one of the ball joint threads. i dont know if a new ball can be pressed in or if that arm is no good. SOLD 2012 Nav updates discs for CIC - £Free + postage Power flex ARB bushes for 335i E90/91 (same part number as E46) new never fitted - £30 inc postage AR Design Oil Catch Can. bought used on here. in good condition, i believe it has all the fittings, but i never fitted it. SOLD E91 Diversity amp. the unit that sits under the rear spoiler. bought this when debugging a DAB coverage issue, this turned out not to be the issue - £45 inc P&P E90/91 PDC module with front and rear connectors. i bought this unit when debugging my PDC system for what ended up being a loose sensor. SOLD 1 set of 20mm hubsentric spacers. This set bolt to the hub and then you bolt to the spacer. - £20 + p&p. let me know if you have any queries cheers Ben Last edited by smoked; 02-22-2015 at 01:23 PM.. |
02-17-2015, 06:16 AM | #3 |
Rep 139
no sadly not. the CIC disks just update the CIC system, whereas the CCC disk is what the CCC system runs off. Thats why a CCC disk is crazy expensive
02-17-2015, 10:05 AM | #6 |
Rep 139
02-17-2015, 01:12 PM | #9 |
Rep 139
02-20-2015, 03:43 AM | #10 |
Rep 139
