Synapse BOV just went really quiet this weekend, What to check?
02-16-2015, 02:12 AM | #1 |
135
Rep 2,120
Drives: ///M Roadster + E92 335i 6MT
It still releases a little "whoosh" but nothing like it used to,
Its absolutely freezing outside so I need to get it on and off the car asap, Anyone have an idea what could be up with it? Car drives smooth no stutters, Buts slower I feel than it should be under boost, I checked the obvious, /Vacuum lines or if anything had come off, and heres a weird question, at idle, if you feel directly in front of the bov Should I feel air coming out of that? Or it that normal?
Imola Red Roadster |
02-16-2015, 08:29 PM | #2 |
BimmerPost Supporting Vendor
24198
Rep 190,805
You shouldnt feel air coming out of the BOV on idle
Synapse have not been a reliable BOV for our cars which made lots of Manufacturers stop offering them with their charge pipes. I recommend calling synapse,if they cant help you get another BOV ( HKS or Tial)
02-17-2015, 12:17 AM | #4 |
135
Rep 2,120
I got of off the car tonight,
Stripped it and cleaned it, No broken parts so nothing obvious, and yes at idle its still letting air out, But the cars seems to be running ok? Weird
02-17-2015, 01:34 PM | #5 |
Rep 116
I'm gonna follow this as I have the Synapse as well. I can tell you for sure that air comes out of mine at idle. After I put it on I was freaking out about this so I did some research and found that this is absolutely normal for air to come out at idle. Check out the video.
02-19-2015, 06:59 PM | #6 |
135
Rep 2,120
Yup wasn't the little spring inside the valve or the larger spring,
No broken parts I can see, Can't find a vacuum or boost leak, Anyone else have any idea's why it went quiet on me?
02-19-2015, 07:42 PM | #7 | |
648
Rep 2,011
335i e92 TPC 19Ts
02-21-2015, 09:47 PM | #8 |
Rep 116
02-21-2015, 10:00 PM | #9 |
135
Rep 2,120
Still a lot quieter than before with no explanation.
I even tried emailing synapse, They responded with "check the small spring and if its broken take it out" they never replied to any of my follow up emails saying its still quiet so I'm at a loss
02-21-2015, 10:06 PM | #10 |
Rep 116
Wow that's crazy. I was out driving the car today and it's just as loud as it was new. Iv'e only had it on about 3 months now. How long has it been since the install?
02-21-2015, 10:20 PM | #11 |
135
Rep 2,120
I bought it used so I'm not sure how many total miles on it,
But there doesn't seem to be many parts inside it so it must be something I've missed or overlooked All seals and O-Rings are fine, no broken springs, Really has me scratching my head
02-21-2015, 11:07 PM | #13 |
583
Rep 2,233
Drives: '12 M3
Did you check your coupler to your throttle body? Mine popped off again -_-
02-22-2015, 09:50 AM | #14 |
DIYER
614
Rep 5,521
Check the vac lines
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
02-23-2015, 09:20 AM | #15 |
135
Rep 2,120
Embarrassingly enough I believe this was a boost leak,
I took off the chargepipe and cleaned all fittings, Put a new throttle body O-Ring on and reseated the synapse valve to the CP, Seems like its got its sound back, I'm awaiting a boost gauge from ECS so I'll know what kind of numbers I'm making rather than the gauge hijack from the JB4 but I'm pretty sure I found it even though there was nothing obvious when removing the chargepipe, I guess just re-seating it all back together helped?
02-23-2015, 10:33 AM | #16 | |
3441
Rep 79,211
02-24-2015, 10:29 AM | #20 |
3441
Rep 79,211
02-24-2015, 10:42 AM | #21 | |
135
Rep 2,120
without sounding stupid what do I need to do?
02-24-2015, 11:34 AM | #22 | |
143
Rep 567
http://www.n54tech.com/forums/showthread.php?t=13465 http://www.n54tech.com/forums/showthread.php?t=10605
07 335 6MT
