E92 vibrations with exhaust
01-22-2008, 08:05 PM | #1 |
360
Rep 2,451
My E92 has a vibration that occurs in the rear of the car that is coming from the console area in the rear. I removed the sliding cubby thing completely and that took away ALOT of the vibrations but there still is some. Its not my exhaust pipes rattling just other pieces in the car vibrating from the drone. Any do anything to help this?
01-22-2008, 08:33 PM | #2 |
54
Rep 1,677
I would say the sliding cubby lid would be the culprit. But you removed that. Other than that I would check the underside of the car for the brackets that are supposed to hold your exhaust in place. Turn the car on and let it idle while you look for where it could be vibrating against. Or better yet let your budy rev the car and then let off and watch the backpressure travel down the exhaust through vibrations and see if you can catch where it is rattling. If it isn't the exhaust it could also be the rear ashtray lid for the rear passengers. Best to sit in the back and let a friend drive and see if you can hear where the vibrations are coming from and try and isolate where the noise is coming from.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
01-23-2008, 12:33 AM | #3 |
16
Rep 327
A couple of things I did in my car - and it is very quiet now!
- Put felt tape behind the license plate. Reducing vibration here is critical. - Tighten the shiny metal exhaust heat shields under the rear of the car. They are not exactly tight from the factory - Layering tape on the underside of the various slidings lids in the interior Should do the trick (esp the license plate)
2008 BMW e90 M3 6MT
1990 BMW e30 325i 5MT |
06-09-2008, 03:30 AM | #5 |
106
Rep 1,534
Drives: jet black 335i coupe
DUDE WTF IM HAVING THIS PROBLEM AND I DUNO WTF to do!!!
The suggestions you listed will be attempted tommorow. Is their anyway to take out the rear center slider door thing?
06-09-2008, 03:34 AM | #6 | |
384
Rep 21,747
Drives: E92 335i TiAg/E46 323i TiAg
Put some gel-like or soft foam material underneath and it should help dampen the vibration. Right now, I have a tennis ball and a brand new Nike sock in the compartment to dampen it.
07 E92 335i | TiAg | Step | Padl | Cmft | Alum Trm | PDC | Nav | Assist | Sat | Lthr | Prem | Sprt | Rear Splr | RDSport Quads | iPod | V1 | LT Refl | VS Clear Bra | OEM Lip | KWV2 | Mtec Sides | BBS LM-R
00 E46 323i | TiAg | 5sp | Sport | Roof | RDSport Cams | RDSport tune | RDSport Shift | Volk LE37 | M3 spoiler | PSS9 | SuperSprint | Brembo |
